Side Stand for a lowered XSR900
Close
Login to Your Account
This is a discussion on Side Stand for a lowered XSR900 within the XSR900 Gear & Accessories forums, part of the Yamaha XSR900 Cafe Racer Forum category; I have installed the lowering kit ( by 20-25mm ) and the bike is now quite upright. I once read that installing the MT-09 side ...
Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By yamaman
Thread: Side Stand for a lowered XSR900
  1. #1
    Junior Member wowow44's Avatar
    Member #
    16066
    Join Date
    Jan 2017
    Posts
    1
    I have installed the lowering kit ( by 20-25mm ) and the bike is now quite upright. I once read that installing the MT-09 side stand will solve the issue as the 09 stand is shorter. I went ahead and ordered a 09 stand and the item looks identical to the one in the 900. Then I checked the parts catalogue and found that the 900 and 09 usues the same side stand with part# 1RC-27311-00. My questions are : 1/. any knows if the 07 stand is shorter ? 07 and 700 share the same part # 1WS-27311-00, 2/. will the 07/700 stand fit onto the 900 ?
    Thanks
  2. #2
    Member sentence's Avatar
    Member #
    7295
    Join Date
    Apr 2016
    Posts
    75
    Quote Originally Posted by wowow44 View Post
    Thanks
    Try giving this one a look
    TRex 2014 2016 Yamaha FZ09 MT09 FJ09 XSR900
  3. #3
    Senior Member abe57's Avatar
    Member #
    3833
    Join Date
    Nov 2014
    Location
    Columbus,IN
    Posts
    1,838
    And more options here : Fz09 adjustable side stand | eBay
    King-Of-Bee's
  4. Remove Advertisements
    FZ09.com
    Advertisements
  5. #4
    Junior Member yamaman's Avatar
    Member #
    10065
    Join Date
    Aug 2016
    Posts
    7
    I have lowered some old bikes and have adjusted the side stand by taking it to weld shop and having them shorten to my desired height, worked perfect and maintained original strength.........and cheaper than buying a new one.
    BazaX likes this.
  6. #5
    Member NickBrewer's Avatar
    Member #
    7621
    Join Date
    Jun 2016
    Location
    Anchorage, Alaska
    Posts
    52
  7. #6
    Member #
    131
    Join Date
    Jul 2013
    Location
    Merced, CA
    Posts
    2,192
    If it is the same part number, it is the same part, regardless of the bike it is listed for.
    There are adjustable sidestands out there and some are pretty trick. My suggestion is to take one of the side stands you have to a welder or machine shop and have them cut a segment out of it and weld it back together.
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Technical Bulletin M2016-006--Side Stand Switch Fault P1601
    By Pseudo-Fed in forum XSR900 General Discussion
    Last Post: 11-15-2016, 02:58 PM
  2. Raised forks/lowered front end
    By JSP in forum FZ-09 General Discussion
    Last Post: 09-09-2016, 10:45 PM
  3. WTB: FZ-09 Left Side Footpeg & Bracket - Headlight Side Brackets
    By Smitherz in forum Parts for Sale / Wanted
    Last Post: 09-09-2016, 05:39 PM
  4. Anyone lowered the bike?
    By Jen in forum XSR900 General Discussion
    Last Post: 08-18-2016, 07:21 PM
  5. Has anyone lowered their bike?
    By Jen in forum FZ-09 General Discussion
    Last Post: 04-03-2015, 07:56 PM
