261 - 280 of 290 Posts
Discussion Starter · #265 · (Edited)
Was your bike the test mule, @kevxtx ?
Not this one, but another manufacture has used my bike to make bolt on 2021 mods which will be launched in the coming weeks, with a few different options of screens & a heap of other mods to bolt on.
2016 xsr 900
holy moly - look at the size of the heat sink on that headlight - wow.
I do not know why Yamaha doesn't 'fix' the fuel gauge issue. It would be trivial for them to program the ECU to interpret the sending unit input on a non-linear scale, so that the gauge is much closer to accurate.
Bike is looking good thus far - nice to hear some solid real-world feedback.
Discussion Starter · #267 · (Edited)
'21 Yamaha MT-09
kevxtx, just curious, why did you use the AUX plug and not the dedicated heated grip power plugs?
Discussion Starter · #269 ·
The whites has a controller built into the left grip which cant be disconnected, I did not see the point of having 2 controllers, also the dash heated controller symbol is small & not that easy to read on the fly.
Discussion Starter · #271 · (Edited)
Installed my 9.5nm YSS linear fork springs today, good bye fork dive from those progressive springs, heavier spring rate, static sag set, will need to dial in the valving. Big thanks to Adam [email protected] for helping me out with the right springs, I stripped my forks last weekend gave him some measurements & got the new set of springs on Thursday. I had to get 2 x 5mm spacers made up as the new springs were 5mm shorter.
NOTE: Sizes in pictures are of the STD progressive spring
YSS spring
OD 1 – 33.5
OD 2 – 36.0
LENGTH – 270 mm
RATE – 9.5 N
*5mm shorter – 2 x 5mm washers around the smaller bottom end of the spacer
165576
165577
165578
STD SPRING
165579
165580
STD SPRING measurements
165581
165582
165583
165584
165585
Needed more stopping power.2004 R1 320mm front rotors, HH EBC Pads, 11mm Ti caliper spacers, 10mm longer caliper bolts, Ti rotor bolts, an a rear rotor off a MT07 just to match the front wave rotors. View attachment 164462
View attachment 164464 View attachment 164465
Did The bigger discs make much difference to the stopping power Thinking of doing mine the same.
Discussion Starter · #273 ·
Yip it does, more stopping leverage + grippy pads, done this mod to my past 3x 09's.
Discussion Starter · #274 · (Edited)
Another screen out on the market with an optional mouth piece that covers the horn. Can be ordered from Australia 0427923234 [email protected] Hans who made this mask owns a 09 & has some more bit to come.
165918
165919
165920
165921
165922
Discussion Starter · #275 · (Edited)
Waiting on Woolich or FT to get into this ECU 2021 09 ECU until then I will do it the old way. I modified my 2014 Dynojet PCV to fit the 21 09, I had to extend the speed signal wiring by 30cm the PCV works fine, will build some maps soon, 2021 MT09 PCV - YouTube
For the PCV TPS signal wire dont use Dynojets 2021 09 instructions or photo as they are wrong, they say use the white wire pin 3 I used the white wire pin 4 on my 21
166271
09SP.
165926
165927
165928
165929
Discussion Starter · #277 · (Edited)
I contacted Hell Australia as I wanted Teflon braided brake lines for my 21 09, I got a set custom made, they replace the front rubber to steel to rubber lines, I had them make the pipes directly from the ABS pump steel pipes to brake master cylinder 1290mm long end to end with banjo at master & twist on end at ABS, left caliper to ABS pump steel pipe 1120mm long banjo at caliper & twist on end at ABS & caliper to caliper 530mm end to end banjo to banjo, I did not bother fitting the rear hell lines. Result a much firmer brake feel with less lever travel.
166260
166261
166262
166263
166264
166265
166266
166267
166268
Ends at ABS pipes for master & caliper pipes.
166303
Discussion Starter · #280 ·
I did not expect that huge difference in airboxes. Will a free flow Dna air filter help ?
I would not waist my money on just the main filter change been there Dynoed that, I have spoken directly with DNA on their stage 2 air box lid for the 2021 09, they have no Dyno tests as yet, not keen to fork out Australian $550 on a untested stage 2 lid mod. Not sure if the stage 3 2014 to 2020 DNA complete air box will fit the 2021 09.
