Throttle valve issues - please help
Close
Login to Your Account
This is a discussion on Throttle valve issues - please help within the FZ-09 General Discussion forums, part of the Yamaha FZ-09 Forums category; Hello, so I am a new member here coming for help, first of all sorry for my English. I own a motor from bike Yamaha ...
Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By shamrock
Thread: Throttle valve issues - please help
  1. #1
    Junior Member Emilliaan's Avatar
    Member #
    40506
    Join Date
    May 2019
    Posts
    1
    Hello, so I am a new member here coming for help, first of all sorry for my English. I own a motor from bike Yamaha MT09 2015 and it seems to have problems with ECU.
    When I turn the key ON it will not start because the throttle bodies are always closed.. they wont open when the motor is starting or when it runs. When I turn the ignition ON, the relay is working, the fuel pump is working, sparks are ok, fuel injectors are ok but the throttle valve is always closed. I can start the motor only by opening the throttle valves by pushing them by hand and the motor runs ok without problems..
    So next thing I tried to connect a 6 volt battery to the servo motor that opens the throttle and they open very nice so the servo motor is ok, also fuse "ETV" is ok. I checked all the wiring, all connectors, all fuses, relay, all sensors, I tried disconnecting all the sensors and nothing is working.
    The problem is that ECU is NOT giving power to the servo motor. When the motor runs it has also no response from the "gas pedal". What could be blocking the ECU to not open the throttle valve? I said it is running smoothly when I open them with hand, when I release them the motor dies.. I have to mention that last thing that has been done to ECU is that it has turned off the immobiliser by "professional" without opening the cover of ECU
    I am desperate please help.. I was trying everything for like 5 days now. I could go for Yamaha diagnostic but the nearest dealer is like 40 km away from me but I think I have no choice. All info will be appreciated.
  2. #2
    Senior Member LouG's Avatar
    Member #
    5709
    Join Date
    Jul 2015
    Location
    Nelson, New Zealand
    Posts
    3,969
    If someone has hacked the immobiliser, you will have to get that sorted by a dealer. Or the "pro" that did it. Pray that the ECU isn't screwed.
    '14 MT 09
    Andreanni Cartridge kits
    Nitron Road and Track Shock
    Givi screen
    Renthal McGrath bend Bars.
    V1+YaV1 Licence protector
    SW Motech Quicklock Tankbag.
    Kevxtx O2 Controller.
    Custom Chain Oiler
    El Cheapo Chinese levers.
  3. #3
    Gold Supporting Member
    Supporting Member
    shamrock's Avatar
    Member #
    83
    Join Date
    Jul 2013
    Location
    Citrus Springs, FL
    Posts
    1,967
    My guess would be the "accelerator position sensor" but then I noticed your statement about somebody screwing around with the ECU so more than likely that's your problem.
    I would keep the "professional" away from any further experiments and seek out a dealer or try to find a used ECU.
    LouG likes this.
    "There is a grey blur and a green blur so I try to stay on the grey one"-------Joey Dunlop
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. XSR Seat Cowl - I Need HELP with install!!! PLEASE HELP
    By adam in forum XSR900 General Discussion
    Last Post: 11-21-2017, 12:18 PM
  2. Advice please? Minor issues
    By fetters in forum Yamaha FZ-09 Common Problems/Issues
    Last Post: 10-30-2015, 08:13 AM
  3. Graves signal issues. Please help.
    By QUIETSTORM in forum FZ-09 General Discussion
    Last Post: 12-19-2014, 08:22 AM
  4. Turn Signal Issues Please Help. Not the typical fuse blown problem
    By davidz28 in forum FZ-09 General Discussion
    Last Post: 04-15-2014, 07:06 PM
  5. FZ 09 Throttle Issues and remapping??
    By han in forum FZ-09 General Discussion
    Last Post: 02-03-2014, 03:30 PM
