Big Problems (Advice needed)
Close
Login to Your Account
This is a discussion on Big Problems (Advice needed) within the FZ-09 General Discussion forums, part of the Yamaha FZ-09 Forums category; I have a 2015 FZ 09 with 4203.03 miles. I was riding to work on the freeway at about 65 mph and the bike dies, ...
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Like Tree10Likes
Thread: Big Problems (Advice needed)
  1. #1
    Junior Member NORCAL1's Avatar
    Member #
    4757
    Join Date
    Apr 2015
    Posts
    9
    I have a 2015 FZ 09 with 4203.03 miles. I was riding to work on the freeway at about 65 mph and the bike dies, like the key got turned off. I costed to the shoulder and shut the key off and then back on and hit the starter and nothing. I thought maybe the battery cable came loose. Pulled seat and it is tight. This bike is in showroom condition. Well I had to get it towed to the Yamaha shop and they just called me and said it looks like a bolt in the clutch assembly came loose and chewed up a ton of stuff. Long story short 825.00 in parts and 425.00 in labor to fix. I know my warranty is up, but this seems like a manufacturer defect. There is no maintenance to tighten bolts on clutch. So my question. Do you think I am screwed or should I contact Yamaha and try to get them to cover or maybe get an attorney. What should I do in your guys opinion.
  2. #2
    Senior Member massrider's Avatar
    Member #
    16857
    Join Date
    Feb 2017
    Posts
    197
    Was there any noise before it died? Seems to me if it was a bolt you would have heard some kind of noise. I had a quad that died all of a sudden out of nowhere. It would fire but never turn over. It ended up being the stator I belive.
    Sent from my SM-J700T1 using Tapatalk
  3. #3
    Member Playjuryst's Avatar
    Member #
    7417
    Join Date
    May 2016
    Location
    NYC
    Posts
    67
    Unfortunately, if the warranty is over, whether it’s by a week or a decade, you’re SOL. What happens if the starter goes in an 8y old car? Same logic.
    I mean, things go bad, machines aren’t perfect. If it happened to many there’d be a chance for a recall, but there isn’t one in this scenario, that I know of. I have a hard time finding a case for a lawyer here, and even if there was one, it would cost more than the repairs.
    Sorry to be the bearer of bad news, but I don’t see an option here.
  4. Remove Advertisements
    FZ09.org
    Advertisements
  5. #4
    Member HyperNakedPimp's Avatar
    Member #
    32705
    Join Date
    Feb 2018
    Location
    Fairfield County, CT
    Posts
    38
    A bolt coming loose in the clutch wouldn't shut the bike down causing it not to run.. warranty wont cover you and what parts did they replace?
    2017 Yamaha FZ-09 Pearl WhiteCu$tom
  6. #5
    Senior Member LouG's Avatar
    Member #
    5709
    Join Date
    Jul 2015
    Location
    Nelson, New Zealand
    Posts
    3,953
    So the engine seized solid? There was no unusual noise when the thing died?
    '14 MT 09
    Andreanni Cartridge kits
    Nitron Road and Track Shock
    Givi screen
    Renthal McGrath bend Bars.
    V1+YaV1 Licence protector
    SW Motech Quicklock Tankbag.
    Kevxtx O2 Controller.
    Custom Chain Oiler
    El Cheapo Chinese levers.
  7. #6
    Member #
    7417
    Join Date
    May 2016
    Location
    NYC
    Posts
    67
    Regardless, the bike is running now, the parts were replaced, looking forward and not back... don’t see much recourse
  8. #7
    Member #
    16857
    Join Date
    Feb 2017
    Posts
    197
    Quote Originally Posted by Playjuryst View Post
    I don't belive he has the bike running yet.
  9. #8
    Member #
    7417
    Join Date
    May 2016
    Location
    NYC
    Posts
    67
    Oh, the price was a quote to fix, but it wasn’t done yet, my bad.
    In that case, I’ll post some thoughts on what we know:
    Normally the bike won’t start up in gear, the clutch must be pulled.
    He mentioned “coasting” to a stop, so it didn’t die in a low gear, or he would have had more engine brake (OP verify)
    So in theory, the original diagnosis could be correct.
    Being stuck in a gear, due to a floating bolt in the clutch case/pack COULD prevent startup
    The initial stall could have happened from multiple things.
  10. #9
    Senior Member Harry Balzak's Avatar
    Member #
    827
    Join Date
    Dec 2013
    Location
    why do you want to know. I'm not sure I trust you with that information.
    Posts
    1,910
    You didn't say when you bought it, new or used, did you buy it from that dealer?
    2019 Tracer 900GT
    2016 Kawasaki 140L
    2015 Yamaha FZ07
    2013 Honda CRF100 tarded for track use
  11. #10
    Senior Member OldSchlPunk's Avatar
    Member #
    37818
    Join Date
    Jul 2018
    Location
    Hilbert, WI
    Posts
    133
    Before any work was performed, I would expect to see exactly what was damaged, even if I didn't know what I was looking at. I don't trust dealers, any type. Too many will give you a bullshyte story with a list of parts and labor costs hoping you won't have a looksee. This may not be the case but who knows.
    I find it hard to believe that what was described wouldn't result in a complete teardown due to metal shavings everywhere in the engine. Just my .02
    minsk99 likes this.
    '92 Bandit 400
    '18 MT-09
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Big Road Trip - Need Your Advice and Tips
    By WebbyRides in forum FZ-09 General Discussion
    Last Post: 02-01-2019, 07:23 PM
  2. Winter is coming! (heated grips advice needed)
    By Sport Tracker in forum FZ-09 Gear & Accessories
    Last Post: 10-07-2016, 07:48 AM
  3. New member, advice/help needed asp
    By Gixxer in forum FZ-09 General Discussion
    Last Post: 04-19-2015, 06:39 PM
  4. Need advice on KTM problems
    By 72jtruck in forum Other Bikes
    Last Post: 09-09-2014, 12:41 PM
  5. Advice needed ASAP! front suspension marshmallow
    By riplee in forum FZ-09 General Discussion
    Last Post: 08-15-2014, 08:01 PM
