FZ-07 Fuel tank capacity proof
Close
Login to Your Account
This is a discussion on FZ-07 Fuel tank capacity proof within the FZ-07 Forum forums, part of the Yamaha FZ-07 category; I was browsing a Euro MT-07 forum...and an owner actually removed the gas tank and drained it dry. He then bought a measuring device to ...
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Like Tree20Likes
Thread: FZ-07 Fuel tank capacity proof
  1. #1
    Senior Member CD599's Avatar
    Member #
    576
    Join Date
    Nov 2013
    Posts
    2,155
    I was browsing a Euro MT-07 forum...and an owner actually removed the gas tank and drained it dry. He then bought a measuring device to measure liters...and filled the tank to the top. It took exactly 13 liters...or 3.43 gallons of gas. Yamaha advertises 3.7 gallon gas tank capacity. Just goes to show you how much these manufactures LIE about everything. Don't ever believe the advertised weight....horsepower... torque....or tank capacity on any new motorcycle. It's always bullshit.
    Just thought I would share.
    ridetofish likes this.
    2015 FZ07 Mods > Traxxion Dynamics AK20's with 8.5k springs.....Traxxion Dynamics revalved and resprung stock shock...Evotech Rad guard..Evotech rear axle sliders...Evotech front axle sliders ...Rizoma frame sliders....Arrow Thunder exhaust .... EJK fuel controller.........Bridgestone BT 016 Pro tires...Givi windscreen...Driven hand grips....Emgo turn signals.....Radial master cylinder....Speigler braided steel brake lines....EBC V pads rear....EBC HH Pads front....Nelson Rigg tailbag.
  2. #2
    Member #
    131
    Join Date
    Jul 2013
    Location
    Merced, CA
    Posts
    2,330
    Most of the press releases are marketing data and not actual specifications of the bike.
    I recall a motorcycle magazine that dug through the marketing data for a selected motorcycle and found the torque and HP data was "slightly off" by how the mfr calculated it to compensate for temperature, humidity, elevation and so forth and then further investigation revealed that the HP data was taken from the rear wheel on the dedicated test machine (read optimized or hopped up for testing purposes) and the resulting HP data was "adjusted" for "projected driveline losses" where an estimated amount of power was added back on so the mfr could claim HP/torque* where the "*" referred to "corrected HP at the crankshaft" in small print at the bottom of the marketing print ad.
    As I recall the actual rear wheel HP that was actually detected by several different magazines was off by more than 25% of the mfr's claimed HP...
    CD599 likes this.
  3. #3
    Supporting Vendor Stoltec Moto's Avatar
    Member #
    65
    Join Date
    Jun 2013
    Location
    Bangor, PA
    Posts
    3,288
    Convenient that it was off by a full, even liter.
    For all we know, some engineer just gave the internal volume of the tank right from the CAD system without accounting for the fuel pump volume...or the expansion volume that remains inaccessible without modifying the filler neck.
    Either way, good information.
  4. Remove Advertisements
    FZ09.org
    Advertisements
  5. #4
    Senior Member DNFDOUG's Avatar
    Member #
    235
    Join Date
    Aug 2013
    Location
    Music City, Ten-er-c
    Posts
    4,424
    Who cares.
  6. #5
    Member #
    576
    Join Date
    Nov 2013
    Posts
    2,155
    Quote Originally Posted by DNFDOUG View Post
    Who cares.
    No .. 'who' is on first. I can't figure out 'what's' on second.
    DNFDOUG and JohnnyC4 like this.
  7. #6
    Member #
    235
    Join Date
    Aug 2013
    Location
    Posts
    4,424
    I make comments like that to see who can appreciate sarcasm and who is dead serious. You passed this time, but I am still keeping you on a short leash.
    Rocky_MTN_FZ09 and valvestem like this.
  8. #7
    Senior Member Rocky_MTN_FZ09's Avatar
    Member #
    3317
    Join Date
    Sep 2014
    Location
    Calgary, AB Canada
    Posts
    4,441
    I wouldn't trust one guys test results without more information, and knowing how accurate his measuring device was? Did the guy use an proper volumetric measuring instruments or a cheap measuring cup he picked up at Ikea???
    Plus fuel volume is effected by ambient temperature. If he measured the volume on a hot day that will effect his "test" results.
    Metric table:
    https://www.ic.gc.ca/eic/site/mc-mc....g/lm00129.html
    And does he live in a Country that has emission standads that require something like the California Evap Canister? and did he really get every drop out of the tank before he filled it? or was some fuel still left in reserve?
    Desert Rat likes this.
    Ride to work, work to ride.
  9. #8
    Member #
    576
    Join Date
    Nov 2013
    Posts
    2,155
    Quote Originally Posted by Rocky_MTN_FZ09 View Post
    Metric table:
    This guys test just confirmed what all of us FZ07 owners already knew. You can't get 3.7 gallons of gas in the tank no matter what country you live in. And yes...I said his tank was off the bike...upside down...and drained BONE dry.
    You can't be serious about ambient temperature. There is no way possible that temperature would make a 3/10ths of a gallon difference. Thanks for the laugh.
  10. #9
    Senior Member PAULIBIKER's Avatar
    Member #
    38
    Join Date
    Jun 2013
    Location
    Ankeny, Iowa
    Posts
    122
    Hmmmmmmmmmmmm..........I've put 3.4XX gal at fill up a couple times.
    Maybe I only had what's in the lines left?!
    I know my Honda 919 was right "on the money" as advertised.
  11. #10
    Supporting Member
    ridetofish's Avatar
    Member #
    1195
    Join Date
    Feb 2014
    Location
    North Georgia
    Posts
    3,902
    Quote Originally Posted by PAULIBIKER View Post
    This is about the capacity of the FZ07.
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. WTB Fuel Tank
    By molon5labe in forum Parts for Sale / Wanted
    Last Post: 07-23-2015, 03:30 PM
  2. Replies: 109
    Last Post: 07-07-2015, 09:40 PM
  3. Fuel tank cap
    By blackclu in forum FZ-09 General Discussion
    Last Post: 05-28-2014, 06:24 PM
  4. Fuel Tank Mod
    By Hawkerjet in forum FZ-09 General Discussion
    Last Post: 03-03-2014, 09:40 PM
  5. Fuel tank mods
    By Janx101 in forum FZ-09 Builds
    Last Post: 10-29-2013, 09:26 PM
Search tags for this page
2017 yamaha fz-07 fuel tank size
fz 07 fuel range
fz 07 fuel tank size
fz 07 gas tank
fz 07 tank size
fz feul tank capecity
fz tank capacity
fz07 fuel leak
fz07 range
fz07 tank capacity
fz07 tank size
fz09 fuel tank capacity
mt 07 fuel tank
tank volume of fz
