Auxiliary LED lighting project
Close
Login to Your Account
This is a discussion on Auxiliary LED lighting project within the FZ-09 General Discussion forums, part of the Yamaha FZ-09 Forums category; First off.. Thanks to Shamrock as I am putting his supplied supermoto fender bracket to use in another way . Always in a quest for ...
Results 1 to 9 of 9
Like Tree3Likes
  • 1 Post By troop
  • 1 Post By Bucket Jumper
  • 1 Post By Hawkerjet
Thread: Auxiliary LED lighting project
  1. #1
    Senior Member troop's Avatar
    Member #
    6144
    Join Date
    Sep 2015
    Location
    Stoughton, WI
    Posts
    2,517
    First off.. Thanks to Shamrock as I am putting his supplied supermoto fender bracket to use in another way . Always in a quest for improved lighting, I scoured the net for a practical lighting source that would give me a bit extra lighting for my night time ventures. And it needed to be inexpensive. I found a light that would fit nicely under my headlight, be thin for clearance and provide a boost in light. So, I spent $22 on this Chinese/ebay LED 7 INCH 40W CREE Led Flood Spot Combo Work Light Bar OFFROAD Car 4WD Ellip Beam | eBay and cut/drilled/painted the Shamrock supplied bracket to mount the light. I think the end result looks quite nice and I have 6.5" light > fender clearance. How does it work?? Got tired of cutting/drilling/painting/bolting up, so I'm going to hold off on the wiring up till this weekend. We shall see???
    ** I now have a $140 Euro Street Rally chin spoiler sitting ob the shelf in the basement. Will hold on to it until I know how the light project works. I'll attach of picture of that to compare to the light. **
    Attached Thumbnails Attached Thumbnails Auxiliary LED lighting project-20161026_091018.jpg   Auxiliary LED lighting project-20161026_112342.jpg   Auxiliary LED lighting project-20161026_113713.jpg   Auxiliary LED lighting project-20161026_122145_001.jpg   Auxiliary LED lighting project-20160719_121924.jpg
    shamrock likes this.
  2. #2
    Member #
    6144
    Join Date
    Sep 2015
    Location
    Stoughton, WI
    Posts
    2,517
    Done ...
    Attached Thumbnails Attached Thumbnails Auxiliary LED lighting project-20161027_101952.jpg
  3. #3
    Senior Member Bucket Jumper's Avatar
    Member #
    5706
    Join Date
    Jul 2015
    Location
    Nocona, TX
    Posts
    331
    Nice job. I accomplished the same effect with 2 round, 4 led lights in the same location, wired to a handlebar switch. Throws quite a bit more light too. Sorry about the poor garage lighting and phone pics don't help much. I think you did a better job than I.
    ridetofish likes this.
  4. Remove Advertisements
    FZ09.org
    Advertisements
  5. #4
    Senior Member Lateralus's Avatar
    Member #
    3268
    Join Date
    Sep 2014
    Location
    Nevada
    Posts
    852
    Thanks Troop.
    2014 FZ-09 - Rapid Red - Flashed by Vcyclenut
  6. #5
    Senior Member Res4cue's Avatar
    Member #
    7705
    Join Date
    Jun 2016
    Location
    Manassas Va
    Posts
    363
    Pics of output?
    2016 FZ09
    Armor grey/hi viz
    Graves FE
    Tripage flush out LEDs fronts
    Custom LED taillight with switch and sequencer
    Evotech radiator guard
    Chinese shorty levers
    Chinese steering damper (on top)
    USB mod
    TST rear stealth plate light
    Forks by Matt
    Stoltec Penske 8900E
    Ivan's flash
    Termignoni stainless headers and Carbon can
    USB mod
    Horn relocated
    Opt7 led headlight bulb
    LED Aux lights (amber)
  7. #6
    Senior Member s fortuna's Avatar
    Member #
    727
    Join Date
    Nov 2013
    Location
    iowa
    Posts
    734
    IRELAND IS MY TRUE HOME
  8. #7
    Senior Member Hawkerjet's Avatar
    Member #
    1144
    Join Date
    Jan 2014
    Location
    Shake and Bake Cali...aka Fresno
    Posts
    1,787
    Cookin Wid Gas
  9. #8
    Member #
    1144
    Join Date
    Jan 2014
    Location
    Posts
    1,787
    Quote Originally Posted by troop View Post
    Done ...
    That should light up the world. I did mine to be seen by cars.
    The few times I rode at night the light was amazing.
    You will like yours.
    troop likes this.
    Cookin Wid Gas
  10. #9
    Member #
    6144
    Join Date
    Sep 2015
    Location
    Stoughton, WI
    Posts
    2,517
    Quote Originally Posted by Hawkerjet View Post
    Exactly! More frontal light for oncoming/approaching daylight traffic. I like the flood portion for a bit more shoulder lighting at night. Damn varmint's
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Replies: 121
    Last Post: 08-01-2017, 05:51 PM
  2. Auxiliary Fuse
    By Coreytrevor in forum FZ-09 General Discussion
    Last Post: 11-16-2016, 10:39 PM
  3. LED lighting question
    By don_don465 in forum FZ-09 General Discussion
    Last Post: 10-19-2016, 03:47 AM
  4. Auxiliary fuel containers
    By fZIdaho in forum FZ-09 Builds
    Last Post: 09-20-2016, 10:20 AM
  5. After installing flush LED signals, auxiliary lights and horn no longer work.
    By Austin107 in forum Yamaha FZ-09 Common Problems/Issues
    Last Post: 04-03-2015, 10:19 AM
Search tags for this page
fz09 aux lights
fz09 light bar
