Engine Light Came On (XSR) - Page 11
Close
Login to Your Account
This is a discussion on Engine Light Came On (XSR) within the XSR900 Common Problems/Issues forums, part of the Yamaha XSR900 Cafe Racer Forum category; Originally Posted by Fearedbynone i got the obd to yamaha 4 pin connector and a cheap reader. i just clear the code myself. if you ...
Page 11 of 11 FirstFirst ... 91011
Results 101 to 105 of 105
Like Tree24Likes
Thread: Engine Light Came On (XSR)
  1. #101
    Junior Member super48's Avatar
    Member #
    7350
    Join Date
    May 2016
    Posts
    6
    2016 XSR900 Euro3 or Euro4
    Quote Originally Posted by Fearedbynone View Post
    if you have your ecu flashed, you will get a light.
    i did a full yoshi and 2wdw tune so i got the cable just to have it.
    Dave
    any one knows which scanner works on 2016 XSR900? I tried get one on ebay, the seller stated that most of the scanners work on Euro 4 emission only, he thought 2016 XSR900 was Euro 3 and 2017 and after are using Euro 4, can some one clarify this? thanks........
  2. #102
    Senior Member XSR-900's Avatar
    Member #
    10762
    Join Date
    Aug 2016
    Location
    Seattle WA
    Posts
    606
    Quote Originally Posted by super48 View Post
    OBDII protocol, and need an OBDII scanner capable of reading CAN.
  3. #103
    Member #
    10762
    Join Date
    Aug 2016
    Location
    Seattle WA
    Posts
    606
  4. Remove Advertisements
    FZ09.org
    Advertisements
  5. #104
    Senior Member Mozzer's Avatar
    Member #
    11082
    Join Date
    Sep 2016
    Location
    Portsmouth
    Posts
    206
    My CEL came on over the weekend as I started it up ready to go for a ride. Went to the dealership today and he cleared it and said it was the wheel speed sensor fault. Absolutely no reason for this but it just happened. It's possible that some metal debris can get in there and just set it off apparently, so it's just one of those things.
    How Yamaha keep getting my money is the fact it wasn't a real fault with the bike and he cleared it without charge. Which is more than can be said for some other brands/dealers I could mention.
    Current Beauties...
    XSR900 Harley-Davidson FXFBS
    Past Beauties...
    CZ250 'Bitsa'80 DT50 KE125 RGV250 NSR400R GPz550 XT600 GPz500S ZZR600 Ducati916 DucatiS4 VFR400 Honda Varadero Ducati749 DR350 XJR1300SP
  6. #105
    Junior Member Davidoff's Avatar
    Member #
    36802
    Join Date
    May 2018
    Posts
    22
    Quote Originally Posted by Mozzer View Post
    Mine came on last month whilst I was touring Ireland. Had to take it to a Yamaha Service Agent in Cork who cleared the code, cost me 50 Euros (2017 bike, out of warranty). It was raining very heavily when it came on and I was stuck in traffic, he put it down to dirt on the wheel speed sensor. Done in excess of 2000 miles since and all good.
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. check engine light sd_60
    By EMT in forum Yamaha FZ-09 Common Problems/Issues
    Last Post: 05-11-2016, 05:51 PM
  2. Oil Light/Engine Light
    By rosavp33 in forum Yamaha FZ-09 Common Problems/Issues
    Last Post: 02-21-2016, 08:27 AM
  3. Does your engine light illuminate when turning the key off?
    By Nimbus in forum FZ-09 General Discussion
    Last Post: 05-31-2015, 11:14 PM
  4. Engine Light - Fault Codes
    By DaveO1967 in forum FZ-09 General Discussion
    Last Post: 04-10-2015, 08:28 AM
  5. Check engine light and code
    By Dj1911 in forum Yamaha FZ-09 Common Problems/Issues
    Last Post: 01-30-2015, 09:16 PM
Search tags for this page
2015 mt-09 engine light stays on
check engine light yamaha xsr900
clear xsr900 check engine light
common chech engine lights for xsr900
how to reset yamaha motorcycle abs light without scan tool
xsr 900 check engine light
xsr 900 yamaha check engine
xsr900 check engine
xsr900 engine light
xsr900 engine loght
yamaha fz6r engine light
yamaha tdm 900 check engine and abs light
yamaha xsr 900 engine light
