Seat key cover - Page 2
Close
Login to Your Account
Seat key cover
This is a discussion on Seat key cover within the FZ-09 General Discussion forums, part of the Yamaha FZ-09 Forums category; I bought some chair leg caps at the hardware store and keep a spare under the seat....
Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 24
Like Tree8Likes
Thread: Seat key cover
  1. #11
    Senior Member DNFDOUG's Avatar
    Member #
    235
    Join Date
    Aug 2013
    Location
    Music City, Ten-er-c
    Posts
    4,424
  2. #12
    Senior Member chris1261's Avatar
    Member #
    198
    Join Date
    Aug 2013
    Location
    Clifton, NJ
    Posts
    614
    Somebody on here posted about retrofitting the cap of a trailer wire-harness. If memory serves, he got the connector at wallmart for a few bucks, and modded the cover.
    1979 YZ 125|1984 RZ 350|1984 RZ 350|1991 ZX6|1993 DR 350|Y2K ZRX 1100|2009 WR 250X|2013 TR 650|2014 FZ-09 |2017 FZ-10
  3. #13
    Senior Member edgyver's Avatar
    Member #
    609
    Join Date
    Nov 2013
    Posts
    768
    Quote Originally Posted by Macgyver03 View Post
    edgyver That is awesome! I haven't looked at the lock in that much detail, but did you need to drill the braket or add a piece of metal? Being able to buy the cable and snap it in sounds way to good to be true.
    Macgyver03 & triman11427 :
    It really is a plug and play installation. If I had it to do over, it wouldn't take 10 minutes and requires zero modification to the bike .
    The latch mechanism has a small tang that the key lock presses against, releasing the seat. The tang comes with a small slot already cut. When you loosen the latch mounting bolts, the Honda cable end can be slipped between the latch and mount and into place through the slot. The latch base already has a place to snap the green part of the cable into, also. It's probably used precisely like that on another model Yamaha.
    Name:  cable detail.JPG
    As soon as I saw how the latch was made, I was reminded of the fairing pocket cable on my former GL1800. I paid $3.58 + $5.95 shipping for the cable from Partzilla. (It cost me more than $5.95 in gas to ride to my nearest Honda dealer.)
    Even if you elect to keep the key lock, it's an easy, cheap mod that works great!
    2014 FZ-09
    2012 XTZ12 Super Tenere
    Formerly:
    In no particular order - a bunch of stuff like two Transalp XL600Vs, a Pacific Coast PC800, two GL1800s, two EN450s, two SV650s (see a pattern here? ) two CB750 Nighthawks, a CL350, 2004 XL1200R, DL1000, DL650, KLR650, CBR250R, FZ-8, Honda 919 and a VT700C Shadow.
    "Did you know you can ride a Transalp through a wall and not die?"
  4. Remove Advertisements
    FZ09.com
    Advertisements
  5. #14
    Member triman11427's Avatar
    Member #
    3322
    Join Date
    Sep 2014
    Location
    Melville, NY
    Posts
    92
    I would have to reinstall the plate which was removed when installing the R&G Tidy Tail. The PO did the install and I'm planning on getting the OEM parts this week. Once I have everything I can better understand what needs to be done.
    edgyver likes this.
  6. #15
    Member #
    609
    Join Date
    Nov 2013
    Posts
    768
    Quote Originally Posted by triman11427 View Post
    In the mean time, if you get curious and have 5 minutes free, take the seat off & remove the tail fairing bolts nearest the latch mechanism. This will let you gently move the tail plastic aside and unbolt the four bolts holding the seat latch in place. Once those are out, the latch simply lifts out - nothing else is holding it. Have a look at the latch itself and the cable mod install will become apparent. =)
    2014 FZ-09
    Formerly:
  7. #16
    Member #
    609
    Join Date
    Nov 2013
    Posts
    768
    2014 FZ-09
    Formerly:
  8. #17
    Senior Member taoshum's Avatar
    Member #
    1145
    Join Date
    Jan 2014
    Posts
    491
    Quote Originally Posted by edgyver View Post
    I bought a Honda GL1800 right side fairing pocket cable (<$5)and fitted to the lock mechanism. It's a direct snap in installation after you take the lock plate off and loosen the latch mechanism bolts a bit first. Once in place and tightened back up, I routed the cable to come out near the regulator rectifier with a black plastic electrical tie fashioned into a pull loop and attached with some heat shrink tubing to the free end of the cable. It's really easy to use and convenient, too.
    Put one on your bike and you won't need the key lock.
    Attachment 10638 Attachment 10639 Attachment 10640 Attachment 10641 Attachment 10642
    What's the part number? That lock thingy is a POC. Thanks.
  9. #18
    Member #
    3322
    Join Date
    Sep 2014
    Location
    Melville, NY
    Posts
    92
    I contacted the PO who doesn't have the OEM setup so it looks like either the latch mod or simple cap is what I'll do. Now that I see how easy it is I'll just do the mod. Thanks
  10. #19
    Member #
    3322
    Join Date
    Sep 2014
    Location
    Melville, NY
    Posts
    92
    I did as you suggested. Ordered the cable. Looks easy peasy. Thanks for the photos, they were a big help.
  11. #20
    Member #
    1145
    Join Date
    Jan 2014
    Posts
    491
    how did you order the cable? I looked at a Honda website parts company and all they know how to process is a part number???
    thx, g
    Wisdom tain't free, We pay for it with Pain
    long ago: Cushman Eagle, Yamahas: Scrambler, RT-1, TT-R; Husky's: 450, 360WR, 430WR;
    Current era: WR250R, HD FLHPI, FZ09 ( RG Sliders, Vario Screen,
    Yamaha bags/rack, Task Grip Heaters, Ram GPS mount, 1st Gear Heatroller
    Acerbis hand guards/Silicon Grips, ZX6RR shock, Mag drain plug, Racetech Springs and damping kit
    Factory 2015 ECU Flash, New SC Seat with non-grip surface, Michelin RP4's
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Luimoto Seat Cover installed - PICS
    By MotovationUSA in forum FZ-09 Gear & Accessories
    Last Post: 07-17-2014, 10:41 AM
  2. Seat cover
    By JEAN-ROCH in forum FZ-09 General Discussion
    Last Post: 07-07-2014, 06:40 AM
  3. Reusing seat lock cover
    By FZ09inBKK in forum FZ-09 Gear & Accessories
    Last Post: 06-09-2014, 08:16 PM
  4. ND a pic of Spring for Seat Lock Cover
    By steviet in forum FZ-09 General Discussion
    Last Post: 05-23-2014, 06:33 PM
  5. Sheep Seat Cover in AU
    By Warrior108 in forum FZ-09 General Discussion
    Last Post: 03-01-2014, 08:22 AM
Search tags for this page
fz09 seat lock cover
seat keycover
