Engine light
Close
Login to Your Account
Engine light
This is a discussion on Engine light within the XSR900 General Discussion forums, part of the Yamaha XSR900 Cafe Racer Forum category; So i took it for a firs ride after ivan's flash.woow!great is all i could say.bike very smooth,lots of power,just like new,but with akrapovic carbon ...
Results 1 to 4 of 4
Thread: Engine light
  1. #1
    Junior Member Gizu's Avatar
    Member #
    38576
    Join Date
    Sep 2018
    Posts
    19
    Engine light
    So i took it for a firs ride after ivan's flash.woow!great is all i could say.bike very smooth,lots of power,just like new,but with akrapovic carbon exhaust. Then this happened... after about 150 miles, multiple stop,start no issues i stopped for a coffee. When i tried to start the bike it wouldn't start. Tried a couple of times and nothing. The starter would turn,dashboard lit up but wouldn't start. Then i looked at the key and it was sitting between off and on position. When i turned it to on the bike started no problem, but i noticed the engine light came on!!i stopped and checked if everything was ok,turned it off and back on and still the light remains on!i didn't notice any performance issues .bike seems to be working normally, but the engine light is still on.any idea what has happened to my bike??what could i do?will dealer even want to look at it knowing i got different exhaust and flash from Ivan??i got about 1500 miles on it,it'll be a year old in July. Any advice?pls help. I will contact Ivan tomorrow and explain the situation, but if any of you have some idea as to what happened, pls help if you can. I'm not even sure if the key situation is the reason the engine light came on,but that was a bit strange. Like i stated before there was no issues until that key situation
  2. #2
    Senior Member Steve H's Avatar
    Member #
    14834
    Join Date
    Nov 2016
    Location
    Perth WA
    Posts
    666
    Apparantly a fault code has to be cleared by a special tool...as it isnt affecting the running of the bike take it to a dealer and tell them it just came on after the key incident....if they are any way decent they will clear the code for free. Ask if they are going to charge before letting them do anything though....some dealers are b.....rds
    Smoke me a kipper I'll be home in time for breakfast
  3. #3
    Member #
    38576
    Join Date
    Sep 2018
    Posts
    19
    Thx.i appreciate it, didn't know it's a common issue...
  4. Remove Advertisements
    FZ09.org
    Advertisements
  5. #4
    Senior Member minsk99's Avatar
    Member #
    7038
    Join Date
    Mar 2016
    Location
    Cambridge, MA
    Posts
    260
    Cmmon issue. I had same code thrown last week for key not in full on position. I have OBDII reader that can clear codes. Very helpful to have.
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Check engine light came on today ('15 , 2k miles)
    By Wolfdog in forum Yamaha FZ-09 Common Problems/Issues
    Last Post: 08-28-2018, 01:46 PM
  2. Clear Check Engine Light (Ghost Check Engine)
    By clubtc05 in forum XSR900 General Discussion
    Last Post: 11-26-2016, 04:05 PM
  3. Oil Light/Engine Light
    By rosavp33 in forum Yamaha FZ-09 Common Problems/Issues
    Last Post: 02-21-2016, 08:27 AM
  4. engine / frame bolt cap covers / Engine bolt kit/ valter moto
    By FZO9 in forum FZ-09 Gear & Accessories
    Last Post: 02-01-2016, 10:08 AM
  5. Check engine light and code
    By Dj1911 in forum Yamaha FZ-09 Common Problems/Issues
    Last Post: 01-30-2015, 09:16 PM
