Proper shift rod and lever height
Close
Login to Your Account
This is a discussion on Proper shift rod and lever height within the Yamaha FZ-09 Guides and How-To's forums, part of the Yamaha FZ-09 Garage category; I received the Graves motorsports sprocket cover for christmas,nice part btw, and i had to unscrew the shift rod so i could remove to stock ...
Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Like Tree16Likes
Thread: Proper shift rod and lever height
  1. #1
    Senior Member Razzle's Avatar
    Member #
    19
    Join Date
    Jun 2013
    Posts
    224
    I received the Graves motorsports sprocket cover for christmas,nice part btw, and i had to unscrew the shift rod so i could remove to stock plastic cover.
    I should have marked it so i could put it back to stock but i didnt. I am pretty sure i got it close but any feedback or picture of the threads for the proper height would be great!! Just dont want shifting issues this spring if i have it adjusted wrong. Thanks.!
  2. #2
    Senior Member Paul G's Avatar
    Member #
    441
    Join Date
    Oct 2013
    Location
    New Zealand
    Posts
    598
    The lever should be set at what ever height works best for your foot.
  3. #3
    Senior Member cza888's Avatar
    Member #
    3120
    Join Date
    Aug 2014
    Location
    Brampton, Ontario
    Posts
    177
    Hope this helps.
  4. Remove Advertisements
    FZ09.org
    Advertisements
  5. #4
    Supporting Member
    triplethreat's Avatar
    Member #
    23
    Join Date
    Jun 2013
    Location
    "Murvil" TN.......18 miles from Deals Gap
    Posts
    5,583
    And just side note/reminder for anyone else who is going to take something like apart or even do an adjustment. My prodecure is this:
    1. Bike on paddock stands, both front and rear.
    2. Take a measurement from the tip of the shifter (put a piece of tape if necessary and put a mark on the tape), STRAIGHT down to the floor
    3. Write down the measurement of the distance from tip to floor.
    4. Proceed with whatever do are planning to do to the bike's rearset/adjustment rod/etc.
    5. When you are finished, you now have a measurement/reference point to use to get it back where it was originally.
    gearsmasher likes this.
    "If it ain't fast...........It ain't fun"!
    Vern........ Sportbike Track Time Southern Region Lead Intermediate Instructor (Retired)
  6. #5
    Senior Member gunpup's Avatar
    Member #
    3341
    Join Date
    Sep 2014
    Location
    Spokane, WA
    Posts
    228
    Here you go, measured from lock nut to lock nut, 7 15/16". (Please disregard my inability to rotate the photo- my bike is not parked on its handlebar
    Attached Thumbnails Attached Thumbnails Proper shift rod and lever height-image.jpg
    cza888 and MoFZio like this.
  7. #6
    Supporting Member
    Member #
    23
    Join Date
    Jun 2013
    Location
    Posts
    5,583
    Quote Originally Posted by cza888 View Post
    Click image for larger version.
    Hope this helps.
    Mmm........GP shift!
  8. #7
    Member #
    19
    Join Date
    Jun 2013
    Posts
    224
    Quote Originally Posted by Paul G View Post
    I kind of figured that but just wanted to make sure!! thanks for the help and cza888 for the pic!!!
  9. #8
    Member #
    19
    Join Date
    Jun 2013
    Posts
    224
    Quote Originally Posted by gunpup View Post
    here you go, measured from lock nut to lock nut, 7 15/16". (please disregard my inability to rotate the photo- my bike is not parked on its handlebar
    thank you!!!
  10. #9
    Member #
    3120
    Join Date
    Aug 2014
    Location
    Brampton, Ontario
    Posts
    177
    Quote Originally Posted by Razzle View Post
    Just offering up an option
    MoFZio likes this.
  11. #10
    Supporting Member
    Member #
    23
    Join Date
    Jun 2013
    Location
    Posts
    5,583
    Beside changing the OEM tires to the Q3s, figuring out a way to make the FZ GP shift was my first project on the bike. See my write up here.....
    https://www.fz09.org/forum/32-yamaha-...t-pattern.html
    cza888 likes this.
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Headlight Height Adjustment--Measure How High and What Distance from Object?
    By Pseudo-Fed in forum Yamaha FZ-09 Guides and How-To's
    Last Post: 10-06-2014, 01:27 PM
  2. Question about Penske shock and adjustable ride height.
    By Tripleblaze in forum FZ-09 Performance & Suspension
    Last Post: 08-26-2014, 12:02 PM
  3. Best RPM to shift at for BEST MPG
    By ScottySutt15 in forum FZ-09 General Discussion
    Last Post: 04-25-2014, 07:48 AM
  4. Won't up shift
    By drifthunter in forum Yamaha FZ-09 Common Problems/Issues
    Last Post: 04-01-2014, 07:40 PM
  5. Shift Points?
    By Jen in forum FZ-09 General Discussion
    Last Post: 02-25-2014, 09:45 PM
Search tags for this page
fz-09 gp shift
