So I am adding a GPS tracker, Camera and extra lights for paniers (Long trips). All of them with quick disconnect and fuses.
All of them have a negative terminal. Can I just connect the negative terminals of all the accessories to the battery's negative? Or if it is a negative for a light from panier, I should only connect it to the negative of the light?
Here is my wiring plan: The # on brake light is for running brake light and # on the GPS is the ACC (12volt ignition)
Second Question I have is they are these empty slots. Instead of buying a fuse box, can I just add fuses here and run wires from the other side? Anyone have any info on how to remove the Fuse box.. I was able to unclip the top one, but couldn't figure out the bottom clip to remove it.
Appreciate your help everyone...
