Dobek EJK for a 2017 or Power commander?
Close
Login to Your Account
This is a discussion on Dobek EJK for a 2017 or Power commander? within the FZ-09 Performance & Suspension forums, part of the Yamaha FZ-09 Garage category; Hey guys, just bought a 2017 FZ 09. I want to install an aftermarket exhaust right away. Looking for a fuel controller to go in ...
Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Like Tree5Likes
Thread: Dobek EJK for a 2017 or Power commander?
  1. #1
    Junior Member Canuck12's Avatar
    Member #
    23393
    Join Date
    Jun 2017
    Posts
    6
    Hey guys, just bought a 2017 FZ 09. I want to install an aftermarket exhaust right away. Looking for a fuel controller to go in addition to an exhaust so the bike doesn't run lean. Talked to power commander and they don't have any maps yet for the 2017, would 2016 maps work on a 2017 or no? Another option is the Dobek EJK, anyone use this and did it work well for you? I am happy with everything else on the bike, just want to ensure proper fueling so I don't think a ECU flash is necessary. Also I want to be able to easily return to stock without having to mail in my ECU ( I live in northern Canada )
    Thanks for any help
  2. #2
    Junior Member heykat18's Avatar
    Member #
    23521
    Join Date
    Jun 2017
    Location
    Twin Falls, ID
    Posts
    2
    If you're looking at PCV I'd get the auto tune with till PC gets a map for the new FZ09
  3. #3
    Member #
    23521
    Join Date
    Jun 2017
    Location
    Twin Falls, ID
    Posts
    2
    I'd get the auto tune kit with it.
  4. Remove Advertisements
    FZ09.com
    Advertisements
  5. #4
    Supporting Vendor pattonme's Avatar
    Member #
    4898
    Join Date
    Apr 2015
    Location
    Northern VA
    Posts
    521
    Have you looked at/talked to the board vendors? I personally consider the EJK to be decidedly 'meh' compared to a proper re-flash, of which there are at least 3 well known solutions. PC-v has been around a very long time and there is broad support for it at local tuner shops. If you've picked your exhaust solution reach out to vCyclenut and FuelMoto for input.
  6. #5
    Supporting Vendor vcyclenut's Avatar
    Member #
    2695
    Join Date
    Jun 2014
    Location
    fort myers, florida
    Posts
    836
    I would do the flash tune kit before either of them , and not just because I sell them,
    if you get the active tube kit with it, you can make a great fuel map as well as get all the benefits of flashing
    their website is weird so I cant give you a direct link to the products but you can find them here
    https://ftecu.com/
    if you decide to go that way I can save you significantly from msrp
    please visit vcyclenut.com
  7. #6
    Supporting Vendor marthy's Avatar
    Member #
    513
    Join Date
    Oct 2013
    Location
    Jupiter, FL
    Posts
    3,006
    There's plenty of good tune made for about any exhaust out there now, not like the early days where everything had to be done from scratch. You'll get more HP out of the flash with tune for your exhaust than a piggyback tuner alone. I think you can get a better deal if you get your exhaust/flash at the same time too... just saying.
    Autotune is good but it takes time to get it right... and still! Much cheaper to buy expertise and enjoy riding!
    vcyclenut likes this.
  8. #7
    Member #
    23393
    Join Date
    Jun 2017
    Posts
    6
    Thanks a lot for all the input guys, great information. A lot to think about! Vcyclenut I am going to send you a PM
  9. #8
    Supporting Vendor fuelmoto's Avatar
    Member #
    8161
    Join Date
    Jul 2016
    Posts
    23
    Quote Originally Posted by Canuck12 View Post
    Thanks for any help
    The 14-16 and 2017 Power Commander maps are different, for the time being if you go the PC-V route you will either need to add the Auto Tune kit or have a custom dyno, tune done. We will have our 2017 FZ09 bike in a few weeks, we'll develop our PC-V maps and we'll also build some maps for Dynojet to distribute as well. Another option as already noted is an ECU flash, we offer this service as well with same day turnaround. If you feel our products or services may be a good fit you are welcome to visit our website of contact us at 920-423-3309
    Jamie Long - Fuel Moto USA
    info@fuelmotousa.com
    www.fuelmotousa.com
    920-423-3309
  10. #9
    Member #
    23393
    Join Date
    Jun 2017
    Posts
    6
    Great news to hear you will soon be working on PCV maps for the 2017! I am now deciding whether to wait for that or go with a flash. If I install an aftermarket exhaust and run it for a short period of time before I get either a flash or PCV, how bad would this be for the bikes engine? If for example I ran the bike for a month or two lean with an aftermarket exhaust would this be very bad for the bike or is it ok short term?
    Thanks a lot for all your help!
  11. #10
    Member #
    8161
    Join Date
    Jul 2016
    Posts
    23
    Note the PC-V harness needs to be changed slightly for the 2017 FZ09, they will be available the later part of July. If you change exhaust generally speaking you can get by for the time being, however a proper tune will be necessary for optimal running & performance.
    www.fuelmotousa.com
    920-423-3309
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Power Commander V used
    By 405 South in forum Parts for Sale / Wanted
    Last Post: 12-05-2016, 07:18 PM
  2. FS:Power Commander 5
    By kkilmore89 in forum Parts for Sale / Wanted
    Last Post: 01-21-2015, 08:10 PM
  3. Power commander V
    By KyleB in forum FZ-09 Performance & Suspension
    Last Post: 09-29-2014, 09:08 PM
  4. Installed Power Commander V - Now no power to gauges or ECU
    By caffine in forum FZ-09 General Discussion
    Last Post: 06-15-2014, 09:28 AM
  5. power commander
    By dangerousdan in forum FZ-09 General Discussion
    Last Post: 03-18-2014, 11:06 PM
