Valve adjust advice - tighter side of spec
Close
Login to Your Account
This is a discussion on Valve adjust advice - tighter side of spec within the Yamaha FZ-09 Guides and How-To's forums, part of the Yamaha FZ-09 Garage category; So I'm doing my 2nd valve check. First was done at 11k and I'm now at about 31k. I did the first early due to ...
Page 1 of 2 12 LastLast
Results 1 to 10 of 16
Like Tree7Likes
Thread: Valve adjust advice - tighter side of spec
  1. #1
    Senior Member dcpppf's Avatar
    Member #
    2879
    Join Date
    Jul 2014
    Location
    KC, KS/MO
    Posts
    852
    So I'm doing my 2nd valve check. First was done at 11k and I'm now at about 31k. I did the first early due to all of the posts about them getting tight, but maybe I got it done too early and the exhaust valves weren't done moving.
    Regardless I've got three exhaust valves that are a hair tight (0.22mm, 0.24mm, and 0.24mm). I'll re-shim those, but my question is on the intake side. Five out of six are measuring at 0.12 or 0.13... While I'm in there is it worth trying to get those closer to 0.18 or something more in the middle or on the higher side of spec?
    For those curious here are all of the measurements. 2014 with roughly 31,000 miles.
    EX: 0.27, 0.26, 0.22, 0.24, 0.24, 0.28
    IN: 0.12, 0.13, 0.13, 0.14, 0.13, 0.12
    ex spec 0.26-0.30
    in spec 0.11-0.20
    Mods: under seat USB charger, complete OES slider/spool set, evotech rad guard, yoshimura FE, barracuda freccia turn signals (front and back), ASV shorty levers (black w/ gold adjusters), puig dark tinted sport screen, APE CCT, Tripage LED Pegs, Ohlin's rear shock, Akra Ti, gold/smoked stainless brake lines (front and back), PowerMadd hand guards
  2. #2
    Senior Member blkbrd's Avatar
    Member #
    5442
    Join Date
    Jun 2015
    Location
    Midland, ON
    Posts
    1,363
    Me personally...I wouldn't bother. It's within spec.
    dcpppf likes this.
    2015 Matte Grey FZ-09 --- Oxford Heated Grips --- Spiegler S/S Brake lines --- OES Frame Sliders --- OES Front Axle Sliders --- GYTR Rad Guard --- GYTR Windscreen --- Racetech Gold Valves --- Racetech Fork Springs --- ZX6R Rear Shock --- Rizoma Action LED Turn Signals --- Tripage Gold LED Headlamp --- E-Bay Pazzo Knockoff Levers --- Termignoni Carbon Exhaust --- Power Commander 5 --- Yoshimura Fender Eliminator --- Ivan's ECU Flash --- Shad Comfort Seat -- GYTR Quick Shifter
  3. #3
    Member #
    2879
    Join Date
    Jul 2014
    Location
    KC, KS/MO
    Posts
    852
    I'm leaning more towards that too; esp after reading more on the topic this morning. I was under the assumption that valves in general only stretched and so clearances would only ever shrink, but sounds as though things aren't that simple.
    if anyone has some info/links to a good read on the topic I'd be all ears.
  4. Remove Advertisements
    FZ09.org
    Advertisements
  5. #4
    Senior Member LouG's Avatar
    Member #
    5709
    Join Date
    Jul 2015
    Location
    Nelson, New Zealand
    Posts
    4,058
    Inlets aren't prone to burning, so being on the tight side of spec gives you slightly longer valve duration.
    dcpppf likes this.
    '14 MT 09
    Andreanni Cartridge kits
    Nitron Road and Track Shock
    Givi screen
    Renthal McGrath bend Bars.
    V1+YaV1 Licence protector
    SW Motech Quicklock Tankbag.
    Kevxtx O2 Controller.
    Custom Chain Oiler
    El Cheapo Chinese levers.
  6. #5
    Member #
    2879
    Join Date
    Jul 2014
    Location
    KC, KS/MO
    Posts
    852
    Quote Originally Posted by LouG View Post
    And longer duration essentially equates to more air getting sucked in, right? Does the ECU account for this and increase fuel too, or is the mix just a bit leaner? Bit off topic, but I don't know a lot about the capabilities of ECUs in general... carbs are nice and simple.
    I'll probably leave them alone unless someone has good reason not to. Maybe if one was way out of whack I'd try bringing it closer. I found the paperwork from the shop who did the first adjustment and all but one were 0.14 or 0.13mm 20k miles ago. So they've barely moved at all.
    For anyone who may be curious... Here are the numbers from the service back in January 2016 at 11k miles:
    BEFORE
    EX: 0.16, 0.22, 0.17, 0.22, 0.22, 0.23
    IN: 0.14, 0.14, 0.14, 0.16, 0.14, 0.13
    AFTER
    EX: 0.30, 0.27, 0.27, 0.28, 0.27, 0.28
    IN: 0.14, 0.14, 0.14, 0.16, 0.14, 0.13 (no adjustments made)
  7. #6
    Member #
    5709
    Join Date
    Jul 2015
    Location
    Nelson, New Zealand
    Posts
    4,058
    Yes, volumetric efficiency improves, but only very slightly if you're talking about hundredths of a mm less clearance. It's within spec, so the ECU etc copes.
    '14 MT 09
    Givi screen
    Custom Chain Oiler
  8. #7
    Junior Member 9Lives's Avatar
    Member #
    40108
    Join Date
    Apr 2019
    Posts
    10
    Quote Originally Posted by dcpppf View Post
    The valves don't "stretch", they expand slightly when they warm up. The reason you loose clearance is because the valve face wears into the seat. The reason the exhaust valve wear more is because the subject to much higher heat and friction caused by the exhaust gases which have tiny partials of carbon. The intake valves are constantly being cooled and cleaned by the relatively cool intake air and fuel. The exhaust valves loosing more clearance is completely normal, there is always a fudge factor in the manufactures specs. Even if they are near or slightly less than the OEM specs, they have a long way to go before it will cause damage. The initial valve adjustment is the most important, this is the "break in" period for the valve, same idea as the rings breaking into the cylinder walls. As has be documented, once the first adjustment is done, very little wear happens after the break in period.
    Travis and dcpppf like this.
  9. #8
    Junior Member WRXBatman88's Avatar
    Member #
    5924
    Join Date
    Aug 2015
    Location
    Long Beach, CA
    Posts
    9
    Hey guys,
    So, I decided that this job couldn't be that difficult since there were some pretty good forum posts with images and directions and a service manual. I am now at the point where I took all my valve clearance measurements, rotated the crank to the recommended BDC, removed the camshafts and re-shimmed my exhaust valves. I realized that when I removed the camshafts there was some spring back involved because some of the cams were still under some pressure from the loaded valve springs. ( I thought it was strange that they would make you remove the camshafts while there was still spring pressure applied..) Now I am thinking that I did not have the 1st piston at the true BDC. Is there any way to rotate the crank to find BDC while the camshafts and CCT are not installed?
    If you have any ideas I am all ears. Thanks in advance!
    dcpppf likes this.
  10. #9
    Member #
    2879
    Join Date
    Jul 2014
    Location
    KC, KS/MO
    Posts
    852
    Hey man. First of all, there is some slight pressure on (I think) cylinder 3 intake lobe when you're putting the cams back in. Getting the shafts in place and tightening the caps was a struggle for me. I ended up putting the cam chain on the sprockets and putting the tensioner in very loosly (manual tensioner) just to put a bit of pressure on the sprockets to hold them down and keep from spinning on me while tightening the caps. The intake cam kept wanting to spin 1 tooth on me.
    Now to get to your question... I did the EXACT same thing. You can absolutely spin the crank as she sits. Since the CCT and cams are out you need to be very careful while turning the crank that you don't kink the cam chain and get it wedged up in the chain guide area/side of the cylinder. So just hold it fairly taught up top near the valve cover area and spin half an inch or so at a time. When I was doing this my concern was being at BTDC on the "compression" stroke vs the "exhaust" stroke. Cause there is no way to tell with the cams out. After a couple of phone calls, and deciding "welp... I've got no other ideas"... I came to the conclusion that it didn't matter. Buddies convinced me that these modern bikes likely have a cam position sensor (or some such) that'll make sure the spark plug is only firing on the power stroke. So as long as you get that BTDC arrow thing lined up on the crank side without kinking your cam chain... You should be all good to go.
    Hopefully someone else can chime in on why compression vs exhaust stroke doesn't matter because I would like to know more confidently why that is or is not true.
  11. #10
    Senior Member Cw09's Avatar
    Member #
    6723
    Join Date
    Feb 2016
    Location
    North Central Florida
    Posts
    588
    There is no compression or exhaust stroke without the cams ,it's just pistons going up and down....
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Valve spec conspiracy
    By FZ0 in forum FZ-09 General Discussion
    Last Post: 09-27-2016, 02:00 PM
  2. fuel injection- adjust, synchronization
    By dantheman in forum Yamaha FZ-09 Guides and How-To's
    Last Post: 09-07-2016, 09:07 AM
  3. Headlight Adjust ???
    By Croomrider in forum FZ-09 General Discussion
    Last Post: 04-25-2015, 08:57 PM
  4. Adjust the chain slack and align the rear wheel?
    By LMTG in forum FZ-09 General Discussion
    Last Post: 10-21-2014, 06:01 PM
  5. Base model Hyperpro shock - hard to adjust?
    By FZ09inBKK in forum FZ-09 Performance & Suspension
    Last Post: 08-20-2014, 06:22 AM
