metal dust in oil
Close
Login to Your Account
metal dust in oil
This is a discussion on metal dust in oil within the Yamaha FZ-09 Common Problems/Issues forums, part of the Yamaha FZ-09 Garage category; doing an oil change few days ago draining and took a light up to the oil and found small micro sized specs in the oil ...
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Like Tree14Likes
Thread: metal dust in oil
  1. #1
    Banned krisfz's Avatar
    Member #
    13434
    Join Date
    Oct 2016
    Posts
    231
    metal dust in oil
    i used mobil 1 full syn for 27000 miles and just recently switched to yamalube convention with yamalube filter
    32000 miles
    i change oil in 4000 intervals
    i can look in through the oil fill cap and 300 miles after oil change there is more specs, recently replaced the clutch 5000 miles ago
    i was wondering if this is nornal and what everybody else finds in their oil, bike runs perfect apart from the cct making noise on cold starts
  2. #2
    Member #
    13434
    Join Date
    Oct 2016
    Posts
    231
    heres a pic
    i had a hard time getting the camera to pick it up
    Attached Thumbnails Attached Thumbnails metal dust in oil-image_1487202565838.jpg
  3. #3
    Senior Member Crossbar1773's Avatar
    Member #
    13530
    Join Date
    Oct 2016
    Location
    Huntington, WV
    Posts
    528
    Valve check or adjustment?
  4. Remove Advertisements
    FZ09.com
    Advertisements
  5. #4
    Senior Member LouG's Avatar
    Member #
    5709
    Join Date
    Jul 2015
    Location
    Nelson, New Zealand
    Posts
    2,249
    It's hard to tell what it is. Drop the oil pan and have a look at the strainer, pick up and bottom of the pan.
    '14 MT 09
    Andreanni Cartridge kits
    Nitron Road and Track Shock
    Givi screen
    Renthal McGrath bend Bars.
    V1+YaV1 Licence protector
    SW Motech Quicklock Tankbag.
    Kevxtx O2 Controller.
    Custom Chain Oiler
    El Cheapo Chinese levers.
  6. #5
    Member #
    13434
    Join Date
    Oct 2016
    Posts
    231
    valve check was done 7000 miles ago
    nothing in the strainer or pan
  7. #6
    Senior Member Steve H's Avatar
    Member #
    14834
    Join Date
    Nov 2016
    Location
    Perth WA
    Posts
    149
    There will be microscopic pieces of metal in any new machine..in your case I would think its tiny pieces of new clutch plate. If it bothers you do as Lou says and drop the sump for a closer inspection.
    Smoke me a kipper I'll be home in time for breakfast
  8. #7
    Senior Member Punkinhead's Avatar
    Member #
    8186
    Join Date
    Jul 2016
    Posts
    145
    If you're concerned then send a sample to a place like Blackstone Labs for analysis. Otherwise you're just guessing.
    raydeightor and TT_FZ like this.
  9. #8
    Member #
    13434
    Join Date
    Oct 2016
    Posts
    231
    sump is clean
    strainer is clean
  10. #9
    Senior Member Crosshairs's Avatar
    Member #
    2174
    Join Date
    May 2014
    Posts
    2,082
    Quote Originally Posted by Punkinhead View Post
    This is the best advice...they will tell you exactly whats going on..Its $25.00 and its money well spent.
    2014 FZ09 Mods> Ivans ECU Flash....... Penske 8983....... GP fork piston kit.......Woodcraft Frame Sliders....Woodcraft Axle Sliders ...Woodcraft Engine guards...Chinese spools...
    Spiegler SS brake lines .....APE CC tensioner .....Antigravity AG-801 Battery......tripage LED headlight.......tripage LED pegs ...Watsen Design front turn signals..and some other stuff I dont feel like listing
  11. #10
    Member #
    13434
    Join Date
    Oct 2016
    Posts
    231
    i dony feel the need for an oil analysts
    just wanna know if when you guys check your oil out with a light if you find anything in your oil
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Metal Shavings!
    By FMG900 in forum XSR900 Common Problems/Issues
    Last Post: 06-21-2016, 09:09 AM
  2. Thinking about a metal oil filter
    By dcnblues in forum FZ-09 Performance & Suspension
    Last Post: 05-22-2015, 12:00 AM
  3. FS: Dainese Full Metal RS - XS
    By whistleillshoot in forum Parts for Sale / Wanted
    Last Post: 03-25-2015, 02:41 PM
  4. Metal Shavings in Oil
    By Th3 VVay in forum FZ-09 General Discussion
    Last Post: 04-21-2014, 01:36 PM
