Tire pressure info from dunlop
Close
Login to Your Account
This is a discussion on Tire pressure info from dunlop within the FZ-09 General Discussion forums, part of the Yamaha FZ-09 Forums category; In case anybody wanted to know, dunlop told me their recommended pressure with the roadsmart 3's for spirited street riding. 34f 32r was their answer....
Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Like Tree9Likes
Thread: Tire pressure info from dunlop
  1. #1
    Member Gregpow's Avatar
    Member #
    39128
    Join Date
    Dec 2018
    Posts
    73
  2. #2
    Senior Member LouG's Avatar
    Member #
    5709
    Join Date
    Jul 2015
    Location
    Nelson, New Zealand
    Posts
    4,065
    For an 09?
    '14 MT 09
    Andreanni Cartridge kits
    Nitron Road and Track Shock
    Givi screen
    Renthal McGrath bend Bars.
    V1+YaV1 Licence protector
    SW Motech Quicklock Tankbag.
    Kevxtx O2 Controller.
    Custom Chain Oiler
    El Cheapo Chinese levers.
  3. #3
    JSP
    JSP is offline
    Senior Member JSP's Avatar
    Member #
    2866
    Join Date
    Jul 2014
    Location
    Central Oregon
    Posts
    382
    Quote Originally Posted by LouG View Post
    For an 09?
    Tire pressures usually are not bike specific.
    -Jay
    You call it facial hair... I call it AWESOMENESS escaping through my face!
    Previous Bikes: 09 Rebel 250, 09 FZ6R, 09 R6, 11 FZ8, 02 Bandit 1200S
  4. Remove Advertisements
    FZ09.org
    Advertisements
  5. #4
    Senior Member Crosshairs's Avatar
    Member #
    2174
    Join Date
    May 2014
    Posts
    2,472
    Quote Originally Posted by JSP View Post
    Yet oddly enough, for a Versys 1000, they told me to run 36/42 if loaded and 32/38 if riding solo with light load ......
    here is a list of their tires and recommended pressures for most bikes
    https://static-content.motosport.com...reFitments.pdf
    2014 FZ09 Mods> Ivans ECU Flash....... Penske 8983....... GP fork piston kit.......Woodcraft Frame Sliders....Woodcraft Axle Sliders ...Woodcraft Engine guards...Chinese spools...
    Spiegler SS brake lines .....APE CC tensioner .....Antigravity AG-801 Battery......tripage LED headlight.......tripage LED pegs ...Watsen Design front turn signals..and some other stuff I dont feel like listing
  6. #5
    Senior Member Harry Balzak's Avatar
    Member #
    827
    Join Date
    Dec 2013
    Location
    why do you want to know. I'm not sure I trust you with that information.
    Posts
    1,953
    I'm not sure how that could be true since a 650 lbs. bike is going to need more air pressure in it's tires than a 400 lbs. motorcycle. You will also need to adjust for the load you're carrying and the size of the rider and/or pillion.
    meinschaft, LouG and Crosshairs like this.
    2019 Tracer 900GT
    2016 Kawasaki 140L
    2015 Yamaha FZ07
    2013 Honda CRF100 tarded for track use
  7. #6
    Senior Member meinschaft's Avatar
    Member #
    6770
    Join Date
    Feb 2016
    Location
    Nirvana
    Posts
    453
    If these far lower than factory-recommended pressures (36F/42R) make so much sense, then is it safe to do the same with a car? Instead of the recommended 35 psi, just run 18 or 20psi cuz 'performance'?
    1965 Triumph Bonneville, 1968 Honda Cl350, 1972 Yamaha XS650, 1982 Yamaha XS650, 1999 Triumph Legend TT, 2004 Kawasaki Z750S, 2008 Yamaha FZ1, 2008.5 Yamaha FZ1, 2015 Yamaha FZ-09
  8. #7
    Junior Member Tatertot1060's Avatar
    Member #
    37936
    Join Date
    Jul 2018
    Posts
    27
    I'm not sure everyone here is aware of how tires and their pressures affect them. Lower pressures cause a bigger contact patch, which will alow for not only more friction between the road and the tire, but will cause the carcass to flex more. What this causes is heat in the tire. Typically the lower pressure you run, the more heat you get into the tire. Touring tires are generally filled up to that 38-40 psi mark because you have a smaller contact patch, which caused less wear and less of a harsh heat impact on the tires. At the track, on a 90 degree day I'll run my q3+ at degrees cold, and a q4 32 cold. Tires typically have a 4-5 psi gain cold to hot on the track, and a 2-3psi cold to hot on the street. If your speed and ability level isn't high enough to keep a tire warm then, yes lowering the pressure ie dangerous, but generally lowering pressure will give you more performance.
    LouG and roadrash83 like this.
  9. #8
    Member #
    827
    Join Date
    Dec 2013
    Location
    Posts
    1,953
    I'm no expert, but yes understand how tire pressures work. I typically run 34/36 or 36/36 on both bikes unless I'm carrying cargo and then I'll bump the pressure up on the rear. Lowering the pressure to increase contact patch and heat has a limit of diminished return. Too much flex and heat can cause greasy tires that break traction unpredictably. I can tell within a couple corners if I my tire pressures are within an acceptable range.
    2019 Tracer 900GT
    2016 Kawasaki 140L
    2015 Yamaha FZ07
  10. #9
    Member #
    5709
    Join Date
    Jul 2015
    Location
    Nelson, New Zealand
    Posts
    4,065
    My experience, and that of many 09 owners say that it is. So does Michelin and Dunlop it seems.
    Crosshairs likes this.
    '14 MT 09
    Givi screen
    Custom Chain Oiler
  11. #10
    Member #
    5709
    Join Date
    Jul 2015
    Location
    Nelson, New Zealand
    Posts
    4,065
    Quote Originally Posted by meinschaft View Post
    Many owners of my car model use lower pressures for comfort, and some say handling is better. But cars generally aren't as pressure sensitive as bikes.
    '14 MT 09
    Givi screen
    Custom Chain Oiler
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
