Vcyclenut flash review - Page 3
Close
Login to Your Account
This is a discussion on Vcyclenut flash review within the Flashed by VCycleNut forums, part of the Vendors category; Originally Posted by bambamrl Tried activating cruising at 70 in 5th couldn't get it. How do you get it to activate? were you in b ...
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 34
Like Tree34Likes
Thread: Vcyclenut flash review
  1. #21
    vcyclenut's Avatar
    Member #
    2695
    Join Date
    Jun 2014
    Location
    fort myers, florida
    Posts
    984
    Quote Originally Posted by bambamrl View Post
    were you in b mode??
    put the bike in b mode in 5th gear get to a speed above 70 and let off the gas it will catch it
  2. #22
    Gold Supporting Member bambamrl's Avatar
    Member #
    3308
    Join Date
    Sep 2014
    Location
    NYC, Queens
    Posts
    187
    ahh ok B mode, will try that.
  3. #23
    Senior Member Bob_Defly's Avatar
    Member #
    3931
    Join Date
    Dec 2014
    Location
    Oakville, ON, Canada
    Posts
    392
    Thread revival!
    So I have a vcyclenut flash on my 2014 with a full Hindle system. I can't remember which options I selected for the O2 sensor, the AIS, and the injector decel cut (although probably all yes/disable), but my bike pops and burbles like crazy, to the point that it's embarrassing. Most of the time it's a pretty loud burble, but every so often it's a full on back fire/explosion which is really loud. Not sure what to do about it, it tends to happen more in colder weather. It seems to have gotten worse over time. Any suggestions? David?
  4. Remove Advertisements
    FZ09.org
    Advertisements
  5. #24
    vcyclenut's Avatar
    Member #
    2695
    Join Date
    Jun 2014
    Location
    fort myers, florida
    Posts
    984
    Quote Originally Posted by Bob_Defly View Post
    Thread revival!
    do you have block off plates??
    the flash just disables the AIS and can still leak, if it is popping you have air getting into the exhaust,
    usually through the ais system, ive seen lots of plates installed and leak so be sure they are installed correctly
    marthy likes this.
  6. #25
    Supporting Vendor marthy's Avatar
    Member #
    513
    Join Date
    Oct 2013
    Location
    Jupiter, FL
    Posts
    3,067
    Cap off the hose on the airbox... quick fix. Install some block off plates next time you're due for spark plugs.
    Crossbar1773 and Camp49 like this.
  7. #26
    Senior Member veebooster's Avatar
    Member #
    1313
    Join Date
    Feb 2014
    Location
    Niagara Falls, Ontario
    Posts
    152
    I've got the hindle with vcyclenut flash as well. A little bit of burbling on decel but never any pops. I installed block off plates though.
    vcyclenut likes this.
  8. #27
    Member Spellicy's Avatar
    Member #
    38814
    Join Date
    Oct 2018
    Location
    NY
    Posts
    37
    mpg
    Quote Originally Posted by veebooster View Post
    Curious, how is fuel econemy vs stock exhaust/flash? im getting the flash from him either way... hes been super at responding to me everytime i ask anything.
  9. #28
    Senior Member dcpppf's Avatar
    Member #
    2879
    Join Date
    Jul 2014
    Location
    KC, KS/MO
    Posts
    839
    Dave's great. I had zero change in fuel economy (if memory serves me right that is). Always hovered between 40 and 42 mpgs.
    shamrock, vcyclenut and VERSYS8 like this.
    Mods: under seat USB charger, complete OES slider/spool set, evotech rad guard, yoshimura FE, barracuda freccia turn signals (front and back), ASV shorty levers (black w/ gold adjusters), puig dark tinted sport screen, APE CCT, Tripage LED Pegs, Ohlin's rear shock, Akra Ti, gold/smoked stainless brake lines (front and back), PowerMadd hand guards
  10. #29
    vcyclenut's Avatar
    Member #
    2695
    Join Date
    Jun 2014
    Location
    fort myers, florida
    Posts
    984
    Quote Originally Posted by Spellicy View Post
    fuel economy is not a parameter I look at when developing a flash. I set the fuel where it needs to be for best performance and throttle response. As many people have shown though a well tuned bike is still an efficient bike and will still get similar fuel mileage depending on the riding conditions.
  11. #30
    Junior Member Badwrench's Avatar
    Member #
    39144
    Join Date
    Dec 2018
    Posts
    8
    Just got my ECU back and installed, so stoked! I went with the recommended settings and have it start in standard. Combined with a Dominator slip on, my bike is so much more alive. The horrible open/close/open jerkiness is gone and replaced with a nice smooth pull. Still some small popping on decel at lower rpm, but I still have the ais installed (even though it is disabled). Plates coming soon.
    Thank you Dave.
    PaulNYC and vcyclenut like this.
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Vcyclenut Flash = All Smiles
    By Hawkerjet in forum Vendor Reviews / Links
    Last Post: 07-16-2015, 10:11 PM
  2. Vcyclenut flash warning!!!!!
    By gearsmasher in forum FZ-09 Performance & Suspension
    Last Post: 10-20-2014, 06:15 PM
  3. Vcyclenut vs Flash Tune Inc
    By Weedstar in forum FZ-09 Performance & Suspension
    Last Post: 10-08-2014, 05:46 AM
  4. An endorsment for VCYCLENUT flash!
    By threesvts in forum FZ-09 Performance & Suspension
    Last Post: 10-04-2014, 06:52 PM
  5. Completing the Trifecta - vcyclenut Flash Initial Review
    By weaponzero in forum Flashed by VCycleNut
    Last Post: 09-05-2014, 11:15 PM
Search tags for this page
ebay v-cyclenut flash
fz 09 vcyclenut review
fz09 ecu reflash by vcyclenut
fz09 vcyclenut flash review
reviews for vcyclenut
throttle map
v cycle nut flash review
vcycle nut flash review
vcyclenut
vcyclenut flash
vcyclenut flash fz09
vcyclenut review
vcyclenut reviews
