Seat key cover - Page 3
Close
Login to Your Account
Seat key cover
This is a discussion on Seat key cover within the FZ-09 General Discussion forums, part of the Yamaha FZ-09 Forums category; Originally Posted by taoshum What's the part number? That lock thingy is a POC. Thanks....
Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Like Tree8Likes
Thread: Seat key cover
  1. #21
    Senior Member edgyver's Avatar
    Member #
    609
    Join Date
    Nov 2013
    Posts
    768
    Quote Originally Posted by taoshum View Post
    2014 FZ-09
    2012 XTZ12 Super Tenere
    Formerly:
    In no particular order - a bunch of stuff like two Transalp XL600Vs, a Pacific Coast PC800, two GL1800s, two EN450s, two SV650s (see a pattern here? ) two CB750 Nighthawks, a CL350, 2004 XL1200R, DL1000, DL650, KLR650, CBR250R, FZ-8, Honda 919 and a VT700C Shadow.
    "Did you know you can ride a Transalp through a wall and not die?"
  2. #22
    Member triman11427's Avatar
    Member #
    3322
    Join Date
    Sep 2014
    Location
    Melville, NY
    Posts
    92
    I did this mod and it works like a charm!
  3. #23
    Senior Member redeye's Avatar
    Member #
    64
    Join Date
    Jun 2013
    Location
    Frederick County, Maryland
    Posts
    821
    Quote Originally Posted by edgyver View Post
    I bought a Honda GL1800 right side fairing pocket cable (<$5)and fitted to the lock mechanism. It's a direct snap in installation after you take the lock plate off and loosen the latch mechanism bolts a bit first. Once in place and tightened back up, I routed the cable to come out near the regulator rectifier with a black plastic electrical tie fashioned into a pull loop and attached with some heat shrink tubing to the free end of the cable. It's really easy to use and convenient, too.
    Put one on your bike and you won't need the key lock.
    Finally got around to replacing the key lock with the pocket cable last evening. Haven't done the pull loop yet, but that's probably next. Thanks for the write-up!
    2014 FZ-09, 2009 Suzuki TU250X, 2008 Yamaha CP250X
    2004 Honda CRF150F (3 of them!), 2005 Honda CRF100F
  4. Remove Advertisements
    FZ09.com
    Advertisements
  5. #24
    Junior Member Glock Holiday's Avatar
    Member #
    6422
    Join Date
    Nov 2015
    Location
    Oklahoma
    Posts
    10
    I did it and it's so much better than having to bend down on one knee and try and insert my key to lift up my seat in darkness to get out my clear eyepro for the night ride home. Thanks to edgyver.
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Luimoto Seat Cover installed - PICS
    By MotovationUSA in forum FZ-09 Gear & Accessories
    Last Post: 07-17-2014, 10:41 AM
  2. Seat cover
    By JEAN-ROCH in forum FZ-09 General Discussion
    Last Post: 07-07-2014, 06:40 AM
  3. Reusing seat lock cover
    By FZ09inBKK in forum FZ-09 Gear & Accessories
    Last Post: 06-09-2014, 08:16 PM
  4. ND a pic of Spring for Seat Lock Cover
    By steviet in forum FZ-09 General Discussion
    Last Post: 05-23-2014, 06:33 PM
  5. Sheep Seat Cover in AU
    By Warrior108 in forum FZ-09 General Discussion
    Last Post: 03-01-2014, 08:22 AM
Search tags for this page
fz09 seat lock cover
seat keycover
