After market license plate light wiring?
Close
Login to Your Account
This is a discussion on After market license plate light wiring? within the XSR900 Common Problems/Issues forums, part of the Yamaha XSR900 Cafe Racer Forum category; Hi everyone! So I have a question related to the License plate bracket/light I purchased and am wondering if anyone has some insight. I bought ...
Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By Springbok
Thread: After market license plate light wiring?
  1. #1
    Junior Member RJandrew's Avatar
    Member #
    40156
    Join Date
    Apr 2019
    Posts
    3
    Hi everyone! So I have a question related to the License plate bracket/light I purchased and am wondering if anyone has some insight. I bought a graves fender eliminator with a license plate light and turn signals from 12 0'clocklabs. They don't give any specific instructions for wiring the license light, they do include a red wire with two male bullet connectors and a striped end plus a posi-tap connector - Which is the part I'm stuck on. Not sure how these are all supposed to connect to the license plate light positive/negative to give it power? Any help at all is much appreciated. I couldn't really find any other videos or post dealing with this specially so figured I would ask myself here.
  2. #2
    Junior Member cb1ocker's Avatar
    Member #
    26962
    Join Date
    Aug 2017
    Location
    Wisconsin
    Posts
    20
    I don't know if different model years have different wiring for the license plate light, but on my 17 I unplugged the existing license plate light, then picked up a matching terminal connector from Cycle Terminal, connected it to the end of the new light wires and plugged directly into the original license plate light plug. As for which is positive and which is negative, I'm pretty sure I just poked the wires in one way, and if it was wrong I swapped them to figure it out. Probably not the best way to check polarity, but it worked for me. The connector is a JST JWPF 2 Pin Connector, but I don't remember if you need male or female for the new light.
    Ducati - KTM turn signal connectors
  3. #3
    Member Springbok's Avatar
    Member #
    37465
    Join Date
    Jun 2018
    Location
    Perth, Australia
    Posts
    40
    Quote Originally Posted by RJandrew View Post
    Mate please don’t use a posi tap connector, It’ll bugger the wiring when it shakes itself to hell and back. Standby, I’m just trying to find my pics when I did mine.
    You want a running light for the indicators at the rear connected to the tail light and front indicators to the Parker light?
  4. Remove Advertisements
    FZ09.org
    Advertisements
  5. #4
    Member #
    37465
    Join Date
    Jun 2018
    Location
    Perth, Australia
    Posts
    40
    Could you send me a picture of what you want to connect exactly?
  6. #5
    Member #
    40156
    Join Date
    Apr 2019
    Posts
    3
    Yeah the Instructions are vague and the wire they provided has me a bit confused with the posi-tap. I believe i am supposed to connect to the oem license power plug using the posi-tap it just seems odd giving how hard it is to get to that wire. Definitely hard explaining it so here is some images IMG_2373_LI.jpg IMG_2376.JPG
  7. #6
    Member #
    37465
    Join Date
    Jun 2018
    Location
    Perth, Australia
    Posts
    40
    Can you send me a pic of the original connector on the stock license plate wires?
  8. #7
    Member #
    40156
    Join Date
    Apr 2019
    Posts
    3
    Quote Originally Posted by Springbok View Post
    yeah It's just the same wire that was connected to the bulb on the stock assembly IMG_2377.JPG
  9. #8
    Senior Member dcpppf's Avatar
    Member #
    2879
    Join Date
    Jul 2014
    Location
    KC, KS/MO
    Posts
    773
    I do better with sketches if you have time for a sketch. Regardless though, It sounds like there are only 3 wires for two turn signals and the license plate LED; is that true? I understand your concern with the ground because I would expect at least a fourth wire as well. Some simple integrated tail lights (like my supermotos) have a single ground for either blinker, and the brake light. So it wouldn't surprise me if you have a fourth wire with a common ground for all three... But if you only have three wires for three devices; something isn't clicking for me i guess.
    Mods: under seat USB charger, complete OES slider/spool set, evotech rad guard, yoshimura FE, barracuda freccia turn signals (front and back), ASV shorty levers (black w/ gold adjusters), puig dark tinted sport screen, APE CCT, Tripage LED Pegs, Ohlin's rear shock, Akra Ti, gold/smoked stainless brake lines (front and back), PowerMadd hand guards
  10. #9
    Member #
    37465
    Join Date
    Jun 2018
    Location
    Perth, Australia
    Posts
    40
    Quote Originally Posted by dcpppf View Post
    Yeah send through a sketch to have a look at if you can. Also send a pic of what the whole package looks like ie. the indicators, brake light and licence plate lights etc
    dcpppf likes this.
  11. #10
    Member #
    2879
    Join Date
    Jul 2014
    Location
    KC, KS/MO
    Posts
    773
    Here is a link to a wiring diagram of what I was talking about, but I meant for you to sketch what you're working with haha. I just looked at your photos again and I'm pretty sure I was WAY off previously. Looks like you have two wires for the license plate and then three wires for each turn signal; is that right? They do daytime running as well as flash? If so that makes much more sense (to me at least). Each of the three elements has it's own ground, a single common DC+ (constantly powering the DRLs and license plate light), and then each turn signal has a "flash" signal.
    https://images-na.ssl-images-amazon....L._SL1384_.jpg
    EDIT: NOTE... I do not know what the colors for the positive/negative are for the license plate, but I'm assuming that link wire should connect the DC+ (constant) to all three devices to get you your DRL on the blinkers as well as the license plate constantly powered. If you have a multimeter you can check for voltages and just tap the license plate wires to ensure you get it connected the right way since it won't work if connected backwards.
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. After market exhaust/low end torque..
    By dvirgil13 in forum FZ-09 Performance & Suspension
    Last Post: 03-04-2017, 05:48 PM
  2. After market levers
    By Ro.nin in forum XSR900 General Discussion
    Last Post: 04-14-2016, 09:04 AM
  3. After-market Parts Australia
    By mtayl24 in forum FZ-09 General Discussion
    Last Post: 03-28-2015, 10:44 PM
  4. Best after market seat for the FZ09
    By TripleFaze09 in forum FZ-09 Gear & Accessories
    Last Post: 10-07-2014, 05:01 PM
  5. My rear turn signals and license plate light don't turn on...
    By Vbp6us in forum FZ-09 General Discussion
    Last Post: 08-03-2014, 09:56 PM
