Toce Exhasust
Close
Login to Your Account
Toce Exhasust
This is a discussion on Toce Exhasust within the FZ-09 General Discussion forums, part of the Yamaha FZ-09 Forums category; Hi Guys, Im looking into getting a Toce exhaust (slip-on) Would I need to do an Engine tune as well? Any recommendations?...
Results 1 to 7 of 7
Thread: Toce Exhasust
  1. #1
    Alf
    Alf is offline
    Junior Member Alf's Avatar
    Member #
    15442
    Join Date
    Dec 2016
    Posts
    6
    Toce Exhasust
    Hi Guys,
  2. #2
    Member FZ09RIDERR's Avatar
    Member #
    6881
    Join Date
    Mar 2016
    Location
    Portland Oregon
    Posts
    32
    Definitely get a tune.
  3. #3
    Alf
    Alf is offline
    Member #
    15442
    Join Date
    Dec 2016
    Posts
    6
    Alright, do you have any recommendations?
  4. Remove Advertisements
    FZ09.com
    Advertisements
  5. #4
    Member #
    6881
    Join Date
    Mar 2016
    Location
    Portland Oregon
    Posts
    32
    There is several on this forum that you can mail your ecu to. I went with 2wheel dyno works since he was more local and was actually able to get a dyno run.
  6. #5
    Alf
    Alf is offline
    Member #
    15442
    Join Date
    Dec 2016
    Posts
    6
    Oh okay, sounds cool. I thought I had to do one of those flash tunes, or whatever they are called.. Powercommander or Bazzaz? (this is my first bike with Injectors and any type of electronics, so Im pretty new in this field.)
  7. #6
    Member #
    6881
    Join Date
    Mar 2016
    Location
    Portland Oregon
    Posts
    32
    Don't need any of the fuel controllers, the flash tune takes care of all of it. A flash changes fuel and ignition tunes along with disabling the speed restriction. Your also can select which model to start up in, enable quickshifter function. Your throttle will be smoother even in A mode.
  8. #7
    Member #
    6881
    Join Date
    Mar 2016
    Location
    Portland Oregon
    Posts
    32
    FYI, I have a Raven 2016 with akrapovic carbon. Got the flash done then had a couple small complaints over the summer and had it rechecked and run on dyno when Nels (2wheeldynoworks he has a dyno trailer) was in the area . He simply unplugged the O2 sensor to fix complaints. I then bought a quick shifter kit and a active tune kit (look up FTECU) . Smoother idle and throttle inputs.
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Toce Performance first ever exhaust for FZ-09
    By Blackfz09 in forum FZ-09 Gear & Accessories
    Last Post: 08-13-2016, 11:15 AM
