2016 to 2017 FZ-09 Parts fitment?
Close
Login to Your Account
This is a discussion on 2016 to 2017 FZ-09 Parts fitment? within the FZ-09 General Discussion forums, part of the Yamaha FZ-09 Forums category; Hey guys! Just put a deposit down on a Matte Silver 2017 FZ-09. Wondering if any of you know if fitment for parts (i.e. windscreens, ...
Page 1 of 2 12 LastLast
Results 1 to 10 of 16
Like Tree1Likes
Thread: 2016 to 2017 FZ-09 Parts fitment?
  1. #1
    Junior Member spencerh26's Avatar
    Member #
    13354
    Join Date
    Oct 2016
    Location
    San Diego, CA
    Posts
    20
    Hey guys! Just put a deposit down on a Matte Silver 2017 FZ-09. Wondering if any of you know if fitment for parts (i.e. windscreens, exhausts...) will stay standard from the prior year model. I would assume everything would fit the same, but I know they made some pretty major design changes that may throw off windscreen/tail tidy fitment from the PY models.
  2. #2
    Gold Supporting Member
    Supporting Member
    Rocky_MTN_FZ09's Avatar
    Member #
    3317
    Join Date
    Sep 2014
    Location
    Calgary, AB Canada
    Posts
    3,328
    Looking at the pictures of a 2016 vs 2017, I think the only major changes are bodywork. Which makes me think the headlight mounted windscreens will be different.
    For the exhaust, you might have to wait a bit to get the ECU flashed to suit the exhaust. I say that because the ECU flash might be different from the FJ-09 and XSR, since the 2017 comes with the option for a Yamaha plug in quick shift???
    Other than that, there are already some sights listing aftermarket parts for the 2017 FZ-09.
    https://www.motostarz.com/filter-by-...html/?cat=1622
    Ride to work, work to ride.
  3. #3
    Member Old Guys Rule's Avatar
    Member #
    3675
    Join Date
    Oct 2014
    Posts
    30
    Quote Originally Posted by Rocky_MTN_FZ09 View Post
    Slipper/assist clutch is compatible. ABS and TC are not. Headlight and body work can likely be retrofitted.
  4. Remove Advertisements
    FZ09.com
    Advertisements
  5. #4
    Senior Member thrstrmech's Avatar
    Member #
    5326
    Join Date
    Jun 2015
    Location
    Phoenix, AZ
    Posts
    1,159
    after looking at many pics of the 2017, things that have changed: headlights, scoops, seat, tail light, turn signals, exhaust pipe cover and tail rear plastics. read somewhere the seat has changed some, that's why I listed it. until a parts catalog/manual is available, all we can do is speculate...I lean towards most parts being compatible between the year models.
    If you don't like the headlight, I'll swap with you and throw in the LED light
  6. #5
    Member #
    5326
    Join Date
    Jun 2015
    Location
    Phoenix, AZ
    Posts
    1,159
    speedometer bracket is the same, just relocated lower...bar clamps are the same with nothing mounted to them?
    FazeNiner likes this.
  7. #6
    Member #
    5326
    Join Date
    Jun 2015
    Location
    Phoenix, AZ
    Posts
    1,159
  8. #7
    Senior Member troop's Avatar
    Member #
    6144
    Join Date
    Sep 2015
    Location
    Stoughton, WI
    Posts
    1,608
    I wonder how much the OEM rear mud guard will cost? Looking hard at this ebay one for around $100.
    Attached Thumbnails Attached Thumbnails 2016 to 2017 FZ-09 Parts fitment?-s-l1600-10-.jpg
  9. #8
    Member #
    13354
    Join Date
    Oct 2016
    Location
    San Diego, CA
    Posts
    20
    Good points guys. I love the new headlights... About 30% of the reason I decided to drop the extra 1.5-2K on the new model. How bad would it be to throw on an aftermarket exhaust w/o an ECU flash? Definitely getting an aftermarket exhaust, putting on the quickshifter, windscreen, and maybe changing the rearsets for something a little higher. Will have to see if the new shocks are good enough to keep. So excited for this bike.
  10. #9
    Member jlowsho's Avatar
    Member #
    9913
    Join Date
    Aug 2016
    Posts
    50
    I have the akra carbon on mine with blockoff plates and it runs perfectly.
  11. #10
    Supporting Member
    Member #
    3317
    Join Date
    Sep 2014
    Location
    Calgary, AB Canada
    Posts
    3,328
    You might have to wait a bit for a windscreen, the mounting bolt pattern has changed quite a bit.
    If you look closely the mounting bolts on the 2016 are outside the ignition switch, while on the 2017 the bolts are more inline with the ignition switch. So the horizontal spacing has decreased quite a bit.
    The location of the lowered instrument cluster on the 2017 might also cause interference, with 2016 windscreens???
    It might be easier to wait until someone comes out with a 2017 specific windscreen.
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Winter 2016/2017 Mods?
    By troop in forum FZ-09 General Discussion
    Last Post: 12-14-2016, 01:27 PM
  2. 2017 MT-10 SP Edition
    By GhengisT in forum Other Bikes
    Last Post: 10-07-2016, 05:44 PM
  3. Buell Clubmans and windscreen fitment
    By Sproink in forum FZ-09 General Discussion
    Last Post: 07-09-2016, 12:50 PM
  4. SC Project Exhaust for FZ09 fitment..
    By PATBAROK in forum XSR900 General Discussion
    Last Post: 06-16-2016, 04:05 PM
  5. Driven D3 Grip Installation/Fitment
    By Mejetski2000 in forum FZ-09 Gear & Accessories
    Last Post: 08-11-2014, 09:15 PM
Search tags for this page
2017 fz 09 headlight
2017 fz09 parts
2017 fz09 windscreen
2017 mt-09 windscreen
2017 yamaha fz-09
