Factory chain lube - Page 2
Close
Login to Your Account
Factory chain lube
This is a discussion on Factory chain lube within the XSR900 General Discussion forums, part of the Yamaha XSR900 Cafe Racer Forum category; Originally Posted by Crosshairs With an O ring chain.. When you are oiling it, all you are really doing is lubricating the sprockets as the ...
Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 31
Like Tree11Likes
Thread: Factory chain lube
  1. #11
    Senior Member XSR-900's Avatar
    Member #
    10762
    Join Date
    Aug 2016
    Location
    Seattle WA
    Posts
    428
    Quote Originally Posted by Crosshairs View Post
    With an O ring chain.. When you are oiling it, all you are really doing is lubricating the sprockets as the chain is lubed internally
    True, but it's also lubricating in inside of the center rollers also which IMO is important to keep a chain in good shape. Keeping lube on the rollers and sprocket teeth cuts down wear quite a bit. I see guys who never lube their chain because they say it's "lubed internally", and the chain rollers look like chrome from all the wear.
  2. #12
    Member #
    10762
    Join Date
    Aug 2016
    Location
    Seattle WA
    Posts
    428
    Quote Originally Posted by Jodiesel View Post
    Ding, ding......winner - 450 miles now.
    The factory chain lube lasted 550 miles on my XSR. I cleaned it with kerosene and lubed it with Maxima chain wax at 550 miles, and that lube lasted to 1000 miles. I've used Maxima chain wax for years on all my chain driven bikes and never had any real mess or dirt attraction and it typically lasts 450~500 miles between lubes.
  3. #13
    Gold Supporting Member
    Supporting Member
    Jodiesel's Avatar
    Member #
    7587
    Join Date
    May 2016
    Location
    Oahu, HI
    Posts
    79
    The chain that came with my bike is a D.I.D. 525 V10. So I look them up online and go through their info. Under Chain Maintenance, I found it quite funny that D.I.D. says not to use kerosene to clean the chain..... I emailed them what kind of lube they send their chains out with.
  4. Remove Advertisements
    FZ09.com
    Advertisements
  5. #14
    Member #
    10762
    Join Date
    Aug 2016
    Location
    Seattle WA
    Posts
    428
    Yamaha owner's manual & service manual says to use kerosene. In fact, about every cycle manufacture I've seen recommends using kerosene to clean o-ring chains.
    Did you ask DID what they recommend to clean their chains with?
  6. #15
    Member #
    131
    Join Date
    Jul 2013
    Location
    Merced, CA
    Posts
    2,270
    Quote Originally Posted by XSR-900 View Post
    According to the video on their website: D.I.D Motorcycle Chains and DirtStar® Rims
    They recommend DID Chain Cleaner which they are happy to sell to you at 10-20x the cost of kerosene.
    Desert Rat likes this.
  7. #16
    Member #
    10762
    Join Date
    Aug 2016
    Location
    Seattle WA
    Posts
    428
    Quote Originally Posted by motomania View Post
    LoL ... of course they want people to buy their expensive cleaner, which is probably kerosene based.
    See the comment to the YouTube video ... it says: "At back side of DID box it stands for cleaning use the kerosene."
  8. #17
    Member #
    131
    Join Date
    Jul 2013
    Location
    Merced, CA
    Posts
    2,270
    I have no doubt their cleaner is kerosene based or at least contains petrochemicals similar to kerosene.
  9. #18
    Supporting Member
    Jodiesel's Avatar
    Member #
    7587
    Join Date
    May 2016
    Location
    Oahu, HI
    Posts
    79
    Ya I laughed pretty hard when I read that on their site. They show in a screen using D.I.D. spray lube on the chain. I couldn't find it in America. Saw it listed on a few over seas websites, but nothing showing the back of can or 'ingredients' or SDS.
  10. #19
    Senior Member Crossbar1773's Avatar
    Member #
    13530
    Join Date
    Oct 2016
    Location
    Huntington, WV
    Posts
    426
    Buy a grunge brush to use with your kerosene. Makes it much easier.
    Lube, I use yamalube, it works well and isn't to expensive
    2015 FZ-09 - current bike
    2013 KLR 650 - Sold
    1978 KZ 400 - Purple Rain - Sold
    2010 Hyosung gt250 - Sold
    And many off road bikes and 4 wheelers in earlier years
  11. #20
    Supporting Member
    Jodiesel's Avatar
    Member #
    7587
    Join Date
    May 2016
    Location
    Oahu, HI
    Posts
    79
    D.I.D. just replied:
    Thank you for contacting D.I.D. It is just a sticky grease that is put in with each chain in Japan. Sorry, it is not available. I am not familiar with OEM chain, I deal with aftermarket so, if that is an o-ring/x-ring, use something that says it is safe for o-rings/x-rings such as PJ1 or Blue Rey. Otherwise use any kind of sticky grease. If you have any further questions, please let me know.
    Thank you.
    Have a nice day!
    D.I.D USA
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. KLOTZ Chain Lube
    By JET in forum XSR900 General Discussion
    Last Post: 06-07-2016, 11:15 PM
  2. Non-Spray on chain lube?
    By akakpaws in forum Yamaha FZ-09 Common Problems/Issues
    Last Post: 11-20-2015, 02:37 PM
  3. Chain lube?
    By taoshum in forum FZ-09 General Discussion
    Last Post: 06-27-2015, 06:50 PM
  4. How do you lube the chain???
    Last Post: 09-08-2014, 11:16 PM
  5. Bel-Ray Super Clean Chain Lube Rocks!
    By Yoyodyne in forum FZ-09 General Discussion
    Last Post: 08-06-2014, 09:03 PM
Search tags for this page
2017 yamaha fz 09 360 degree view
