metal dust in oil - Page 3
Close
Login to Your Account
metal dust in oil
This is a discussion on metal dust in oil within the Yamaha FZ-09 Common Problems/Issues forums, part of the Yamaha FZ-09 Garage category; mine is not nearly as bad as that travis i have to be shining a light and looking close to see it...
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 32
Like Tree14Likes
Thread: metal dust in oil
  1. #21
    Banned krisfz's Avatar
    Member #
    13434
    Join Date
    Oct 2016
    Posts
    231
  2. #22
    Senior Member gsatterw's Avatar
    Member #
    6342
    Join Date
    Oct 2015
    Location
    Baton Rouge, LA
    Posts
    1,018
    Your bike is trashed, pretty much totaled I'll haul it off for a $150 fee, you're welcome.
    Desert Rat likes this.
  3. #23
    Senior Member LouG's Avatar
    Member #
    5709
    Join Date
    Jul 2015
    Location
    Nelson, New Zealand
    Posts
    1,948
    Sparkly? You've got disco oil!
    '14 MT 09
    Andreanni Cartridge kits
    Nitron Road and Track Shock
    Givi screen
    Renthal McGrath bend Bars.
    V1+YaV1 Licence protector
    SW Motech Quicklock Tankbag.
    Kevxtx O2 Controller.
    Custom Chain Oiler
  4. Remove Advertisements
    FZ09.com
    Advertisements
  5. #24
    Member Steve H's Avatar
    Member #
    14834
    Join Date
    Nov 2016
    Location
    Perth WA
    Posts
    83
    Personally I think you are worrying about nothing. An oil filter traps small particles and any that are not would be so insignificant to cause no problems. As you stated non of the particles are magnetic and you just fitted a new clutch so it is highly likely to be bedding in debris from that. I would question why a bike with such low mileage needed a new clutch...wheelies?? if so you would do better checking your fork seals.
    Smoke me a kipper I'll be home in time for breakfast
  6. #25
    Member #
    13434
    Join Date
    Oct 2016
    Posts
    231
    fork seals are dry as wood
    which is impressive as how many stoppies i do
  7. #26
    Senior Member Hawkerjet's Avatar
    Member #
    1144
    Join Date
    Jan 2014
    Location
    Shake and Bake Cali...aka Fresno
    Posts
    1,655
    Quote Originally Posted by krisfz View Post
    doing an oil change few days ago draining and took a light up to the oil and found small micro sized specs in the oil
    i used mobil 1 full syn for 27000 miles and just recently switched to yamalube convention with yamalube filter
    32000 miles
    i change oil in 4000 intervals
    i can look in through the oil fill cap and 300 miles after oil change there is more specs, recently replaced the clutch 5000 miles ago
    i was wondering if this is nornal and what everybody else finds in their oil, bike runs perfect apart from the cct making noise on cold starts
    I would go back to Mobil 1. It's a much better oil than Yamalube.
    Check out how Yamalube compairs with Mobil 1 on the test results. You will need to scroll down quite a ways to see the test results.
    Everything you ever wanted to know about oil
    LouG likes this.
    Cookin Wid Gas
  8. #27
    Senior Member Punkinhead's Avatar
    Member #
    8186
    Join Date
    Jul 2016
    Posts
    135
    I call BS. Stoppies require using the front brake.
    Crosshairs, gsatterw, Dpak and 1 others like this.
  9. #28
    Member #
    13434
    Join Date
    Oct 2016
    Posts
    231
    Quote Originally Posted by Hawkerjet View Post
    32000 miles
    exactly what im planning on doing
    question is should I continue using yamalube filter?
  10. #29
    Member #
    14834
    Join Date
    Nov 2016
    Location
    Perth WA
    Posts
    83
    I would use the Yamaha one...no reason not to....also I used semi synthetic in mine at 5000k's and it didnt run as smoothly with that stuff in...recently did the 12month service and switched back to Yamalube and the motor sounds better....never had this before but hey it might just be my old ears making shit up. Once my bike is out of warranty I intend to use Fuch Silkoline comp 4 motorcycle oil. I have used this for years in my previous bikes with good results.
  11. #30
    Member #
    13434
    Join Date
    Oct 2016
    Posts
    231
    my bike shifts smooth as butter with the yamalube conventional
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Metal Shavings!
    By FMG900 in forum XSR900 Common Problems/Issues
    Last Post: 06-21-2016, 09:09 AM
  2. Thinking about a metal oil filter
    By dcnblues in forum FZ-09 Performance & Suspension
    Last Post: 05-22-2015, 12:00 AM
  3. FS: Dainese Full Metal RS - XS
    By whistleillshoot in forum Parts for Sale / Wanted
    Last Post: 03-25-2015, 02:41 PM
  4. Metal Shavings in Oil
    By Th3 VVay in forum FZ-09 General Discussion
    Last Post: 04-21-2014, 01:36 PM
