MT09 2016 ABS + TCS Diagnostic's - Page 8
Close
Login to Your Account
This is a discussion on MT09 2016 ABS + TCS Diagnostic's within the MT-09 Forum forums, part of the Yamaha MT-09 category; Attached is my pic when I did my own OBD dongle......
Page 8 of 8 FirstFirst ... 678
Results 71 to 75 of 75
Like Tree14Likes
Thread: MT09 2016 ABS + TCS Diagnostic's
  1. #71
    Member Tenchi's Avatar
    Member #
    7296
    Join Date
    Apr 2016
    Location
    Philippines
    Posts
    42
    Mauro_Octaviano likes this.
  2. #72
    Iva
    Iva is offline
    Junior Member Iva's Avatar
    Member #
    39146
    Join Date
    Dec 2018
    Posts
    2
    hi guys I having a problem also with FTECU with EU 2016 MT09 with ECU 2DR-8591A-40. I have activetuned with o2 sensor, I flashed the bike with activetuned but I get error code P0030. I use ODB2 scanner but can´t erase the code... I send a ticket to them, they add option "disable AIS valve" so I can get proper reading with new o2 sensor, but I dont have the option disable closed loop or diagnostic option.... I still waitting... they said the need an ECU 2DR-8591A-40 to test...
    Have anyone had this problem? I bought the o2 sensor (activetuned) so I can make my on maps with best A/R fuel target´s... and I can´t use...
    Best Regards,
    Iva
  3. #73
    Senior Member kevxtx's Avatar
    Member #
    719
    Join Date
    Nov 2013
    Location
    Brisbane Australia
    Posts
    595
    Quote Originally Posted by Iva View Post
    Best Regards,
    Iva
    Yip FT never fixed the OBD2 port problem on the 2DR-8591A-40 ECU, I gave up in the end & bought Woolich software & have never looked back.
    2018 MT09SP: Full Woolich Race tools & tune, up/down QS, launch control, pit lane limiter, Shorty clutch lever, Protaper bars, Lithium iron battery, steering damper, Titanium bolts & nuts everywhere, Akra Carbon, R1 front 320mm wave brake rotors, full set Hell brake lines, MT07 Wave rear rotor, R1 tail tidy with 2016 rear axle, R1 indicators, modified ABS rings.
  4. Remove Advertisements
    FZ09.org
    Advertisements
  5. #74
    Iva
    Iva is offline
    Member #
    39146
    Join Date
    Dec 2018
    Posts
    2
    I managed with ftecu today to add disable ais valve and add diagnostic tool. Now I can erased codes. I am current using active tuned with the new o2 sensor!!! No error codes, making my fuel maps xD
  6. #75
    Member #
    719
    Join Date
    Nov 2013
    Location
    Brisbane Australia
    Posts
    595
    Good news I gave up in 2016 after months of emails back & forwards.
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Yamaha Diagnostic tool
    By kevxtx in forum Parts for Sale / Wanted
    Last Post: 12-01-2017, 02:46 AM
  2. Diagnostic codes
    By DECON BLUE in forum Yamaha FZ-09 Common Problems/Issues
    Last Post: 03-31-2017, 04:04 AM
  3. TCS Light on dash
    By BlueR32 in forum XSR900 General Discussion
    Last Post: 08-31-2016, 11:34 AM
  4. Self Diagnostic code 19?
    By Speedbird in forum Yamaha FZ-09 Common Problems/Issues
    Last Post: 06-02-2015, 07:03 PM
Search tags for this page
2016 yamaha mt09 abs diagnostic
mt 09 diagnostic function not working
mt 09 diagnostic port
mt-09 odb2
mt09 diagnostic codes
mt09 fault codes
obd yamaha mt09
odb2 per mt09 2016
p2195 mt-09
read fault codes yamaha mt09
xsr700 diagnostic pinout
yamaha mt 09 reset management light
yamaha mt09 obd reader
yamaha mt9 2015 fault code list
