Flexible clutch cable ???
Close
Login to Your Account
This is a discussion on Flexible clutch cable ??? within the MT-09 Forum forums, part of the Yamaha MT-09 category; Is there any clutch cable from another Yamaha model, without the bended steel tube, at the handlebar that will fit the MT09 ? I have ...
Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By Newbie
Thread: Flexible clutch cable ???
  1. #1
    Junior Member Newbie's Avatar
    Member #
    30121
    Join Date
    Nov 2017
    Location
    Europe
    Posts
    21
    Question Flexible clutch cable ???
    I have mounted a lower handlebar, but i also want to lower the 'risers' (or what they are called), but then i will run into problems.
    Is it possible to bend the tube on the original clutch cable ?
    Scox9315 likes this.
  2. #2
    Senior Member wayne-o's Avatar
    Member #
    512
    Join Date
    Oct 2013
    Location
    Chicago
    Posts
    419
    Lower bars ate my clutch cable in 100 miles or so. People used the FJ09 cable but then it was changed I believe. Other people routed the cable in front of the throttle bodies.
    This spring Ill reinstall my clip on's and try a FZ1 cable.
    The Urban Ballet with millimeters to spare.
  3. #3
    Member #
    30121
    Join Date
    Nov 2017
    Location
    Europe
    Posts
    21
    Hi Wayne.
    Did the cable snap because you modified the steel tube in the handle bar end ?
    Or just because it was not proper aligned..?
  4. Remove Advertisements
    FZ09.org
    Advertisements
  5. #4
    Senior Member thrstrmech's Avatar
    Member #
    5326
    Join Date
    Jun 2015
    Location
    Peoria, AZ
    Posts
    1,990
    clutch cable design from what I've seen between the first and second gen '09's went from ok to wtf? lowest bars you can install on the '09 are the Rizoma drag bar, lower risers will not work due to the tank design and space issue between the left hand control housing and the tank, period! you can install the XSR clubmans onto the '09 using the FJ clutch cable routed via the stock location, I did it on a '17. you can use the stock cable routed via the throttle bodies, ie. #1 & #2 which work with the Rizoma drag bar and Buell clubmans, did that too on my '15. the FJ cable is best for lower bars, Rizoma drag bar and both XSR and Buell clubmans.
  6. #5
    Member #
    5326
    Join Date
    Jun 2015
    Location
    Peoria, AZ
    Posts
    1,990
    Rizoma drag bar with stock clutch cable
  7. #6
    Member #
    512
    Join Date
    Oct 2013
    Location
    Chicago
    Posts
    419
    I would say alignment as I did not modify anything.
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Issue: Clip ons Clutch cable / New design of FJ09 cable
    By JSP in forum FZ-09 General Discussion
    Last Post: 08-08-2018, 04:28 PM
  2. Clutch Cable Fail
    By Tetrec in forum Yamaha FZ-09 Common Problems/Issues
    Last Post: 09-04-2014, 02:59 PM
  3. Having Trouble tightening up my clutch cable
    By kkilmore89 in forum FZ-09 Performance & Suspension
    Last Post: 06-20-2014, 08:05 PM
  4. Squeaky Clutch Cable - no biggie
    By RichBinAZ in forum Yamaha FZ-09 Common Problems/Issues
    Last Post: 10-17-2013, 07:06 PM
