Max preload front and rear will it harm suspension
Close
Login to Your Account
This is a discussion on Max preload front and rear will it harm suspension within the FZ-09 Performance & Suspension forums, part of the Yamaha FZ-09 Garage category; I just set my bike max preload front and rear and 1/2 turn out front and rear on rebound. Will this effect the life of ...
Page 1 of 2 12 LastLast
Results 1 to 10 of 18
Like Tree14Likes
Thread: Max preload front and rear will it harm suspension
  1. #1
    Senior Member MC357's Avatar
    Member #
    16625
    Join Date
    Jan 2017
    Posts
    450
    Will this effect the life of my suspension being at the extreme max of its adjustment?
    I can't afford new set up for a while. Probably a couple years at least.
    I weigh about 200 lbs.
    Sent from my LG-H900 using Tapatalk
  2. #2
    Senior Member TwoWheelObsession's Avatar
    Member #
    19457
    Join Date
    Mar 2017
    Location
    Holiday, FL
    Posts
    834
    No, but that's no way to setup suspension.
  3. #3
    Senior Member Rocky_MTN_FZ09's Avatar
    Member #
    3317
    Join Date
    Sep 2014
    Location
    Calgary, AB Canada
    Posts
    4,438
    Here are some easy to follow instructions to set your suspension sag, off the RaceTech website. FAQ
    Max preload front and rear will it harm suspension-racetech-sag-settings.jpg
    Setting sag by MC Garage
    MC357 likes this.
    Ride to work, work to ride.
  4. Remove Advertisements
    FZ09.org
    Advertisements
  5. #4
    Senior Member troop's Avatar
    Member #
    6144
    Join Date
    Sep 2015
    Location
    Stoughton, WI
    Posts
    2,509
    No more unnecessary farkles/add ons for you until you save enough to upgrade your suspension . Anyone 200+ # who says their stock suspension works fine probably hasn't ridden an upgraded suspended FZ-09.
    1970 Honda CT70H
    1972 Honda XL250
    1974 Yamaha MX360
    1975 Suzuki TS250
    1979 Honda CB750F
    1983 Kawasaki GPZ550 (A)
    1984 Kawasaki GPZ550 (B)
    1985 Kawasaki GPZ750
    1986 Kawasaki 1000Ninja
    1987 Honda XL600R
    2000 Buell M2 Cyclone
    2000 Kawasaki 1500 Classic FI
    2004 Kawasaki ZRX1200R
    2004 Kawasaki 1600 Meanstreak
    2009 H-D FLHT (current)
    2012 Kawasaki KLR650
    2015 Indian Scout
    2015 Yamaha FZ-09 (sold 1-9-18)
    2016 Triumph Tiger 800 XCxR (current)
  6. #5
    Supporting Vendor pattonme's Avatar
    Member #
    4898
    Join Date
    Apr 2015
    Location
    Northern VA
    Posts
    870
    You can take a reasonable crack at the frontend with $20 in oil and $70 for springs. Or if you can finagle someone to send you some loose shims and a better mid-valve piston you're going to look not too shabby for $120. just bring tools and labor.
    MC357 likes this.
  7. #6
    Member #
    16625
    Join Date
    Jan 2017
    Posts
    450
    I'll have to have a friend help me set the static sag. Thank you for the information and video.
    it seems to be the general consensus I need springs.
    I just have a hard time replacing parts on a bike I just bought brand new!
    I even still have the dunlops on it at a bit under 2500 miles. I did get a rear pilot power 2 today. I'll install that maybe at 3k or so.
    So about 100$ and thr front end is good, the rear I will probably have to re spring too, so that the suspension works even and no wobbles.
  8. #7
    Member #
    4898
    Join Date
    Apr 2015
    Location
    Northern VA
    Posts
    870
    Quote Originally Posted by MC357 View Post
    There's your first mistake. It may look like an assembled motorcycle but what the Yamaha dealer handed you was keys to a kit.
    "good" is such a strong word in this context. I would characterize the result as somewhere in the neighborhood of "tolerable" or "pretty decent" depending on your level of expectations.
    The rear needs a rework/revalve more than it needs a spring. That'll run you $220. You don't even need to resort to downtime, a redone OE shock (optional respring) can be sent to you and all you need to do is swap one for the other and send yours back or try to sell it on ebay or whatever.
    Spottedfrog likes this.
  9. #8
    Member #
    6144
    Join Date
    Sep 2015
    Location
    Stoughton, WI
    Posts
    2,509
    Yeah ... Yamaha seems to think the average weight of an FZ-09 rider is 175#. We 'Mericans must be bigger than our Euro/Asian/Aussie counterparts . I initially went the .95/5 wt front spring route (225# geared). While it was a nice improvement, it still was a bit harsh. At 200#, I'd go the .90 route. Hit up Matt (pattonme) for some Sonic springs and oil recommendation. Inexpensive good start.
    Also get a hold of Terry at Norwest suspension as he is the one who can revalve/spring your OEM shock. He did mine and it also is a nice improvement over the rear on a budget.
    ausrobbo likes this.
    1970 Honda CT70H
    1972 Honda XL250
    1974 Yamaha MX360
    1975 Suzuki TS250
    1979 Honda CB750F
    1987 Honda XL600R
    2015 Indian Scout
  10. #9
    Junior Member drummel1's Avatar
    Member #
    6089
    Join Date
    Sep 2015
    Location
    Baltimore
    Posts
    7
    Quote Originally Posted by pattonme View Post
    Who offers this? Cuz I TOTALLY didn't take the same approach OP did and ride on it for 2.5 years... I'd be interested in some very budget minded options that don't involve cutting on my bike if you know of any, especially if it means I don't have to give up a ton of seat time.
    MC357 likes this.
  11. #10
    Junior Member QldMT09's Avatar
    Member #
    24537
    Join Date
    Jul 2017
    Location
    Gold Coast, Qld, Australia
    Posts
    1
    2015 MT09 with Adreani Inserts
    Hi, Have been searching for information to fix the adreani cartridge inserts and see that you come highly recommended for a fix. Have also been talking to Kevxtx from this forum about a fix. He said that he got your fix set to him and he is very happy with the end result for the MT09. I would like to purchase the same kit and have it sent. Would you be able to do this? Plse let me know the cost for the kit and post to the Gold Coast, Queensland, Australia. Oh. Riding weight is 85kgs.
    Cheers
    Doug
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Any harm in doing first service early?
    By OilCan in forum XSR900 General Discussion
    Last Post: 08-03-2016, 08:06 AM
  2. Front suspension dillemma.
    By pete4x4 in forum FZ-09 Performance & Suspension
    Last Post: 02-23-2016, 06:43 PM
  3. Front Suspension
    By stevie in forum FZ-09 Performance & Suspension
    Last Post: 02-23-2016, 02:20 AM
  4. Max payload suspension settings
    By velvetymouse in forum FZ-09 Performance & Suspension
    Last Post: 08-14-2015, 09:07 AM
  5. 42 Max PSI rating on front and back tires plus my compressor setup
    By cjhorton in forum FZ-09 Wheels & Tires
    Last Post: 02-22-2014, 11:47 PM
