ZX10 rear shock - Page 3
Close
Login to Your Account
ZX10 rear shock
This is a discussion on ZX10 rear shock within the Yamaha FZ-09 Guides and How-To's forums, part of the Yamaha FZ-09 Garage category; Swapping spring is very easy. If you don't have the right tooling the stealership could do it for you for few $$$. Sent from my ...
Page 3 of 42 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 414
Like Tree189Likes
Thread: ZX10 rear shock
  1. #21
    Supporting Vendor marthy's Avatar
    Member #
    513
    Join Date
    Oct 2013
    Location
    Jupiter, FL
    Posts
    2,989
  2. #22
    Member andmoon's Avatar
    Member #
    543
    Join Date
    Oct 2013
    Location
    NU JOISY
    Posts
    67
    Do you what year zx14s?
  3. #23
    Senior Member 1962siia88's Avatar
    Member #
    534
    Join Date
    Oct 2013
    Location
    Crockett
    Posts
    554
    There are a bunch of pages out there dedicated to the sv650 rear shock swap.
    https://docs.google.com/spreadsheet/...COvG24gH#gid=1
    This link is a chart someone put together about the different popular shocks. Our shock is 13" eye to eye so about the same length as these. I dont claim anything here as accurate, so proceed at your own risk.
    Daniel
    marthy, ktk_ace, Holios551 and 1 others like this.
  4. Remove Advertisements
    FZ09.com
    Advertisements
  5. #24
    Member #
    513
    Join Date
    Oct 2013
    Location
    Jupiter, FL
    Posts
    2,989
    Just gotta be careful here. The main reason I went with the 2008-10 is the offset canister to clear the plastic under tray.
    But nice find here... from what I found my spring is a 9.1kg/mm... 510 lb/in.
    Steve101 likes this.
  6. #25
  7. #26
    Member #
    534
    Join Date
    Oct 2013
    Location
    Crockett
    Posts
    554
    Well I just purchased a 2006 zx6r rear shock. I'll let everyone know how it goes. If the interwebs is correct then this shock should be .2" longer than stock and should be sprung better for my weight range. I'll need to remove my evap can now. $39 delivered on ebay! Definitely worth the risk to me.
    Daniel
    marthy and ktk_ace like this.
  8. #27
    Member #
    513
    Join Date
    Oct 2013
    Location
    Jupiter, FL
    Posts
    2,989
    2004 seems to have a stiffer spring... cheap one in flee bay available.
  9. #28
    Senior Member giebsfz's Avatar
    Member #
    811
    Join Date
    Dec 2013
    Location
    Howell, NJ
    Posts
    193
    so I installed a 2008 zx10r shock today. trimmed the plastic tray to clear the reservoir, but didn't like how the compression adjusters were a pita to get to. turns out you can mount the shock with the reservoir pointing down towards the starter and get a clear strait shot at the adjusters from the right side. at full droop, there is about 1/8" gap between the shock and starter, and as the suspension compresses, you gain clearance. Now im not too sure i could have gotten the shock flipped around that way without trimming the plastic tray back. i guess the next guy to put their shock in can give it a try before cutting it up.
    also found my rear brake line rubbed the paint off the swing arm a little bit although the brake line covers it....
    ktk_ace and Holios551 like this.
  10. #29
    Member #
    513
    Join Date
    Oct 2013
    Location
    Jupiter, FL
    Posts
    2,989
    Upside down work? Sweet... and now zx6r.... you guys rock! Nice to see all the different options.
    zloikish likes this.
  11. #30
    Gold Supporting Member
    Supporting Member
    zloikish's Avatar
    Member #
    639
    Join Date
    Nov 2013
    Location
    San Diego, CA
    Posts
    1,081
    And I just finished yesterday lol I woulda flipped it around.
    Graphite #108 "EARL" 16k Miles Still Going Strong
    Mods: Satin black paint, ZX-10 Shock, Fork Replacement Springs, CREE L.E.D. Headlamp, bullet LED turn signals with front and rear turn signal running lights, Custom LED Brake modulator, Seat Concepts Seat, Tech Spec Tank Grips and tank protector, Pro Taper handlebars(black) Stoltec ECU , OES fork sliders & swing arm sliders, Mad Hornet Gold levers, MRA double bubble, speigler lines, barkbuster s1's, PR4 shoes, Oxford Heated Grips.
    2015 BMW R1200GS BAMF Beemer
    Features and Additions: Cruise, Ride Modes(Suspension, Throttle Response, wheelie control, TC, ABS), Adjustable Wind Screen, Skid Plate, Engine Crash Bars, Expandable Side bags, Integrated GPS, Keyless Ride. Basically an offroad capable, touring, sportbike. But the FZ is still special, so if I can keep it I will.
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Penske Shock Lineup NOW AVAILABLE
    By Stoltec Moto in forum Stoltec Moto
    Last Post: 09-22-2014, 11:59 PM
  2. rear shock replacement
    By andmoon in forum FZ-09 Performance & Suspension
    Last Post: 04-29-2014, 05:35 AM
  3. For Sale: Spiegler Brake Lines (Front and Rear)
    By Alley Oop in forum FZ-09 General Discussion
    Last Post: 12-22-2013, 03:51 PM
  4. Rear Fender Parts & Turn Signals - FREE
    By LehighLuke in forum Parts for Sale / Wanted
    Last Post: 12-20-2013, 09:32 PM
  5. mounting MT-09 rear seatbag
    By YHK in forum FZ-09 Gear & Accessories
    Last Post: 12-07-2013, 11:35 PM
Search tags for this page
2014 fz 09 rear shock mod
fz 09 rear shock
fz 09 rear shock swap
fz 09 zx10 shock
fz 09 zx10r shock
fz-09 zx10 shock
fz09 rear shock swap
yamaha fz-09 rear shock
zx shocks for an fz09
zx-10r rear shock
zx10
zx10 shock sag
zx10r rear shock
zx6rr shock for sale
