Tire Pressure Question
Close
Login to Your Account
This is a discussion on Tire Pressure Question within the FZ-09 Wheels & Tires forums, part of the Yamaha FZ-09 Garage category; Hey Guys, so I have been reading some of the past post about tire pressure, and what different people are running. I understand that the ...
Results 1 to 9 of 9
Like Tree5Likes
  • 2 Post By triplethreat
  • 1 Post By dcpppf
  • 2 Post By triple distilled
Thread: Tire Pressure Question
  1. #1
    Member Kawwikid's Avatar
    Member #
    36089
    Join Date
    May 2018
    Posts
    31
    Hey Guys,
    so I have been reading some of the past post about tire pressure, and what different people are running. I understand that the stated tire pressure in the manual and on the swing arm (36 F/42 R), is for max load, way to firm for one up riding. My question is this, I get lowering the tire pressure, and from what I have been playing with, it makes a difference in traction and ride comfort, but when changing tire pressure, should you keep the 6lb air pressure difference between front and rear? Is there a reason that the factory is using that much a difference between front and rear? Does the lower pressure on the front tire help the bike lean a little more forward, keeping more weight on the front tire for better traction? Just some questions I was thinking about and was curious as to what other thought....Thanks Guys...
    Sean
  2. #2
    Senior Member JM00JM's Avatar
    Member #
    4990
    Join Date
    Apr 2015
    Posts
    128
    Because passengers sit on the rear seat?
  3. #3
    Supporting Member
    triplethreat's Avatar
    Member #
    23
    Join Date
    Jun 2013
    Location
    "Murvil" TN.......18 miles from Deals Gap
    Posts
    5,574
    I run 30/30 cold pressure for general riding. And yes, for carrying a passenger or lots of stuff on the rear of the bike is the reason for the 6 lb difference between the front and rear.....if max. PAYLOAD is what you need.
    Moto26 and shamrock like this.
    "If it ain't fast...........It ain't fun"!
    Vern........ Sportbike Track Time Southern Region Lead Intermediate Instructor (Retired)
  4. Remove Advertisements
    FZ09.org
    Advertisements
  5. #4
    Senior Member dcpppf's Avatar
    Member #
    2879
    Join Date
    Jul 2014
    Location
    KC, KS/MO
    Posts
    799
    Sub'd for info... I have just been following the posted pressure on the triple tree since I've had the bike. Curious what others do... Coworker scolded me for running 42 in the rear this past weekend saying that is "wayyyyy too much"...
    shamrock likes this.
    Mods: under seat USB charger, complete OES slider/spool set, evotech rad guard, yoshimura FE, barracuda freccia turn signals (front and back), ASV shorty levers (black w/ gold adjusters), puig dark tinted sport screen, APE CCT, Tripage LED Pegs, Ohlin's rear shock, Akra Ti, gold/smoked stainless brake lines (front and back), PowerMadd hand guards
  6. #5
    Member #
    36089
    Join Date
    May 2018
    Posts
    31
    ok..so now the 6lbs difference makes sense to me...payload....with the suspension work done and new piolet powers on the bike. I have found 32 f 36 rear to be a good ride, but after the reading that i have done on here, im thinking of trying 32/34 or 30/34.....thanks guys
  7. #6
    Member triple distilled's Avatar
    Member #
    39468
    Join Date
    Jan 2019
    Posts
    54
    Just chiming in after playing around with 3 sets of S21s, about 220lbs with gear, listed as cold temps.
    Usually run 32F/34R. For longer road trips, I bump it up a few lbs, 34/36 to get a bit better mileage when I’m not going to be pushing it very hard. At the track, running 28F/29R to get the tires to heat up/ correct psi increase.
  8. #7
    Senior Member LouG's Avatar
    Member #
    5709
    Join Date
    Jul 2015
    Location
    Nelson, New Zealand
    Posts
    3,948
    I'm running 34/36 as per the Michelin recommendations. It feels good.
    '14 MT 09
    Andreanni Cartridge kits
    Nitron Road and Track Shock
    Givi screen
    Renthal McGrath bend Bars.
    V1+YaV1 Licence protector
    SW Motech Quicklock Tankbag.
    Kevxtx O2 Controller.
    Custom Chain Oiler
    El Cheapo Chinese levers.
  9. #8
    Junior Member Frisco's Avatar
    Member #
    39052
    Join Date
    Nov 2018
    Posts
    12
    I run 36/38. Grip is good for street riding and I like the way the tires wear. I’ve got 4500 mi on a set of S21s with some tread left. Not bad for moderately fast riding on mostly twisty local roads.
    CJ
  10. #9
    Member PaulNYC's Avatar
    Member #
    36178
    Join Date
    May 2018
    Location
    New York City
    Posts
    50
    I recommend you call your tire manufacturer, they are very helpful.
    That being said I heard the following for roadSmart 3 tires for my weight 195 in gear.
    2 up: 36/42
    1 up: 36/ 36-38
    Spirited: 34/32
    Track: 32/30
    Sent from my SAMSUNG-SM-G900A using Tapatalk
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Tire Pressure
    By jmcghee41 in forum FZ-09 Wheels & Tires
    Last Post: 02-10-2019, 01:28 PM
  2. Changed rear tire, no rear brake pressure
    By w33ls in forum Yamaha FZ-09 Common Problems/Issues
    Last Post: 10-01-2018, 02:39 PM
  3. Tire pressure on twisties?
    By usersrdum in forum FZ-09 General Discussion
    Last Post: 08-31-2018, 02:12 PM
  4. tire pressure
    By jvalus in forum FZ-09 Wheels & Tires
    Last Post: 05-14-2016, 05:15 PM
  5. Tire air pressure
    By RickyNY in forum FZ-09 Wheels & Tires
    Last Post: 06-18-2015, 09:45 AM
