Stupid Question - Preload Adjusters
Close
Login to Your Account
This is a discussion on Stupid Question - Preload Adjusters within the FZ-09 Gear & Accessories forums, part of the Yamaha FZ-09 Garage category; I think I have these figured out but I'm not 100% sure what they do???? I see the set screw in the photo so I'm ...
Results 1 to 6 of 6
Like Tree7Likes
  • 2 Post By Fizzerpilot
  • 4 Post By motomania
  • 1 Post By Keef
Thread: Stupid Question - Preload Adjusters
  1. #1
    Senior Member EZ-09's Avatar
    Member #
    5913
    Join Date
    Aug 2015
    Location
    Middle Of Nowhere, Alabama
    Posts
    132
    I think I have these figured out but I'm not 100% sure what they do???? I see the set screw in the photo so I'm assuming that you attach them to your preload adjuster bolts on top of the forks and it gives you the ability to adjust the preload by hand without additional tools??? Does anyone here have them installed and do they work as advertised?
  2. #2
    Senior Member Fizzerpilot's Avatar
    Member #
    1374
    Join Date
    Feb 2014
    Location
    Indianapolis
    Posts
    4,498
    I think they are sorta goofy. Most people set preload once, and leave it. Making this adjuster just bling.
    Sent from my SM-G386T using Tapatalk
    Desert Rat and RichBaker like this.
  3. #3
    Senior Member DECON BLUE's Avatar
    Member #
    2960
    Join Date
    Jul 2014
    Location
    Port Richey, Florida
    Posts
    610
    I have them, although not like the picture of yours. And yes if you ride much or various roads of different surfaces they do help with adjustment of preload.
    Graves Tidy Tail, adj. levers, OEM Fly Screen, gauge relocation, horn relocation mod., Vcycle flash, TST Flush mount front LED turn signals, TST Flasher Relay, Womet-Tech bar ends, Flash Tune Quick Shifter, Comp. Werkes Stainless Slip-on exhaust, Battery Tender USB Charging Port
  4. Remove Advertisements
    FZ09.org
    Advertisements
  5. #4
    Member #
    131
    Join Date
    Jul 2013
    Location
    Merced, CA
    Posts
    2,330
    In general, you set the preload once.
    The only time you change it is if you are riding with a passenger or a load.
    Road conditions or pace do NOT determine preload or require preload adjustment on a properly set up suspension.
    Thus, these adjusters are mostly bling and not utility.
  6. #5
    Member #
    1374
    Join Date
    Feb 2014
    Location
    Indianapolis
    Posts
    4,498
    ^^^ correct. It adjusts sag. Which once sag is set, it's set. These adjusters are just gimmicks.
  7. #6
    Senior Member Keef's Avatar
    Member #
    2010
    Join Date
    Apr 2014
    Location
    Sydney Australia
    Posts
    2,212
    I've got a set on my MT. They did make setting sag easier. And I like the way they look.
    DECON BLUE likes this.
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Andreani Fork Cartridges Installed........ Preload Adjustment Question
    By FZ09R in forum FZ-09 Performance & Suspension
    Last Post: 07-10-2017, 11:52 AM
  2. A Question About Litetech Chain Adjusters
    By 1duckyboy in forum FZ-09 General Discussion
    Last Post: 10-08-2015, 04:48 PM
  3. Chain adjusters
    By LouG in forum FZ-09 General Discussion
    Last Post: 09-30-2015, 01:46 PM
  4. Manual fork preload adjusters
    By Woof in forum FZ-09 Performance & Suspension
    Last Post: 03-25-2015, 08:04 PM
  5. Fork Preload Adjusters
    By fatfurious2 in forum FZ-09 General Discussion
    Last Post: 06-08-2014, 05:25 PM
