Fixed my seat in 10 minutes. Why didn't I do this sooner?
Close
Login to Your Account
This is a discussion on Fixed my seat in 10 minutes. Why didn't I do this sooner? within the FZ-09 General Discussion forums, part of the Yamaha FZ-09 Forums category; Amongst the numerous things that bother me unless I constantly think about how cheap the FZ-09 was is the stupid loose/rattly/down-sloping seat. So I finally ...
Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Like Tree9Likes
Thread: Fixed my seat in 10 minutes. Why didn't I do this sooner?
  1. #1
    Senior Member Nimbus's Avatar
    Member #
    2660
    Join Date
    Jun 2014
    Posts
    195
    Amongst the numerous things that bother me unless I constantly think about how cheap the FZ-09 was is the stupid loose/rattly/down-sloping seat. So I finally got irritated enough to do something about it. I know people have used furniture foot pads, but I just used electrical tape. I took about 18" and just kept wrapping about a 3/4" "square" until it was sufficiently thick. Then I did a matching square and I taped them on the frame area where the rubber seat pads sit. It's stinking awesome how much more comfortable the seat is. Best 10 minutes I've spent in a long time.
    Tigershark likes this.
  2. #2
    Member yamasaki's Avatar
    Member #
    5680
    Join Date
    Jul 2015
    Posts
    60
    i just spent $409 to fix mine
    Evol likes this.
  3. #3
    Senior Member gsatterw's Avatar
    Member #
    6342
    Join Date
    Oct 2015
    Location
    Baton Rouge, LA
    Posts
    1,018
    Pics!
    crheming likes this.
  4. Remove Advertisements
    FZ09.com
    Advertisements
  5. #4
    Gold Supporting Member
    Supporting Member
    Rocky_MTN_FZ09's Avatar
    Member #
    3317
    Join Date
    Sep 2014
    Location
    Calgary, AB Canada
    Posts
    3,421
    I tried a couple quick fixes as well, but found this was the best long term fix.
    Seat mod (reduce the forward slope)
    The problem with using tape or glue, is the heat of the engine melts the glue into a mess.
    FZweasel likes this.
    Ride to work, work to ride.
  6. #5
    Member #
    2660
    Join Date
    Jun 2014
    Posts
    195
    Quote Originally Posted by Rocky_MTN_FZ09 View Post
    I'll have to keep an eye on it, but I'd hope electrical tape won't melt.
  7. #6
    Supporting Member
    Member #
    3317
    Join Date
    Sep 2014
    Location
    Calgary, AB Canada
    Posts
    3,421
    Quote Originally Posted by Nimbus View Post
    The tape won't melt, but the glue will become soft and not hold very well. It's all the heat off the engine that messes up any glue. I find Permatex RTV Silicone works better than glue to help hold things in place.
    Bucket Jumper likes this.
  8. #7
    Senior Member Bucket Jumper's Avatar
    Member #
    5706
    Join Date
    Jul 2015
    Location
    TX
    Posts
    127
    So does your wife's nail polish. Best thing for making electrical tape steadfast. It will NEVER come off unless you force it. Heat, oil, etc. That stuff is tenacious !! even under heat !!!
  9. #8
    Member #
    131
    Join Date
    Jul 2013
    Location
    Merced, CA
    Posts
    2,241
    Quote Originally Posted by Bucket Jumper View Post
    How does nail polish help electrical tape stay put?
  10. #9
    Member #
    5706
    Join Date
    Jul 2015
    Location
    TX
    Posts
    127
    I don't the chemistry or physics involved, but it dries HARD. Use clear nail polish. It encapsulates the tape and adhesive. The electrical tape cannot/will not peel, slough,move,slip etc, etc, etc.
    PVC cement works equally well, however is a bit more difficult to work with in delicate situations due to the size of the applicator. But PVC cement works extremely well
    Provided that the piece you are applying it to does not experience excessive movement ( bending, stretching, you get the picture )
  11. #10
    Senior Member Rapido1's Avatar
    Member #
    6638
    Join Date
    Jan 2016
    Location
    Cabo San Lucas, Baja
    Posts
    559
    Mankind's ingenuity amazes me! Wadded up electrical tape - wow!
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. things didn't go as planned:(
    By thrstrmech in forum FZ-09 General Discussion
    Last Post: 02-12-2017, 07:01 AM
  2. I fixed my Yamaha!
    By bennyblanco in forum Other Bikes
    Last Post: 05-24-2016, 06:04 PM
  3. Yamaha's next unveiling starting in 2 minutes!
    By BenCOfz09 in forum Off-Topic
    Last Post: 11-16-2015, 08:31 PM
  4. Sooner or later (First Drop)
    By Jorckio in forum FZ-09 General Discussion
    Last Post: 06-27-2014, 10:59 AM
  5. 6 Minutes of Joy
    By NickJ in forum Off-Topic
    Last Post: 06-26-2013, 01:14 PM
