Which coolant?
Close
Login to Your Account
Which coolant?
This is a discussion on Which coolant? within the FZ-09 General Discussion forums, part of the Yamaha FZ-09 Forums category; Hello, I have a 2014 FZ-09 I want to flush the cooling system, and re-fill. What coolant can I use? I am unable to acquire ...
Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Like Tree8Likes
Thread: Which coolant?
  1. #1
    AJ.
    AJ. is offline
    Member AJ.'s Avatar
    Member #
    847
    Join Date
    Dec 2013
    Posts
    42
    Question Which coolant?
    Hello,
    I have a 2014 FZ-09
    I am unable to acquire YamaCool in my area.
    And the temperatures here never drop below 60°F.
    Any recommended brand?
    Thank you!
    2014 Yamaha FZ-09
    1986 Yamaha Fazer
    Surfboards
  2. #2
    Senior Member Dpak's Avatar
    Member #
    4056
    Join Date
    Dec 2014
    Location
    Waterford pa.
    Posts
    774
    Engine ice is what I use. It's not cheap though.
  3. #3
    Senior Member mox44ah's Avatar
    Member #
    7177
    Join Date
    Apr 2016
    Location
    New Jersey
    Posts
    224
    Quote Originally Posted by Dpak View Post
    I use Engine Ice too. There was absolutely no change in engine temp though like the company claims. It's not worth it. Just buy your standard coolant at Autozone.
    Lateralus and Crosshairs like this.
  4. Remove Advertisements
    FZ09.com
    Advertisements
  5. #4
    Senior Member Indyzrider's Avatar
    Member #
    7817
    Join Date
    Jun 2016
    Posts
    259
    Use the engine ice....it's good stuff...
  6. #5
    Member GameChanger's Avatar
    Member #
    1483
    Join Date
    Mar 2014
    Location
    Gilbert, AZ
    Posts
    49
    I use Purple Ice by Royal Purple mixed with filtered drinking water. In Phoenix there is no need for me need actual anti-freeze
  7. #6
    Senior Member CRFan1's Avatar
    Member #
    117
    Join Date
    Jul 2013
    Location
    Northwest Indiana
    Posts
    675
    Any aluminum safe anti-freeze works (all are now days). Get some pre-mixed stuff at your local auto parts store.
    Spacecoast, LouG, FZO9 and 1 others like this.
  8. #7
    Senior Member Spacecoast's Avatar
    Member #
    5120
    Join Date
    May 2015
    Posts
    1,717
    I use Peak Long-Life coolant in all my vehicles, available as either full strength (mix with distilled water) or already pre-diluted. Its sold at Target, Home Depot, Walmart, etc. They also have a tech help-line 1 800 number.
    CRFan1 and FZO9 like this.
  9. #8
    Senior Member Desert Rat's Avatar
    Member #
    1854
    Join Date
    Apr 2014
    Location
    Tucson, AZ
    Posts
    1,419
    Unless you are over heating, no coolant will reduce the operating temperature because the thermostat will insure it reaches normal temp no matter how much better a coolant might conduct heat.
    INVENTOR of DIRT
  10. #9
    Senior Member FZO9's Avatar
    Member #
    6200
    Join Date
    Oct 2015
    Posts
    829
    Quote Originally Posted by Spacecoast View Post
    peak 50/50. says its safe for motorcycles on the label. if you dont get pre-mixed remember you have 2 dilute the concentrated antifreeze as mentioned above,
    the only reason I would buy regular antifreeze concentrate (not 50/50 premixed/ready to use) is
    *if I had to make a bunch of antifreeze to refill a engine block and radiator, you can make two gallons of 50/50 antifreeze out of one gallon of regular concentrate antifreeze. thats the only advantage of buying concentrate.
    I'm thinking one gallon of 50/50 would be enough to fill the FZ's radiator back up.
    also check your manual that came with the motorcycle. it will tell you how many gallons it will take to refill after flushing the radiator.
  11. #10
    Junior Member Agwag's Avatar
    Member #
    21585
    Join Date
    May 2017
    Location
    Boston
    Posts
    20
    Personal pref. Engine ice
    Sent from my iPhone over the
    '05 CBR600RR sold
    '15 GROM sold
    '14 Ninja 300ABS track
    '16 FZ-09
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Coolant Change
    By Hawkerjet in forum Yamaha FZ-09 Guides and How-To's
    Last Post: 04-03-2017, 03:03 PM
  2. What kind of Coolant
    By mox44ah in forum FZ-09 General Discussion
    Last Post: 08-29-2016, 12:13 PM
  3. Coolant question
    By superman242242 in forum FZ-09 General Discussion
    Last Post: 08-06-2016, 07:32 AM
  4. Help...What is this stuff? (coolant)
    By Beantown in forum Yamaha FZ-09 Common Problems/Issues
    Last Post: 08-26-2015, 09:51 AM
  5. What color of coolant do you use?
    By Madgelo in forum FZ-09 General Discussion
    Last Post: 07-20-2014, 12:55 AM
