Engine Warning light on
Close
Login to Your Account
This is a discussion on Engine Warning light on within the MT-09 Forum forums, part of the Yamaha MT-09 category; Hi. I have done a chain cleaning and chain lube excercise. Started bike after lube excercise while on main stand and run in 1st gear ...
Results 1 to 7 of 7
Thread: Engine Warning light on
  1. #1
    Junior Member Johan's Avatar
    Member #
    39534
    Join Date
    Feb 2019
    Posts
    2
    Hi. I have done a chain cleaning and chain lube excercise. Started bike after lube excercise while on main stand and run in 1st gear at idle speed to ensure proper lubrication. Then engine warning light came on. Switch off and waited for 15 minutes but engine warning lights stays on...??? Is it still save to ride to dealership and why did they light came on...could it because the back wheel was turning and front wheel was stationary and ECU detected a difference in wheel speed rotation. Please help!!!
  2. #2
    Senior Member Steve H's Avatar
    Member #
    14834
    Join Date
    Nov 2016
    Location
    Perth WA
    Posts
    662
    ABS/Traction control?? What exacly is the light that has come on?
    Smoke me a kipper I'll be home in time for breakfast
  3. #3
    Member #
    39534
    Join Date
    Feb 2019
    Posts
    2
    The engine warning light came on after chain lube done and running bike in 1st gear on main stand at idle speed. Engine warning light lit up and stays on....
  4. Remove Advertisements
    FZ09.org
    Advertisements
  5. #4
    Member #
    14834
    Join Date
    Nov 2016
    Location
    Perth WA
    Posts
    662
    I would say it is either something that will clear once you are riding or, if it stays on ride to the dealer and let them sort it out...what year is it and is it under warrenty?
  6. #5
    Senior Member Da Braddah's Avatar
    Member #
    1500
    Join Date
    Mar 2014
    Location
    The 808
    Posts
    1,365
    A better question might be...why are you running it in gear while on the stand? Seems unnecessarily dangerous...
  7. #6
    Member saksittb's Avatar
    Member #
    18873
    Join Date
    Mar 2017
    Location
    San Antonio TX
    Posts
    33
    The speed sensor and or traction control system is thrown off because the weight of the rear wheel was on a stand vs the ground. You can clear this code with the proper scan tools.
  8. #7
    Member Chinook's Avatar
    Member #
    38996
    Join Date
    Nov 2018
    Location
    Bakersfield, California
    Posts
    58
    TCS definitely said What? If it doesn't go away after shutting down then restarting, disconnect the battery for 5 minutes then reconnect then test again. Won't hurt anything and it may clear it. I'm not sure how the codes work on this bike yet but it should clear it. Guess I could reproduce the problem and see if this works.
    Hang on... we'll see.
    Just ran it on the stand for about 45 seconds. Within the first seconds the TCS (amber) light comes on for a few seconds then turns off then nothing else. No engine light for me. How long did you run that way before the engine light came on?
    PS. The TCS disables itself in this situation.
    2018 Yamaha MT-09
    1986 Yamaha Virago 1100 Special Edition
    2008 Yamaha YZ 450Fcc
    2006 Yamaha YZ 250cc
    2002 Yamaha YZ 250cc
    You don't quit riding because you get old - You get old because you quit riding...
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Clear Check Engine Light (Ghost Check Engine)
    By clubtc05 in forum XSR900 General Discussion
    Last Post: 11-26-2016, 04:05 PM
  2. low fuel warning light
    By dorset xsr rider in forum XSR900 General Discussion
    Last Post: 10-15-2016, 03:45 PM
  3. TCS Warning Light
    By XSR-900 in forum XSR900 Common Problems/Issues
    Last Post: 09-01-2016, 06:42 AM
  4. Oil light warning periodically?
    By Red Rocket in forum FZ-09 General Discussion
    Last Post: 04-23-2015, 10:34 PM
  5. Occasional Oil-light warning after changing to Yamalube non-synthetic
    By Red Rocket in forum Yamaha FZ-09 Common Problems/Issues
    Last Post: 07-06-2014, 09:05 PM
