Oil feed to clutch basket and plates problem...
Close
Login to Your Account
This is a discussion on Oil feed to clutch basket and plates problem... within the MT-09 Forum forums, part of the Yamaha MT-09 category; Good morning all, ok im sure this has been covered plenty can some one possibly explain how the clutch and clutch plates get oil?It does ...
Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Like Tree6Likes
Thread: Oil feed to clutch basket and plates problem...
  1. #1
    Junior Member Caylib's Avatar
    Member #
    36113
    Join Date
    May 2018
    Posts
    7
    Good morning all, ok im sure this has been covered plenty can some one possibly explain how the clutch and clutch plates get oil?It does not come from it been submerged in oil basket sits way to high, next there is no oil feed hole at tip of gearbox clutch drive shaft, like on some other model bikes that get oil from gearbox that runs inside shaft and out to basket.... Reason is this is my 2nd clutch basket with a crack, before any one asks its a Mt09 they wheelie off throttle LOL as every one here knows' so yes i do wheelie every now and then....BUT on inspection i have found plates to be dry i mean dry dry one or two spots here and there.
    Which leads me to believe there is a lack of oil to some units that have been sold' ive been covering the internet and have come across alot of feeds,posts, so on regarding this issue of snapped plates and cracked or broken baskets...
    Any info would be awesome.. Thank you
  2. #2
    Senior Member dcpppf's Avatar
    Member #
    2879
    Join Date
    Jul 2014
    Location
    KC, KS/MO
    Posts
    799
    sub'd
    Mods: under seat USB charger, complete OES slider/spool set, evotech rad guard, yoshimura FE, barracuda freccia turn signals (front and back), ASV shorty levers (black w/ gold adjusters), puig dark tinted sport screen, APE CCT, Tripage LED Pegs, Ohlin's rear shock, Akra Ti, gold/smoked stainless brake lines (front and back), PowerMadd hand guards
  3. #3
    Senior Member Cw09's Avatar
    Member #
    6723
    Join Date
    Feb 2016
    Location
    North Central Florida
    Posts
    562
    OK if there's,an oil shortage your friction plates are probably glazed and your steels are probably blued , which I doubt,an easier theory to prove would be the basket is junk so it breaks
  4. Remove Advertisements
    FZ09.org
    Advertisements
  5. #4
    Member #
    36113
    Join Date
    May 2018
    Posts
    7
    Yeah possible on the basket as the MT is a budget bike, and i dont mean that in an ugly way... My plates are ok just no oil, in between the carbon on the plate it has a slight blue color, steel plate you wont believe me not blue at all so im kinda lost,, when i removed everything i noticed hardly any oil inside the basket or on the basket so on.... So how the hell does oil get into the basket and onto plates? I guess its a mystery this 1 of mine.
  6. #5
    Senior Member abe57's Avatar
    Member #
    3833
    Join Date
    Nov 2014
    Location
    Columbus,IN
    Posts
    2,449
    It covers it in the service manual. Shows the oil gallery's but right off hand I don't remember but the passages are there! Next time at a Yamaha shop as the service manager if you could take a peek at it ... that is if you don't own one ...when I installed my slipper clutch I will say it's not dripping wet like I have seen on other bikes !
    Caylib likes this.
    King-Of-Bee's
  7. #6
    Senior Member Steve H's Avatar
    Member #
    14834
    Join Date
    Nov 2016
    Location
    Perth WA
    Posts
    660
    I would suggest this system is for two reasons....the bike will accelerate faster without a fully immeresed clutch and the clutch is mounted fairly high so a full oil bath would need a fair bit of oil....my 2cts worth anyway...and for what it is worth I would suspect the lack of sufficient oil is the main reason for so many failures....dont forget when you wheelie the oil gallery may end up being starved of oil. Maybe a coating of oil before the clutch is re-assembled?
    Caylib likes this.
    Smoke me a kipper I'll be home in time for breakfast
  8. #7
    Member #
    6723
    Join Date
    Feb 2016
    Location
    Posts
    562
    I'm not an engineer so I can't tell you if there's a oil issue ,I can tell you if you upgrade the basket and the plates there's no more oil issue.....
    Caylib likes this.
  9. #8
    Member #
    3833
    Join Date
    Nov 2014
    Location
    Columbus,IN
    Posts
    2,449
    Quote Originally Posted by Cw09 View Post
    If you are talking about replacing the the basket with a new factory one it is the same there has been no upgrade to it the part number is the same from though out all the years !
    Caylib likes this.
    King-Of-Bee's
  10. #9
    Member #
    6723
    Join Date
    Feb 2016
    Location
    Posts
    562
    Quote Originally Posted by abe57 View Post
    No I'm talking about upgrading to the extreme basket and Barnett's plates
  11. #10
    Member #
    14834
    Join Date
    Nov 2016
    Location
    Perth WA
    Posts
    660
    The better clutch can probably withstand a harder life
    Caylib likes this.
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Broken clutch basket?plates?
    By Cw09 in forum Yamaha FZ-09 Common Problems/Issues
    Last Post: 09-21-2017, 04:00 AM
  2. (Barnett) Billet Clutch Basket
    By Empty09 in forum FZ-09 General Discussion
    Last Post: 12-18-2016, 08:19 AM
  3. brock davidson on fz09 clutch basket issues
    By krisfz in forum Yamaha FZ-09 Common Problems/Issues
    Last Post: 11-30-2016, 09:08 PM
  4. 12voltg accessory feed
    By jvalus in forum FZ-09 General Discussion
    Last Post: 09-20-2016, 07:42 PM
  5. Noisy clutch basket
    By JEAN-ROCH in forum FZ-09 General Discussion
    Last Post: 09-30-2015, 12:16 PM
