Stuttering engine at cruising speeds *** SOLVED *** - Page 3
Close
Login to Your Account
This is a discussion on Stuttering engine at cruising speeds *** SOLVED *** within the Yamaha FZ-09 Common Problems/Issues forums, part of the Yamaha FZ-09 Garage category; Thanks Abe...
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 35
Like Tree29Likes
Thread: Stuttering engine at cruising speeds *** SOLVED ***
  1. #21
    Senior Member JM00JM's Avatar
    Member #
    4990
    Join Date
    Apr 2015
    Posts
    138
    Thanks Abe
    abe57 likes this.
  2. #22
    Junior Member tim.pigeau@gmail.com's Avatar
    Member #
    38782
    Join Date
    Oct 2018
    Location
    Ontario, Canada
    Posts
    5
    JM00JM,
    You do NOT have to remove the airbox to access them. They are on either side of the intake tubes and the airbox does not obstruct you at all. All I do is lift the tank, rotate it and place it where my seat normally is (use a towel or something in between the tank and the bike to prevent scratches). With this method I don't even need to disconnect the fuel lines.
    2thdr and RichBinAZ like this.
    2014 Yamaha FZ-09 (Red): VcycleNut flash, K&N air filter, MRA Double-Bubble windscreen, Kaoko throttle lock
  3. #23
    Member #
    4990
    Join Date
    Apr 2015
    Posts
    138
    Quote Originally Posted by [email protected] View Post
    JM00JM,
    Thanks for the info. I've already done it now and it felt like the airbox needed to move out the way, so I just removed it
  4. Remove Advertisements
    FZ09.org
    Advertisements
  5. #24
    Member #
    4990
    Join Date
    Apr 2015
    Posts
    138
    I'm still not sure exactly which connector is which though
  6. #25
    Senior Member abe57's Avatar
    Member #
    3833
    Join Date
    Nov 2014
    Location
    Columbus,IN
    Posts
    2,477
    Quote Originally Posted by JM00JM View Post
    Look closely at the pic on post #13...anything electrical connected to the throttle body's just remove one at a time clean them up and then apply a bit of dialectic grease " squeeze it into the female part of the connector " and connect it back and move on to the next one ....
    King-Of-Bee's
  7. #26
    Senior Member Rexster's Avatar
    Member #
    1170
    Join Date
    Jan 2014
    Location
    Memphis, TN
    Posts
    233
    I'm gonna try this.....Drives me nuts!!!!!!!!!
    thanks
    ridetofish likes this.
  8. #27
    Member #
    4990
    Join Date
    Apr 2015
    Posts
    138
    I've come to the conclusion that my fuel cut issue was caused by the weather and low temperatures because it's gone now its heated up a bit here. Cant find any other explanation.
  9. #28
    Member #
    38782
    Join Date
    Oct 2018
    Location
    Ontario, Canada
    Posts
    5
    I found that too for a while. The connectors expand in the heat, breaking the airtight seal. When its cold the connectors contract again, trapping moisture. If this is the issue, it will get worse. I've taken to putting some dielectric grease on the seal of the connectors to prevent this. The connectors are on the left and right of the 3 intake tubes of the throttle body. It doesn't hurt to clean out the connector for the throttle actuator as well (on the rear side of the throttle body, a little to the right).
    JM00JM likes this.
  10. #29
    Junior Member Roninracing88's Avatar
    Member #
    38784
    Join Date
    Oct 2018
    Location
    Atlanta, GA
    Posts
    16
    Way to keep with it. Gonna have a look at my 2019 to see if thats whats going on with mine. In Georgia so have serious heat/humidity.
  11. #30
    Senior Member blackfireball5's Avatar
    Member #
    34730
    Join Date
    Apr 2018
    Location
    Cleveland, Ohio
    Posts
    184
    My bike is experiencing these exact symptoms. Gonna inspect these connectors later today. If this is my issue it will have saved me a ton of time.
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Fz09 prolonged cruising speed
    By Projectslowcus in forum FZ-09 General Discussion
    Last Post: 01-22-2015, 09:37 AM
  2. Sena SMH-10 problem solved
    By DNFDOUG in forum Off-Topic
    Last Post: 01-21-2015, 09:53 PM
  3. Bike stuttering and flaming out - SOLVED
    By DNFDOUG in forum FZ-09 Performance & Suspension
    Last Post: 07-25-2014, 08:47 AM
  4. Bike surging/missing at constant speeds?
    By Poogamer69 in forum Yamaha FZ-09 Common Problems/Issues
    Last Post: 02-25-2014, 11:56 PM
Search tags for this page
fz 09 low speed issue
Tags for this Thread
