Factory chain lube - Page 3
Close
Login to Your Account
Factory chain lube
This is a discussion on Factory chain lube within the XSR900 General Discussion forums, part of the Yamaha XSR900 Cafe Racer Forum category; Been told many times I do it right and probably the expensive way. Every 200-300 miles I clean my chain with WD-40 Specialist Water Resistant ...
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 31
Like Tree11Likes
Thread: Factory chain lube
  1. #21
    Junior Member alexfair's Avatar
    Member #
    13586
    Join Date
    Oct 2016
    Location
    Los Angeles California
    Posts
    23
    Every 200-300 miles I clean my chain with WD-40 Specialist Water Resistant Silicone Lubricant Spray.
    Then lube the chain with a paste which is Motul Chain Lube Paste.
  2. #22
    Member deboula's Avatar
    Member #
    306
    Join Date
    Sep 2013
    Location
    montreal,canada
    Posts
    42
    Quote Originally Posted by Rocky_MTN_FZ09 View Post
    Here is a good video on WD-40 and O-Ring motorcycle chains.
    Here is one example of someone who uses WD-40 to lube his chain. One thing to note is that he cleans his chain often and makes sure it is adjusted properly all the time.
    On the dirt bikes I use to use Maxima Chain Wax and it worked great, but found it made a mess on my street bikes. Which is why I switched over to Bel-Ray Super Clean. It is dry and dusty here most of the time, and I found the Wax chain lubes turned black right away from all the dust.
    If you ride a lot in the rain, I'd suggest checking out and auto oiler like a Scottoiler or TUTORO Automatic Motorcycle Chain Oiler. They are standard on a lot of bikes in the UK, for guys who ride rain or shine.
    What kind of chain is that (gold inside and black plates on the sides)
  3. #23
    Member stevierst's Avatar
    Member #
    14737
    Join Date
    Nov 2016
    Posts
    42
    Or you could just fit a scottoiler, and forget about oiling your chain.
    Used them for the last 15+ years, and well over 1/4 million miles (about 30 thou per bike). Only ever had to change 2 chains through wear, and they were probably knackered to start with!
    I really don't know why people don't fit them, it's a no brainier!
  4. Remove Advertisements
    FZ09.com
    Advertisements
  5. #24
    Senior Member yamfz09's Avatar
    Member #
    6606
    Join Date
    Jan 2016
    Location
    Cleveland, Ohio
    Posts
    393
    Quote Originally Posted by stevierst View Post
    As someone said here before, you can buy a lot of cans of chain lube for $140
    IMO, I don't want something hanging of my bike that's not really necessary. Especially something with oil that could leak.
    Desert Rat likes this.
  6. #25
    Senior Member meinschaft's Avatar
    Member #
    6770
    Join Date
    Feb 2016
    Location
    Nirvana
    Posts
    198
    DuPont Teflon Chain-Saver Dry Self-Cleaning Lubricant
    https://www.amazon.com/gp/product/B0...=ATVPDKIKX0DER
    ridetofish likes this.
    1965 Triumph Bonneville, 1968 Honda Cl350, 1972 Yamaha XS650, 1982 Yamaha XS650, 1999 Triumph Legend, 2004 Kawasaki Z750S, 2008 Yamaha FZ1, 2008.5 Yamaha FZ1, 2015 Yamaha FZ-09
  7. #26
    Member #
    14737
    Join Date
    Nov 2016
    Posts
    42
    Quote Originally Posted by yamfz09 View Post
    I don't want to hijack the thread, but unless I told you there was a scottoiler on my two current bikes, you'd never know. They're hidden away that well. And $140!!!!! All I'll say is 'ebay'
    And in that 1/4 million miles, never had one leak. Just my opinion, but each to their own.
  8. #27
    Senior Member CapeRR's Avatar
    Member #
    11921
    Join Date
    Sep 2016
    Location
    Nova Scotia, CAN
    Posts
    213
    I use Tirox chain cleaner. It comes with 360 degree brush that wraps around the chain. The spray itself is basically just kerosene by the smell of it. I've had it a few years and used it on a number of bikes and it works quite well.
    For lube I use the clear Bel-ray stuff. I don't like the look of the ones that leave the white behind. Maxima chain wax is good too.
  9. #28
    Junior Member BUDFORCE's Avatar
    Member #
    13681
    Join Date
    Oct 2016
    Posts
    14
    Quote Originally Posted by Crosshairs View Post
    With an O ring chain.. When you are oiling it, all you are really doing is lubricating the sprockets as the chain is lubed internally
    Whilst that is true, the exterior may be prone to corrosion if you don lubricate it, and then rust or corrosion can work in between the moving parts, ruin the rubber seals, and then the internal lubrication can get out.
    Then you chain is broken
    Also I wouldn't use WD40 for chain lubrication unless you use it every day or two. WD40 becomes hydroscopic after a few days (will attract water) which will then penetrate in to the little gaps on your chain and do more harm then good.
    But any purpose made chain lubrication is fine, it comes down to personal choice on which are better than others.
  10. #29
    Gold Supporting Member
    Supporting Member
    Crosshairs's Avatar
    Member #
    2174
    Join Date
    May 2014
    Posts
    2,078
    Quote Originally Posted by BUDFORCE View Post
    Yeah, I think that pretty obvious.
    2014 FZ09 Mods> Ivans ECU Flash....... Penske 8983....... GP fork piston kit.......Woodcraft Frame Sliders....Woodcraft Axle Sliders ...Woodcraft Engine guards...Chinese spools...
    Spiegler SS brake lines .....APE CC tensioner .....Antigravity AG-801 Battery......tripage LED headlight.......tripage LED pegs ...Watsen Design front turn signals..and some other stuff I dont feel like listing
  11. #30
    Senior Member abe57's Avatar
    Member #
    3833
    Join Date
    Nov 2014
    Location
    Columbus,IN
    Posts
    1,883
    Quote Originally Posted by deboula View Post
    That is a EK 3D black/gold chain...
    King-Of-Bee's
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. KLOTZ Chain Lube
    By JET in forum XSR900 General Discussion
    Last Post: 06-07-2016, 11:15 PM
  2. Non-Spray on chain lube?
    By akakpaws in forum Yamaha FZ-09 Common Problems/Issues
    Last Post: 11-20-2015, 02:37 PM
  3. Chain lube?
    By taoshum in forum FZ-09 General Discussion
    Last Post: 06-27-2015, 06:50 PM
  4. How do you lube the chain???
    Last Post: 09-08-2014, 11:16 PM
  5. Bel-Ray Super Clean Chain Lube Rocks!
    By Yoyodyne in forum FZ-09 General Discussion
    Last Post: 08-06-2014, 09:03 PM
Search tags for this page
2017 yamaha fz 09 360 degree view
