1 - 3 of 3 Posts
Does anyone know if the plastic bezel that surrounds the 2016 and earlier single headlight assembly is available as a separate part? Mine broke and I can't seem to find a part# to replace this plastic bezel that snaps into place around the headlight assembly. Surely it's available separately from the entire assembly?
Sorry, mate. You’re looking at a whole new headlight assembly (#1 in the parts diagram you posted).
Look at eBay and the like for a used one first...
if you have the broken housing and it is just cracked or in pieces. Rough up the back side with a dremel tool, Get some JB Weld, lay a nail in the puddy at right angles to the crack for strength it against bending and re-cracking. I also use metal window screen with JB weld for strength too. Several layers are better than 1 layer. After done, on finish side, sand and fill. Repaint and put it back together. I have a seat cowl on my Hawk that had a 3 inch crack I repaired 5 years ago. Cure for several days inside house where warm.
Reactions: Moto26
1 - 3 of 3 Posts
