LED Running Light suggestions
Close
Login to Your Account
This is a discussion on LED Running Light suggestions within the FZ-09 General Discussion forums, part of the Yamaha FZ-09 Forums category; On my Tracer GT I replaced the stock pumpkins with a really nice set of LED lights. The downside is that I lost the running ...
Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By djbpdx
Thread: LED Running Light suggestions
  1. #1
    Junior Member gerdawg's Avatar
    Member #
    40544
    Join Date
    May 2019
    Posts
    22
    On my Tracer GT I replaced the stock pumpkins with a really nice set of LED lights. The downside is that I lost the running lights in the front. On that bike it was easy to run some external fog lights so that cars could see me easier. On the FZ9 it seems like fog lights might be more of a challenge then they are worth and I like having the extra visibility. Can anyone suggest some nice LED running lights that work with the bike and look functional? Pictures would be great as well if you have them! Thanks!
  2. #2
    Junior Member djbpdx's Avatar
    Member #
    35082
    Join Date
    Apr 2018
    Location
    Portland, OR, USA
    Posts
    18
    I installed a set of Lightech lights that have amber turns signals and white running lights (one row for each colour, stacked on top of each other). You can find them for purchase by seaching "LighTech Integrated LED Turn Signal - Type 3"
    Imgur link
    edit: I should note that I was pulled over by Washington State Police recently and the officer mentioned that these lights are technically too small to be considered legal in that state (must have lit surface area of 3 square inches). Check your local equipment laws, or avoid cops.
    DrunkulaTX likes this.
    2017 Matte Silver (Puig touring screen + CustomLED integrated tail light + LighTech front signals + Kaoko throttle lock + Yamaha comfort seat)
  3. #3
    Senior Member jimmay's Avatar
    Member #
    7040
    Join Date
    Mar 2016
    Location
    Toronto, ON
    Posts
    216
    Traf-X hands down. Expensive but worth it and still look great after 3 years. Bright as hell, too. None of this dim Amazon LED garbage.
    Do a search for Traf-X Indicator X Light 02
    I can't find my pics, but here's another guy's:
    https://www.fz09.org/forum/13-fz-09-...d-signals.html
    Edit: Also, I think not having the signals on as daytime running lights, regardless of which signals you have attached is probably to do with wiring. I ended up using a 3 to 2 wiring kit from Tripage LED and mine are always on as running lights. The dashboard does blink alternate of what the signal is doing; when dashboard signal light is on, the actual signal light is off, kinda thing.
    2015 Yamaha FZ-09
    1993 Suzuki GS500
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
