Instrument panel won't display
26K views 13 replies 10 participants last post by  Bryan
#1 ·
Hello all,
I am brand new member to this forum, and also a new (as of last summer) FZ-09 owner. I recently had to replace a battery in the bike, now the display won't work.
Bike turns over immediately, headlights, turn signals/hazard works. Neutral indicator light and Hi-beam indicator lights both work. The only thing not working is the display panel.
Any suggestions would be appreciated.
#2 · (Edited)
First thought is check your fuses and make sure you didn't blow a fuse when you replaced your battery?
Via accidentally grounding out a wire while changing battery, it might have happened and you didn't notice it????
If no blown fuses, check all you connectors under the seat, to make sure nothing came loose.
#3 ·
A couple of folks have found the connector to the display were intermittent so check those connectors as well. Especially if you have done anything like turnsignals up front on the bike.
