Power Commander V
Close
Login to Your Account
Power Commander V
This is a discussion on Power Commander V within the FZ-09 Performance & Suspension forums, part of the Yamaha FZ-09 Garage category; I am about to pick up a lightly used PCV tomorrow for a good enough deal that it rivals a re-flash. I'm going to be ...
Results 1 to 7 of 7
Like Tree4Likes
  • 1 Post By gsatterw
  • 1 Post By blkbrd
  • 2 Post By motomania
Thread: Power Commander V
  1. #1
    Member Red Max's Avatar
    Member #
    8425
    Join Date
    Jul 2016
    Posts
    47
    Power Commander V
    I am about to pick up a lightly used PCV tomorrow for a good enough deal that it rivals a re-flash. I'm going to be buying an Akra Carbon over the winter, but I'm reading on the forums that a PCV is not necessarily the best way to go, but not many answers say why. Power Commanders are supposed to be more versatile from what I've learned in general, but is this not the case for the FZ?
    Any insight into this? I just want what's best for my ̶c̶h̶i̶l̶d̶̶ bike.
    Current: 2014 FZ-09, 2003 SV-1000S, 2005 ZX-6R (project)
    Past: 2007 ZX-6R, 2000 SV-650S
  2. #2
    Senior Member gsatterw's Avatar
    Member #
    6342
    Join Date
    Oct 2015
    Location
    Baton Rouge, LA
    Posts
    1,295
    Power commander does not fix on/off fueling. Doesn't remove speed limiter, can't disable AIS system, can't apply different throttle maps, can't adjust timing. A good flash is far superior.
    Desert Rat likes this.
  3. #3
    Junior Member Tuddu's Avatar
    Member #
    9882
    Join Date
    Aug 2016
    Posts
    22
    ... and needs lambda disconnected...
    Inviato dal mio NX508J utilizzando Tapatalk
  4. Remove Advertisements
    FZ09.org
    Advertisements
  5. #4
    Senior Member blkbrd's Avatar
    Member #
    5442
    Join Date
    Jun 2015
    Location
    Midland, ON
    Posts
    1,363
    I have a PCV on mine. I'm happy with it. It may not fix the on/off fueling like a flash would, but it improves it alot. The O2 optimizer that comes with the PCV also greatly improves the light throttle cruising behavior. I may flash mine one day, just to see, but the power commander did make a huge difference.
    Sent from my SM-G903W using Tapatalk
    myntz likes this.
    2015 Matte Grey FZ-09 --- Oxford Heated Grips --- Spiegler S/S Brake lines --- OES Frame Sliders --- OES Front Axle Sliders --- GYTR Rad Guard --- GYTR Windscreen --- Racetech Gold Valves --- Racetech Fork Springs --- ZX6R Rear Shock --- Rizoma Action LED Turn Signals --- Tripage Gold LED Headlamp --- E-Bay Pazzo Knockoff Levers --- Termignoni Carbon Exhaust --- Power Commander 5 --- Yoshimura Fender Eliminator --- Ivan's ECU Flash --- Shad Comfort Seat -- GYTR Quick Shifter
  6. #5
    Senior Member myntz's Avatar
    Member #
    5640
    Join Date
    Jul 2015
    Location
    North of Boston, MA
    Posts
    432
    Quote Originally Posted by blkbrd View Post
    IMHO - for day to day cruising and commuting, I found that the PCV was much better at handling light throttle/cruising than my current flash from a popular vendor.
    I was running M4 exhaust + blockoff plates + PCV + Kevxtx O2 controller.
    This setup along with my custom tweaked map had the bike running better at low RPM than post-flash but had a sudden onset of power 4500+ when the bike kicked out of closed fueling.
  7. #6
    Member #
    8425
    Join Date
    Jul 2016
    Posts
    47
    As a street rider, should the PCV + Akra Carbon do the job? I just want to make sure I'm not wasting any money.... I'm getting the stock ECU reflash from Yamaha soon since I have a '14. It's manageable now, so it can only be better after the flash.
  8. #7
    Member #
    131
    Join Date
    Jul 2013
    Location
    Merced, CA
    Posts
    2,330
    Quote Originally Posted by Red Max View Post
    1) the 2014 reflash from the factory was not much help. It helped, just not much so don't expect much from it.
    2) PC has a lot of reliability issues mostly related to cheesy, incompetent, amateur installation practices such as using scotchlocks and/or wirenuts and/or improperly crimped splices to tap into the stock wiring and other issues. I have untangled that mess a few times and helped several people troubleshoot their bikes when something went nuts with the piggyback fuel controller (PC and Bazzaz). If you buy the plug in type harness makes a T connection to the ECU the connections are much more reliable.
    3) The PC can only modify the input signals and output signals from the ECU. It cannot fix the actual problem of the fuel cut and related issues.
    The PC is great for some situations such as where you cannot reflash the ECU but for the most part, it is way past passe, old tech. The one exception is when you want to be able to fiddle with your mapping yourself. Not too many people really use that capability.
    Otherwise, a reflash is much better use of your money and is less prone to failure.
    Desert Rat and myntz like this.
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. FS: Power Commander 5
    By Jkaiser93 in forum Parts for Sale / Wanted
    Last Post: 10-16-2015, 06:39 AM
  2. FS; Power Commander V
    By Tflndav in forum Parts for Sale / Wanted
    Last Post: 05-04-2015, 04:22 PM
  3. FS:Power Commander 5
    By kkilmore89 in forum Parts for Sale / Wanted
    Last Post: 01-21-2015, 08:10 PM
  4. Installed Power Commander V - Now no power to gauges or ECU
    By caffine in forum FZ-09 General Discussion
    Last Post: 06-15-2014, 09:28 AM
  5. power commander
    By dangerousdan in forum FZ-09 General Discussion
    Last Post: 03-18-2014, 11:06 PM
