Help with this problem. - Page 2
Close
Login to Your Account
This is a discussion on Help with this problem. within the FZ-09 General Discussion forums, part of the Yamaha FZ-09 Forums category; Had the same type of problems on a friend's Honda a year or so ago. The bike would bog, die and act all kinds of ...
Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Like Tree17Likes
Thread: Help with this problem.
  1. #11
    Senior Member quickstang87's Avatar
    Member #
    5666
    Join Date
    Jul 2015
    Location
    Glendale, AZ
    Posts
    144
    Had the same type of problems on a friend's Honda a year or so ago. The bike would bog, die and act all kinds of messed up. I found the negative terminal bolt had come undone from the battery and the cables were only making partial contact. It ran like new after fixing it.
  2. #12
    Member 405 South's Avatar
    Member #
    11881
    Join Date
    Sep 2016
    Posts
    79
    It was the battery, the negative terminal somehow became loose, inside the battery. New battery in, and smooth sailing again.
    Does anyone else think the little yellow triangles on the cars mirrors are cool when they light up for you?
  3. #13
    Member carzcarzcarz's Avatar
    Member #
    6582
    Join Date
    Jan 2016
    Location
    Houston, Texas
    Posts
    44
    Great to hear you found the problem and fixed it, and thanks for reporting back on it.
    shamrock likes this.
  4. Remove Advertisements
    FZ09.com
    Advertisements
  5. #14
    Senior Member Crossbar1773's Avatar
    Member #
    13530
    Join Date
    Oct 2016
    Location
    Huntington, WV
    Posts
    569
    Good job man, kudos
  6. #15
    Member #
    131
    Join Date
    Jul 2013
    Location
    Merced, CA
    Posts
    2,319
    Quote Originally Posted by 405 South View Post
    Think I may have found it. Bad battery terminal. It wiggles. I found it when I plugged in my battery tender and something was making an audible high frequency noise from the battery when on the charger. I shook the cables and the battery terminal moved with the cables, but the battery didn't move. I guess I need a new battery.
    Have you cleaned the battery terminals and cables with a wire brush and tighten the terminals?
  7. #16
    Senior Member Tigershark's Avatar
    Member #
    2931
    Join Date
    Jul 2014
    Location
    West Bend, WI
    Posts
    3,234
    Just occurred to me that you may want to check your seat clearance to battery terminals. Unintentional contacts or hits while riding could have caused the battery damage.
    You can't have everything. Where would you put it?
  8. #17
    Member #
    11881
    Join Date
    Sep 2016
    Posts
    79
    Quote Originally Posted by Tigershark View Post
    Good idea to check the clearance, I am using a different seat than stock. But I shouldn't take that for granted. I have a German Yamaha mt09 comfort seat that the previous owner installed.
    It passed the silly putty test. Greater than a half inch. I guess all batteries will eventually die, this one seemed to go in a strange way. The terminal looked clean, just was loose where it went into the batteries innards.
  9. #18
    Senior Member Spacecoast's Avatar
    Member #
    5120
    Join Date
    May 2015
    Posts
    1,717
    Quote Originally Posted by motomania View Post
    If I understand it correctly, it was an internal problem with the battery rather than a loose terminal/cable connection.
    Desert Rat likes this.
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. 1 Finger? No problem
    By karimy in forum FZ-09 Gear & Accessories
    Last Post: 04-28-2017, 09:26 AM
  2. Problem
    By DECON BLUE in forum FZ-09 General Discussion
    Last Post: 03-28-2016, 11:19 AM
  3. Anyone else have this problem?
    By threesvts in forum FZ-09 Performance & Suspension
    Last Post: 08-24-2015, 02:10 PM
  4. Shut off problem
    By CJD in forum Yamaha FZ-09 Common Problems/Issues
    Last Post: 07-04-2015, 06:22 PM
  5. FZ-09 problem?
    By twelvehundo in forum FZ-09 General Discussion
    Last Post: 10-21-2013, 09:16 AM
