Oil feed to clutch basket and plates problem... - Page 2
Close
Login to Your Account
This is a discussion on Oil feed to clutch basket and plates problem... within the MT-09 Forum forums, part of the Yamaha MT-09 category; Ok guys so i took a look at the manual the oil looks like it feeds down the main axel, does not use a drain ...
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Like Tree6Likes
Thread: Oil feed to clutch basket and plates problem...
  1. #11
    Junior Member Caylib's Avatar
    Member #
    36113
    Join Date
    May 2018
    Posts
    7
    Ok guys so i took a look at the manual the oil looks like it feeds down the main axel, does not use a drain hole at the tip but filters into the casings and some how gets dropped into the basket how the Hell? sorry about the crappy pics but would'nt the oil just be flung off? i will check for any blockagesIMG_20181015_174441.jpg
  2. #12
    Senior Member Truckinduc's Avatar
    Member #
    2862
    Join Date
    Jul 2014
    Posts
    130
    That's how. Oil feeds the bearing and goes outwards through the hub, then plates and then out the basket fingers.
  3. #13
    Member #
    2862
    Join Date
    Jul 2014
    Posts
    130
    dcpppf likes this.
  4. Remove Advertisements
    FZ09.org
    Advertisements
  5. #14
    Senior Member Steve H's Avatar
    Member #
    14834
    Join Date
    Nov 2016
    Location
    Perth WA
    Posts
    662
    That seems to be a good supply....I wonder is some bikes suffer from debris blocking it....maybe some left over manufacturing crap within the galleries somewhere? Yamaha certainly wouldnt want to admit their manufacturing process has a problem....more like.... fix it and deny all knowledge, seems to be the way today.
    Smoke me a kipper I'll be home in time for breakfast
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Broken clutch basket?plates?
    By Cw09 in forum Yamaha FZ-09 Common Problems/Issues
    Last Post: 09-21-2017, 04:00 AM
  2. (Barnett) Billet Clutch Basket
    By Empty09 in forum FZ-09 General Discussion
    Last Post: 12-18-2016, 08:19 AM
  3. brock davidson on fz09 clutch basket issues
    By krisfz in forum Yamaha FZ-09 Common Problems/Issues
    Last Post: 11-30-2016, 09:08 PM
  4. 12voltg accessory feed
    By jvalus in forum FZ-09 General Discussion
    Last Post: 09-20-2016, 07:42 PM
  5. Noisy clutch basket
    By JEAN-ROCH in forum FZ-09 General Discussion
    Last Post: 09-30-2015, 12:16 PM
