o2 sensor after flash on xsr
Close
Login to Your Account
This is a discussion on o2 sensor after flash on xsr within the XSR900 General Discussion forums, part of the Yamaha XSR900 Cafe Racer Forum category; I'm going to be getting a flash soon, and am a little confused about what to do with the o2 sensor plug at the midpipe ...
Results 1 to 5 of 5
Thread: o2 sensor after flash on xsr
  1. #1
    Member Siens's Avatar
    Member #
    7841
    Join Date
    Jun 2016
    Posts
    96
    I'm going to be getting a flash soon, and am a little confused about what to do with the o2 sensor plug at the midpipe . I know the ais system will be disabled with the flash and the sensor is not needed..but..do I have to screw it back in to avoid the dreaded check engine light ? Or am I ok to screw in the plug that came with the aftermarket exhaust ? And disconnect the sensor at the connector port ? Obviously the warning light is what I'm looking to avoid at all costs...I've read conflicting info on this on different tuners Web pages. I know it's ok to remove it on the fz. But the xsr is a whole other beast when it comes to that diagnostic light. Any info is appreciated. Thanks
    Sent from my SM-G935V using Tapatalk
  2. #2
    Gold Supporting Member
    Supporting Member
    Crosshairs's Avatar
    Member #
    2174
    Join Date
    May 2014
    Posts
    2,032
    Whoever is doing your flash should answer those questions. We have no idea what he is doing with the code.
    2014 FZ09 Mods> Ivans ECU Flash....... Penske 8983....... GP fork piston kit.......Woodcraft Frame Sliders....Woodcraft Axle Sliders ...Woodcraft Engine guards...Chinese spools...
    Spiegler SS brake lines .....APE CC tensioner .....Antigravity AG-801 Battery......tripage LED headlight.......tripage LED pegs ...Watsen Design front turn signals..and some other stuff I dont feel like listing
  3. #3
    Member #
    7841
    Join Date
    Jun 2016
    Posts
    96
    what I'm asking is..if the o2 is disabled in the flash, is it it ok to remove the sensor on the exhaust..or does it need to stay plugged in..regardless of "code".. or will it throw a warning light. I know its different on fzs and xsrs ..so maybe someone who has an xsr with a flashed ecu might know what I'm referring to..
  4. Remove Advertisements
    FZ09.com
    Advertisements
  5. #4
    Senior Member XSR-900's Avatar
    Member #
    10762
    Join Date
    Aug 2016
    Location
    Seattle WA
    Posts
    362
    If the tuner disables the O2 sensor in his ECU re-flash, then not having the sensor probably won't trip the check engine light. If that's the case, then just put the plug in and remove the O2 sensor. But as mentioned already, you really need to email or talk to the ECU tuner to see what he says about using the O2 sensor or not with the re-flash.
  6. #5
    Supporting Member
    Crosshairs's Avatar
    Member #
    2174
    Join Date
    May 2014
    Posts
    2,032
    Quote Originally Posted by Siens View Post
    if its disabled then yes, you can unplug it and remove it without fear of an engine light.
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. ECU Flash (Stoltec vs. Flash-Tune)
    By dubblernr in forum FZ-09 Performance & Suspension
    Last Post: 01-30-2017, 01:29 PM
  2. Temperature Sensor
    By minsk99 in forum XSR900 General Discussion
    Last Post: 08-04-2016, 03:09 PM
  3. ECU Flash or not to Flash - throttle issue?
    By druck in forum Yamaha FZ-09 Common Problems/Issues
    Last Post: 03-06-2016, 04:20 PM
  4. No Speed Sensor
    By emrevuran in forum FZ-09 General Discussion
    Last Post: 12-16-2015, 03:36 AM
  5. Anti Wheelie Sensor?
    By GaryC in forum FZ-09 General Discussion
    Last Post: 02-21-2015, 05:18 PM
