MT09 2016 ABS + TCS Diagnostic's
Close
Login to Your Account
This is a discussion on MT09 2016 ABS + TCS Diagnostic's within the MT-09 Forum forums, part of the Yamaha MT-09 category; I have mangaged to get into the bikes ECU diagnostic's to read & clear faults on my 2016 MT09 ABS + TCS using an OBD2 ...
Page 1 of 8 123 ... LastLast
Results 1 to 10 of 78
Like Tree16Likes
Thread: MT09 2016 ABS + TCS Diagnostic's
  1. #1
    Senior Member kevxtx's Avatar
    Member #
    719
    Join Date
    Nov 2013
    Location
    Brisbane Australia
    Posts
    599
    I have mangaged to get into the bikes ECU diagnostic's to read & clear faults on my 2016 MT09 ABS + TCS using an OBD2 diagnosic's reader, I will post full details this evening.
    Anyone with a XSR900 in Brisbane so I can plug into your Diagnostic's for testing, otherwise I will pop past my dealer & check on their demo?
    2018 MT09SP: Full Woolich Race tools & tune, up/down QS, launch control, pit lane limiter, Shorty clutch lever, Protaper bars, Lithium iron battery, steering damper, Titanium bolts & nuts everywhere, Akra Carbon, R1 front 320mm wave brake rotors, full set Hell brake lines, MT07 Wave rear rotor, R1 tail tidy with 2016 rear axle, R1 indicators, modified ABS rings.
  2. #2
    Junior Member Tuddu's Avatar
    Member #
    9882
    Join Date
    Aug 2016
    Posts
    23
    Ciao Kev, I have the same model as ya and I just ordered my harness a couple od days ago.
    As soon as I receive 'em I' ll test my obd/wifi interface and which (Android) software works for me and report back to you.
    Inviato dal mio HUAWEI MT7-L09 utilizzando Tapatalk
  3. #3
    Member #
    719
    Join Date
    Nov 2013
    Location
    Brisbane Australia
    Posts
    599
    Quote Originally Posted by Tuddu View Post
    I made up my own OBD2 to Yamaha connector with the help from Raydiehtor giving me the pin layout.
    I used this software http://www.ross-tech.com/vcds/tour/obd-2.html
    And this cable, http://www.ross-tech.com/vag-com/hex-usb+can.php
    I do have the OEM version of VAGCOM but they can be bought here. http://www.aliexpress.com/item/VAG-1...4-80d7ff025003
  4. Remove Advertisements
    FZ09.org
    Advertisements
  5. #4
    Member #
    719
    Join Date
    Nov 2013
    Location
    Brisbane Australia
    Posts
    599
    I tested a few OBD testers today & these two work so far.
    Make sure you twist the two can wires together if you make your own harness
    VAGCOM OBD2 Protocol
  6. #5
    Member #
    719
    Join Date
    Nov 2013
    Location
    Brisbane Australia
    Posts
    599
    Hand held scanner:
  7. #6
    Senior Member raydeightor's Avatar
    Member #
    6571
    Join Date
    Jan 2016
    Location
    Pennsyltucky
    Posts
    182
    Thanks for doing the legwork on the scanners Kev. Odd that it's one of the VW/Audi scanners that worked for you on a Japanese motorcycle with a Japanese ECU. Just ordered the Creader V off Amazon. Thought I'd probably get more use out of that since since there are no VW products in my fleet. When I die my kids won't get a whole lot of money but they will inherit a sweet collection of code scanners.
  8. #7
    Member #
    719
    Join Date
    Nov 2013
    Location
    Brisbane Australia
    Posts
    599
    Quote Originally Posted by raydeightor View Post
    No worries a bit help from each other goes a long way, I also ordered in another one off the link I sent you on Sunday off EBay the same model that FTECU recommends for the 2016 ZX10R with their Diag cable, I will try & pop over to the dealer on Saturday & do some tests on the XSR & MT10 to see if we can get into their diagnostic's.
  9. #8
    Member #
    6571
    Join Date
    Jan 2016
    Location
    Pennsyltucky
    Posts
    182
    Just got the Creader, same model that Kev used on his MT/FZ-09 above and it doesn't read my XSR ECU, "communication error". While attempting to connect it lists all the protocols it is trying, includes "CAN" and a bunch of others. No dice. I'm thinking the XSR is either using an unusual/non-standard protocol (or obscure variant thereof) or my specific ECU just doesn't want to talk to anybody. My ECU is flashed and the CEL light is lit. Maybe the error the CEL is indicating on relates to the ECUs inability to communicate? In other words, somehow related.
    Kev - let us know how your tests go with the XSR and MT10.
  10. #9
    Member #
    719
    Join Date
    Nov 2013
    Location
    Brisbane Australia
    Posts
    599
    That is a strange one, one would think they would use the same protocol for the newer bikes, I will try & get to my dealer on Saturday & let you know. Have you tried the scanner with the bike running?
  11. #10
    Member #
    6571
    Join Date
    Jan 2016
    Location
    Pennsyltucky
    Posts
    182
    Yup, tried with not running and running, no good.
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Yamaha Diagnostic tool
    By kevxtx in forum Parts for Sale / Wanted
    Last Post: 12-01-2017, 02:46 AM
  2. Diagnostic codes
    By DECON BLUE in forum Yamaha FZ-09 Common Problems/Issues
    Last Post: 03-31-2017, 04:04 AM
  3. TCS Light on dash
    By BlueR32 in forum XSR900 General Discussion
    Last Post: 08-31-2016, 11:34 AM
  4. Self Diagnostic code 19?
    By Speedbird in forum Yamaha FZ-09 Common Problems/Issues
    Last Post: 06-02-2015, 07:03 PM
Search tags for this page
2016 yamaha mt09 abs diagnostic
mt 09 diagnostic function not working
mt 09 diagnostic port
mt-09 odb2
mt09 fault codes
mt09 obd2 port
obd2 p1ef0
odb2 per mt09 2016
p2195 mt-09
read fault codes yamaha mt09
xsr700 diagnostic pinout
yamaha diagnosis code p1ef5
yamaha mt 09 reset management light
yamaha mt9 2015 fault code list
