Help with this problem.
Close
Login to Your Account
This is a discussion on Help with this problem. within the FZ-09 General Discussion forums, part of the Yamaha FZ-09 Forums category; My bike scared the crap out of me today multiple times by the engine stalling unpredictability. I rode home as gingerly as possible but the ...
Page 1 of 2 12 LastLast
Results 1 to 10 of 18
Like Tree17Likes
Thread: Help with this problem.
  1. #1
    Member 405 South's Avatar
    Member #
    11881
    Join Date
    Sep 2016
    Posts
    41
    My bike scared the crap out of me today multiple times by the engine stalling unpredictability. I rode home as gingerly as possible but the engine stalled several times under strange circumstances.
    Stall number one happened after deceleration while I was going to pull into a parking spot, I pulled in he clutch and then while still moving the engine stalled. It took multiple cranks on the starter to restart.
    Decelerating to a stoplight I clutch in and again while moving engine dies. After one crank engine restarts and I try to accelerate into first gear bike stalls. Restart, bike bogs and misses with minimal throttle, then after more throttle the bike wheelies five feet then falls on its face and bogs again. I pull over and bike seems to be fine after a curbside inspection. Nothing suspicious from the outside.
    I decide to ride the bike home gingerly at this point, better to limp home than wait for a tow.
    Bike dies again in third gear rolling, again when decelerating when traffic ahead of me slowed to a crawl. After two starter attempts engine restarts. Again engine bogs and sputtered in first then power surged to make another in wanted wheelie. And again after standing up engine dies and I drag the back tire to the side of the road.
    Wtf. I bet every car on the road must have thought I was a complete dumbass.
    Bike is now home but I am looking for suggestions as to where to hunt for this gremlin. Two days ago my bike was fine and rode a good 50 miles without any issues.
    Does anyone else think the little yellow triangles on the cars mirrors are cool when they light up for you?
  2. #2
    Senior Member krisfz's Avatar
    Member #
    13434
    Join Date
    Oct 2016
    Posts
    210
    clean your clutch switch out
  3. #3
    Senior Member gsatterw's Avatar
    Member #
    6342
    Join Date
    Oct 2015
    Location
    Baton Rouge, LA
    Posts
    993
    Quote Originally Posted by krisfz View Post
    Having a hard time seeing how this is a clutch switch issue. The clutch switch only matters when you are starting the bike in gear. It is open and closed all the time during normal operation.
    That being said I'm not sure what OP's issue is. Maybe fouled plugs? Coil going bad? Kink in a fuel/vacuum/breather line?
    OP what mod's are you running? Any fueling related?
  4. Remove Advertisements
    FZ09.com
    Advertisements
  5. #4
    Member #
    11881
    Join Date
    Sep 2016
    Posts
    41
    I do have a reflash, but I have done nothing mechanical to the bike in a month. Lotta rainy days lately.
  6. #5
    Member #
    11881
    Join Date
    Sep 2016
    Posts
    41
    I have a feeling it is something electrical, will double check electrical connections. This problem seems to be a mystery to me, I haven't changed anything in over a month, yet something sure is wrong..
  7. #6
    Senior Member Crossbar1773's Avatar
    Member #
    13530
    Join Date
    Oct 2016
    Location
    Huntington, WV
    Posts
    251
    Has it been sitting for awhile? Have you put fuel stabilizer in the tank? The obvious thing is water in gas maybe?
  8. #7
    Member #
    11881
    Join Date
    Sep 2016
    Posts
    41
    Think I may have found it. Bad battery terminal. It wiggles. I found it when I plugged in my battery tender and something was making an audible high frequency noise from the battery when on the charger. I shook the cables and the battery terminal moved with the cables, but the battery didn't move. I guess I need a new battery.
  9. #8
    Senior Member MoFZio's Avatar
    Member #
    1985
    Join Date
    Apr 2014
    Location
    Saratoga Springs, NY
    Posts
    1,392
    Good find, bro!
    Enjoy.
    Machine: Red '14 FZ09
    WARNING: This bike will put a permanent smile on your face!
  10. #9
    Senior Member Keef's Avatar
    Member #
    2010
    Join Date
    Apr 2014
    Location
    Sydney Australia
    Posts
    1,860
    Quote Originally Posted by 405 South View Post
    Who did the reflash? Probably worth talking to them as well.
  11. #10
    Gold Supporting Member
    Supporting Member
    Crosshairs's Avatar
    Member #
    2174
    Join Date
    May 2014
    Posts
    2,026
    Quote Originally Posted by Keef View Post
    Vcyclenut did his flash about 2 months ago
    2014 FZ09 Mods> Ivans ECU Flash....... Penske 8983....... GP fork piston kit.......Woodcraft Frame Sliders....Woodcraft Axle Sliders ...Woodcraft Engine guards...Chinese spools...
    Spiegler SS brake lines .....APE CC tensioner .....Antigravity AG-801 Battery......tripage LED headlight.......tripage LED pegs ...Watsen Design front turn signals..and some other stuff I dont feel like listing
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. 1 Finger? No problem
    By karimy in forum FZ-09 Gear & Accessories
    Last Post: 07-02-2016, 01:53 PM
  2. Problem
    By DECON BLUE in forum FZ-09 General Discussion
    Last Post: 03-28-2016, 12:19 PM
  3. Anyone else have this problem?
    By threesvts in forum FZ-09 Performance & Suspension
    Last Post: 08-24-2015, 03:10 PM
  4. Shut off problem
    By CJD in forum Yamaha FZ-09 Common Problems/Issues
    Last Post: 07-04-2015, 07:22 PM
  5. FZ-09 problem?
    By twelvehundo in forum FZ-09 General Discussion
    Last Post: 10-21-2013, 10:16 AM
