New style head light swap
Close
Login to Your Account
This is a discussion on New style head light swap within the FZ-09 Gear & Accessories forums, part of the Yamaha FZ-09 Garage category; Does anyone know if the 2017 fz09 head light will work on an earlier 2015 fz09 ....
Results 1 to 5 of 5
Thread: New style head light swap
  1. #1
    Junior Member Turbomopar's Avatar
    Member #
    39424
    Join Date
    Jan 2019
    Posts
    2
  2. #2
    Senior Member peabrain's Avatar
    Member #
    6574
    Join Date
    Jan 2016
    Location
    5 dimensions down the road of existence
    Posts
    196
    with all the brackets and etc you could make it fit.(even adding custum made brackets)
    my only issue may be that you need some wiring change done, wich could get complicated if you are new to wiring on bikes.
  3. #3
    Senior Member abe57's Avatar
    Member #
    3833
    Join Date
    Nov 2014
    Location
    Columbus,IN
    Posts
    2,453
    There is a bunch of wires as stated above that are in the headlamp on the 15's and most of that got moved on the 17's to other locations ..... so yes you would have to move some stuff around as wiring go's ..not easy but I guess if willing it can be done !
    King-Of-Bee's
  4. Remove Advertisements
    FZ09.org
    Advertisements
  5. #4
    jj_
    jj_ is offline
    Junior Member jj_'s Avatar
    Member #
    37974
    Join Date
    Jul 2018
    Posts
    22
    I'm planning on going the other way. 7" halogen on a '17. I have figured out the wiring and tested it on a H4 bulb. It works. You'll need to use resistors, I think, where I need to use relays. I can upload all my pics of the diagrams I drew when I get home this evening. You should be able to figure it out from there.
    P.S./edit why do you want to do this? Why not just get a J.W. Speaker adaptive for your bike? The 17 LED has a horrible pattern for cornering at night, like the inside of the turn goes black when you lean in.
    17 FZ-09
  6. #5
    Member #
    39424
    Join Date
    Jan 2019
    Posts
    2
    I just liked the look but if the lighting sucks then I guess I should just stay with what I have
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. 2015 FZ09 head lights swap?
    By jvassilakis in forum FZ-09 General Discussion
    Last Post: 11-08-2017, 09:24 AM
  2. Led head light and running light installed
    By pete1p in forum FZ-09 Builds
    Last Post: 07-12-2016, 07:10 AM
  3. FS, eBay style tail tidy, plate bracket with LED light
    By bigweb2001 in forum Parts for Sale / Wanted
    Last Post: 07-05-2015, 07:37 PM
  4. Replies: 43
    Last Post: 04-02-2015, 11:46 AM
  5. Newbie questions. Tail light, head light, exhaust and blinkers
    By espospowdercoating in forum FZ-09 General Discussion
    Last Post: 03-20-2014, 01:21 PM
