Seat key cover
Close
Login to Your Account
Seat key cover
This is a discussion on Seat key cover within the FZ-09 General Discussion forums, part of the Yamaha FZ-09 Forums category; I have the R&G Tidy Tail and the seat key cover fell off. Anyone have a suggestion for a seat key cover. The whole cylinder ...
Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Like Tree8Likes
Thread: Seat key cover
  1. #1
    Member triman11427's Avatar
    Member #
    3322
    Join Date
    Sep 2014
    Location
    Melville, NY
    Posts
    92
    Seat key cover
    I have the R&G Tidy Tail and the seat key cover fell off. Anyone have a suggestion for a seat key cover. The whole cylinder is exposed.
  2. #2
    Senior Member JEAN-ROCH's Avatar
    Member #
    2705
    Join Date
    Jun 2014
    Location
    QUÉBEC CANADA
    Posts
    249
    I install a black plastic cover that fit tigh on if after 5500km!
  3. #3
    Senior Member Keef's Avatar
    Member #
    2010
    Join Date
    Apr 2014
    Location
    Sydney Australia
    Posts
    1,875
    fill it with road debris?
    Probably not the most helpful suggestion, I know.
    JARVIS likes this.
  4. Remove Advertisements
    FZ09.com
    Advertisements
  5. #4
    Gold Supporting Member
    Supporting Member
    Rocky_MTN_FZ09's Avatar
    Member #
    3317
    Join Date
    Sep 2014
    Location
    Calgary, AB Canada
    Posts
    3,445
    I have the same tidy tail, I used a couple black tie wraps to hold it in place. One around the rubber cap & one through the first tie wrap which also wrapped around part of the tidy tail. It hasn't moved since I installed it.
    They should have noted something like this in the install instructions, since the rubber cap is a loose fit over the lock.
    You should be able to do the same thing to keep any replacement cap in place.
    Edit: - after two years, the rubber cap hasn't moved.
    Ride to work, work to ride.
  6. #5
    Senior Member rtsb's Avatar
    Member #
    1341
    Join Date
    Feb 2014
    Location
    Puyallup,Wa.
    Posts
    510
    This is what I did to mine I used zip ties to hold it and some good double back tape it works great.
    2014 Liquid Graphite FZ-09
    ARROW Thunder Full Exhaust
    Aluminum Black / Carbon End Cap
    ASV black long brake/shorty clutch levers
    PowerMadd Star Series Black Hand guard System
    Ermax Scoop
    Cree LED head light
    Denalli DM LED driving lights
    Powerbronze seat cowl and belly pan
    Yamaha Fly Shield
    Tidy Tail by SMoto
    Bike Master LED Turn Signal
    Pro Grips
    Old dirt bike racer/rider
    First sport bike
  7. #6
    Senior Member edgyver's Avatar
    Member #
    609
    Join Date
    Nov 2013
    Posts
    768
    I bought a Honda GL1800 right side fairing pocket cable (<$5)and fitted to the lock mechanism. It's a direct snap in installation after you take the lock plate off and loosen the latch mechanism bolts a bit first. Once in place and tightened back up, I routed the cable to come out near the regulator rectifier with a black plastic electrical tie fashioned into a pull loop and attached with some heat shrink tubing to the free end of the cable. It's really easy to use and convenient, too.
    Put one on your bike and you won't need the key lock.
Size:  46.7 KBName:  IMG_7874.JPG
Size:  19.8 KBSeat key cover-img_7878.jpg Name:  IMG_7880.jpg
Size:  23.6 KBName:  IMG_7881.JPG
    2014 FZ-09
    2012 XTZ12 Super Tenere
    Formerly:
    In no particular order - a bunch of stuff like two Transalp XL600Vs, a Pacific Coast PC800, two GL1800s, two EN450s, two SV650s (see a pattern here? ) two CB750 Nighthawks, a CL350, 2004 XL1200R, DL1000, DL650, KLR650, CBR250R, FZ-8, Honda 919 and a VT700C Shadow.
    "Did you know you can ride a Transalp through a wall and not die?"
  8. #7
    Member #
    3322
    Join Date
    Sep 2014
    Location
    Melville, NY
    Posts
    92
    [QUOTE=edgyver;98984]I bought a Honda GL1800 right side fairing pocket cable (<$5)and fitted to the lock mechanism. It's a direct snap in installation after you take the lock plate off and loosen the latch mechanism bolts a bit first. Once in place and tightened back up, I routed the cable to come out near the regulator rectifier with a black plastic electrical tie fashioned into a pull loop and attached with some heat shrink tubing to the free end of the cable. It's really easy to use and convenient, too.
Size:  19.8 KBClick image for larger version.
    That's an incredible feat of engineering. I'm just looking for a cap to protect the key hole. I did reach out to R&G in CA but they don't have the part. Maybe a Home Depot will have something that will work. I read someone used a cap from a leg of a chair. I report when I find an answer.
  9. #8
    Member stunva's Avatar
    Member #
    806
    Join Date
    Dec 2013
    Location
    Gunnedah, NSW, Australia
    Posts
    91
    I just went to the hardware store and bought a 20mm rubber stool leg foot. It slips over tight enough not to vibrate off, looks fine, has done about 3 or 4,000 ks and never fell off and the lock works good as new, I think it set me back 20c.
  10. #9
    Member #
    3322
    Join Date
    Sep 2014
    Location
    Melville, NY
    Posts
    92
    Perfect, thanks.
  11. #10
    Junior Member Macgyver03's Avatar
    Member #
    3475
    Join Date
    Sep 2014
    Location
    Raleigh, NC
    Posts
    8
    edgyver That is awesome! I haven't looked at the lock in that much detail, but did you need to drill the braket or add a piece of metal? Being able to buy the cable and snap it in sounds way to good to be true.
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Luimoto Seat Cover installed - PICS
    By MotovationUSA in forum FZ-09 Gear & Accessories
    Last Post: 07-17-2014, 10:41 AM
  2. Seat cover
    By JEAN-ROCH in forum FZ-09 General Discussion
    Last Post: 07-07-2014, 06:40 AM
  3. Reusing seat lock cover
    By FZ09inBKK in forum FZ-09 Gear & Accessories
    Last Post: 06-09-2014, 08:16 PM
  4. ND a pic of Spring for Seat Lock Cover
    By steviet in forum FZ-09 General Discussion
    Last Post: 05-23-2014, 06:33 PM
  5. Sheep Seat Cover in AU
    By Warrior108 in forum FZ-09 General Discussion
    Last Post: 03-01-2014, 08:22 AM
Search tags for this page
fz09 seat lock cover
seat keycover
